| Ringadingdoo |
 Ringadingdoo Derestricted Danger
 Posted: 20:49 - 24 May 2011 Post subject: |
Make 'em. It's just a strip of copper/brass folded over and crimped. You'll have to buy the crimping too anyway, if you want to do it proper like. If I was doing it I'd knock up a tool and make the crimp. ____________________ a.k.a 'Geri'
| Ringadingdoo |
| sandman1976 |
 sandman1976 Nova Slayer
 Posted: 20:54 - 24 May 2011 Post subject: |
Or you could buy small cable cramps... Like the ones they use on stainless steel wire fencing, they cramp stuff together
P.S That bike is AWESOME! |
 Posted: 21:47 - 24 May 2011 Post subject: |
My oppinion, borne of years of experience, is that those are a crap way of splicing motorcycle wiring.
I'll tell you exactly why.
They don't seal the insulation up against the wire. Any ingress of damp will track up between the insulation and the wire and rot it for several inches along its length. It also puts all the load on the copper wire. as the wiring bends and flexes during normal use, the copper will work-harden at the stress point just behind the crimp and could eventually break.
I would be using some sort of crimp which has two crimps. One which grips the wire and the second which grips the insulation and seals it down against the wire. I would consider any sleeve or shrink tube over the top of this to be for electrical insulation purposes.
At the most simple are the pre-insulated butt connectors:
https://www.vehicle-wiring-products.eu/VWP-onlinestore/terminalspreins/images/bb.gif
When properly applied with a double crimp using a ratchet crimping tool, you can hang in excess of 16kg off one of those connectors as I proved using empirical methods in THIS THREAD (scroll down)
I am confident the terminal would break before the wire pulls out:
https://i48.photobucket.com/albums/f216/stinkwheel/dscn1019.jpg
There are also heatseal butt splices which crimp in the same way and are then heated so the adhesive backed insulation joins the wires:
https://www.vehicle-wiring-products.eu/VWP-onlinestore/terminalspreins/images/bhs.gif
You said you don't want to solder but here is a soldering option which you don't have to solder. Inline solder splices. Shove the wires in each end. Heat with blowlamp. Solders, heatshrinks and adhesive seals all with one pass of a blowtorch.
https://www.vehicle-wiring-products.eu/VWP-onlinestore/terminalspreins/images/bhss.gif
There are also non-insulated butt splices. This is essentially what is inside the insulated ones, double crimp each side, shrinktube over the top.
https://www.vehicle-wiring-products.eu/VWP-onlinestore/terminalsnonins/images/ctb06.gif
All can be bought from https://www.vehicle-wiring-products.eu/
I would consider the following crimping tool essential for the number of connectors you are proposing:
https://www.vehicle-wiring-products.eu/VWP-onlinestore/terminalspreins/photo/dv5.jpg
Yellow ones will take up to 6sq mm wire. That's 50A thinwall cable, you bike will have nothing that thick on it. So blue for thick wires, red for thin ones. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Ringadingdoo |
| Raffles |
 Raffles World Chat Champion
 Posted: 23:21 - 24 May 2011 Post subject: |
I'm guessing that the wires crimped together in this way are all earth wires. If this is the case then why don't you simply use ring connectors crimped to the end of each wire and connect them all together using a bolt threaded into the bike's frame?
A ring connector:-
https://media.digikey.com/photos/3M%20Photos/MN24-6RK.jpg ____________________ A good loser will always be a loser. |
| Gazdaman |
 Gazdaman I did a trackday!!!
| MarJay |
 MarJay But it's British!
| Gazdaman |
| chris-red |
| Ringadingdoo |
 Posted: 13:55 - 26 May 2011 Post subject: |
Any links to items or products recommended would be great guys.
Ive asked for some samples of open barrel splices which I can get for free, so simpley asked for all sizes available. Great way of getting connectors and switches for free too... but i didn't say that.
Thanks for the input, keep it comin ____________________ https://motochimp.blogspot.com |
| Robby |
 Robby Dirty Old Man
| Ringadingdoo |
 Posted: 18:30 - 03 Jun 2011 Post subject: |
Funny how some say crimp, others say solder, and from both amateur and professional alike.
At this stage im going for crimps, if I can get the right size. I found that I can get samples for free which saves money, also works with getting expensive connectors, so bit of a result there, just cant sell them, which is not an issue
Once i found the right crimp for the job, I will just have to find the right tool, failing that, finding another option. ____________________ https://motochimp.blogspot.com |
The last post was made 15 years, 40 days ago. Instead of replying here, would creating a new thread be more useful? |
