Wobbly wheel...
TheManWithThe...
PostPosted: 14:29 - 24 May 2011    Post subject: Wobbly wheel... Reply with quote
I had a new rear tire put on during the service and have felt some vibration from it, like it isnt on properly.
could this be because it needs time to wear in and smooth out or could there be a problem with the tire?
(and yes the wheel is bolted on correctly)
thanks
MBK Nitro 50, Sold. Kawasaki ER-5, Honda ST1100
"Anyone can jump a motorcycle! The trouble begins when you try to land it..."
chillyman0
PostPosted: 14:32 - 24 May 2011    Post subject: Reply with quote
Double check that its on straight.
Also put it on the centre stand and let the wheel spin in gear, see if it jumps about then
1996 gsf600n (sold)
TheManWithThe...
PostPosted: 14:35 - 24 May 2011    Post subject: Reply with quote
Will do(y)
i was also informed (by the mechanic) that it may be wobbly cause its chinese....
....if it turns out to be shit..i may get my wheels elsewhere from now on!
im only on a moped, but even that had a good set of Pirellis on to start with!
chillyman0
PostPosted: 15:05 - 24 May 2011    Post subject: Reply with quote
Ignore that mechanic, sounds like a fool.
If it didnt do it before then there must another reason, not just 'because its chinese'!
1996 gsf600n (sold)
PostPosted: 15:22 - 24 May 2011    Post subject: Reply with quote
Did you check that it's exactly the same as the old one, i.e. width, profile, tubed/tubeless (and if it's a tube tyre that it is tubed!), radial/cross/bias ply, and - I'm perfectly serious - that he's fitted it the right way around?
TheManWithThe...
PostPosted: 18:02 - 25 May 2011    Post subject: Reply with quote
im prety sure its the same size, its tubeless, as the original was...and yes, it is on the correct way Thumbs Up
Ive spun it by hand a few times, and from what i can see, the tire rim sits evenly within the wheel rim, but there is on part on the top of the tire which appears to bulge slightly, causing the wobble.
im going to run the tire in for about 2 weeks, and if the problem pursues, take it back to the workshop to get it sorted out.
thanks for all the suggestions Thumbs Up
nowhere.elysium
The Pork Lord
PostPosted: 18:52 - 25 May 2011    Post subject: Reply with quote
Did they bother to balance it?
TheManWithThe...
PostPosted: 18:58 - 25 May 2011    Post subject: Reply with quote
im not sure what they've done to it.
the rollers also had to be changed, and im now finding some vibrations at low revs, shortly after the clutch engages past the biting point, so ill be sure to express my concern if these issues continue in a couple of weeks
PostPosted: 19:02 - 25 May 2011    Post subject: Reply with quote
If the tyre doesn't run true then no matter where it came from it needs to be looked at. Do a visual test with it on the stand and if it's not running true take it back for them to sort.
Suppliers can't supply you a poor product then blame you for where THEY sourced it from.
TheManWithThe...
PostPosted: 19:09 - 25 May 2011    Post subject: Reply with quote
well im on the giving end of a financial insentive to keep me happy...i will shortly be spending quite a bit of my lovely cash on lessons to get my mod1 and 2 done...they shal feel my wrath if i am not satisfied!!!
but at the end of the day, they are good people and i do trust them (apart from a few of their dodgey products) and im sure they would fix any problems that arose
PostPosted: 19:13 - 25 May 2011    Post subject: Reply with quote
You trust someone who tells you that the tyre they fitted poorly is wobbly because they sold you a cheap one?
Wanna buy some magic beans?
TheManWithThe...
PostPosted: 19:20 - 25 May 2011    Post subject: Reply with quote
No, i mean i trust them to fix any problems i have, like a wobbly tire.
PostPosted: 21:03 - 25 May 2011    Post subject: Reply with quote
Take it back, show them this "buldge" thing.. get them to change it.
Its that simple! My tyre kept deflating after having it put on.. turns out the tyre had a sharp piece of metal on the inside which was popping inner tubes.
New tyre and inner tube ftw.
DrDonnyBrago
PostPosted: 21:19 - 25 May 2011    Post subject: Reply with quote
Mate, take the bike to the dealer show them the wobble, tell them it is either a shit tyre or they did a shit job (neither are your responsibility) and you want it sorted.
TheManWithThe...
PostPosted: 22:46 - 25 May 2011    Post subject: Reply with quote
im a bit busy tomorow cause ive got an exam, then have to go and pack for my holiday, but ill definately be taking it to get sorted when i get back.
if they refuse, ill be requesting my old tire back and putting it back on myself (with a little help from a friend who is actually mechanically informed) Laughing
Old Git Racing
PostPosted: 23:33 - 25 May 2011    Post subject: Reply with quote
Take it back and tell them you've took loadsa photo's of it and recorded in writing all their bullshit, and if you have an accident and die your relatives are gonna sue the shit out of them for incompetence.
Alternatively go to someone who knows what they're doing, buy decent tyres and put it down to experience cos in this life you get what you pay for, cruel but true.
OGR
TheManWithThe...
PostPosted: 23:48 - 05 Jun 2011    Post subject: Reply with quote
ive had a word with one of the women who work there, told her i want the mechanic to have another go at fitting it cause im not happy, so ill be booking it in tomorow(y)
my brother has also suggested, if they try to charge me, demanding my £60 back for the shit tire, giving me my original tire back, and fucking off Middle Finger
and old git...your "OGR" sig reminded me of a little sign i sometimes use...
OGC ....if you tilt your head to the left, it looks like a little man spanking the monkey:')
TheManWithThe...
PostPosted: 15:49 - 08 Jun 2011    Post subject: Reply with quote
just an update...i took it to the shop today, the mechanic checked it was on the wheel correctly: it was.
so, comming to the conclusion its a defective tire, im giving them a bit extra to have a pirelli tire ordered in, and im getting it fitted for free.
with the pirelli, they are putting my refund on the defective tire (£40) towards the new one, and im gona pay the difference (£26)
...as my old man says "you get what you pay for" Thumbs Up
The last post was made 15 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 97.45 Kb
