| cagiva gezzer |
 Posted: 19:08 - 25 May 2011 Post subject: New Shed / Workshop |
Finally I'm the proud owner of my own shed. It's a 6'6" deep, 8' wide pent shed.
It also has an extension of 4'x4' on one side, making it a L shape. 210 square foot of wall space / 68 ft floor space, if I've worked that out right.
What I need:
Advice on insulation. I'm planing (haven't worked out the cost yet!) on using 25mm celotex as i've just used this to line a pond. I can only get 100mm loft insulation and I would have to compress this down to 40mm to fit in batons. I'd also need some sort of membrane with loft insulation?
Advice on lining? Ply?
Storage solutions ?
Power? Electrician will be doing it, but what have YOU got power wise that is handy?
Security?
Thanks in advance.
https://i67.photobucket.com/albums/h294/supercitybity/random/DSC02271.jpg
https://i67.photobucket.com/albums/h294/supercitybity/random/DSC02268.jpg ____________________ "because one stroke isnt enough and four strokes waste two" |
| Nope. |
 Nope. World Chat Champion
 Posted: 20:19 - 25 May 2011 Post subject: |
With regards to insulation, Im intending to line my garage with this polystyrene sheet that has foil sides. It comes in various thicknesses and im sure you'll be able to find some to suit. The good thing is you can cut it with a saw down to whatever size you want and its about £6 for a 2M X 2M sheet. Im then going to cover the insulation with Plaster board and paint it. Hopefully that should last a while.
For electricity, we have our shed on a spur that has an RCD in line with it. The cable is armoured and runs in a waterproof armoured rubber jacket under the patio, under the garden and then into the shed. The garage is on a separate ring main though. ____________________ Former: Derbi GP1 50, Sachs XTC 125, Suzuki GSXR 400 GK73A, Kawasaki ZX7R, Suzuki DR250, Yamaha RD350
Current: 2011 Yamaha XT660Z Ténéré, 2003 Yamaha YZR-R1 5PW (In Build), 2009 Kawasaki ZZR1400 |
 Posted: 20:35 - 25 May 2011 Post subject: |
That's a fair size shed.
The celotex will work just fine for insulation and looks like it will fit in the batons. Don't forget to do the roofspace or you'll bake in summer and freeze in winter.
I would line the inside walls with plasterboard on top of the celotex since it thin, easy to install, will add fireproofing and it makes the inside very light and easy to maintain. Best of all it's cheap. The only downside is you can't hang things off it easily, but you can glue a parts rack to it or screw into the batons behind (if you remember to mark them out before covering them).
Plywood would be more secure and add structural rigidity, but smells when it gets hot, doesn't insulate well at all and doesn't reflect light as well either even when painted. Also, it's expensive. ____________________ a.k.a 'Geri'
| AndyB1989 |
 AndyB1989 Scooby Slapper
| Gazdaman |
 Gazdaman I did a trackday!!!
| kawakid |
 kawakid World Chat Champion
| heehaw |
 heehaw Nova Slayer
 Posted: 03:33 - 27 May 2011 Post subject: |
A wee consumer unit like this would do the trick
https://www.screwfix.com/p/mk-sentry-4-way-rcd-garage-consumer-unit/33248
Unless your heating it I personally don't think insulation is worthwhile, its not going to keep moisture or cool out unless you have a heat source, good for keeping the heat out during the 2 days of summer, saying that wrapping rockwool in tin foil is an alternative.
Ply or sterling board lining is ideal. ____________________ Its important, otherwise it wouldn't be there.
Retro Rider Bicycles: CB125TDC, CBR400RR, BSA Bantam. |
| Dazbo666 |
 Dazbo666 World Chat Champion
 Posted: 04:36 - 27 May 2011 Post subject: |
We have a 12ft x 8ft brick built garage.
I fitted a fuse protected DIY power extension, connected to the house mains, some years ago... and I have 3 heavy duty double sockets (freebies sourced from work) inside the garage so that I don't have unneccessary power tool cables laying around the place.
I've considered adding insulation by fitting a plywood ceiling attached to the rafters, and filling the void with rockwool or similar. Our next door neighbour did theirs 2 years ago, so I was keeping an eye on their set-up to find out if there was any issue with condensation etc during the winter months.
With regards to storage I have a couple of workbenches with shelving below them, some home-modified tool racks on the walls, and at one point I have a scaffolding plank used as a high level heavy duty shelf for storage of power tools.
(My next project is going to be a storage rack or trolley for my two welders. I've sourced some surplus metal, so I just need to decide on the design).
Security : A full width, metal up-and-over garage door. The original handle and lock has been replaced with a better quality, more secure option, and the main and side doors are also dead bolted.
....oh and two hyperactive, exciteable, and very possessive dogs helps too  ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
 ..... Quote Me Happy
| pepperami |
 pepperami Super Spammer
 Posted: 17:04 - 27 May 2011 Post subject: |
What I did for security was have a p.i.r.-light fixed to the house pointing towards the shed.
I was at B&Q and they had an offer on home security stuff (old stock), so I bought a battery operated siren alarm.
Scrotes hate to be seen as well as heard
Worked for me  ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
The last post was made 15 years, 26 days ago. Instead of replying here, would creating a new thread be more useful? |
