Learn with sidecar or solo?
dandygallop
PostPosted: 23:02 - 26 May 2011    Post subject: Learn with sidecar or solo? Reply with quote
Hi all. Newbie here.
I have dreamed of having a bike and sidecar since I was a little 'un, my Nan and Grandad have always had one and still get about in it now (he is 76, she is 79). I've never wanted to ride on 2 wheels.. I want to take up the whole road! And I have never wanted to drive a car (don't like being in boxes), but thought that the sidecar thang was out of my reach.
Then today, my mum's fella tells me he is willing to pay for me to do my Direct Access as an intensive course AND that if/when I pass, he will help me to get a sidecar outfit. This has gobsmacked me. Dreams coming true? Whatever next.. Denmark banning Marmite? Wink
So anyway, I have been doing a bit of hunting about today for courses in my area (Cornwall - anyone have any recommendations?) and also have been trying to get a bit more info on the rules about sidecars. I know that they are a totally different ride to a solo bike, so my question is this.. Should I learn to ride on a sidecar outfit, seeing as this is what I am going to be riding full-time, or should I learn on 2 wheels and then relearn how to ride with a sidecar?
Thanks in advance,
DG
Teflon-Mike
tl;dr
PostPosted: 23:11 - 26 May 2011    Post subject: Reply with quote
How old are you?
You cant do DAS until you are over 21.
Modern motorcycle test is for Solo's.
You cannot take your test on an outfit, unless you are registered dissabled and the 'three wheeler' is to accomodate your dissability.
So if you want a bike licence, you have to train up on a Solo. Sorry.
dandygallop
PostPosted: 23:15 - 26 May 2011    Post subject: Reply with quote
Thanks for the prompt reply!
I am 35 next month, so a bit of a late bloomer Embarassed . I don't mind learning on 2 wheels, just wasn't sure what the deal with it all was.
DG
virus
PostPosted: 23:48 - 26 May 2011    Post subject: Reply with quote
you will find that piloting an outfit is a massive difference from riding a solo. and not just the obvious dont lean around corners thing.
Generally you will find that the sidcar is unbraked, so applying the brakes hard will cause the outfit to turn right (sidecar keeps going) and under heavy acceleration it will turn left. Of course an experienced sidecar rider uses this to there advantages (powering through left handers etc) but you will find it quite unnerving at the start.
No as nerving as the amount of handlebar vibration and shake if you havent got a sidecar with leading link front end mind.
John
own: 81 xs1100g...
Teflon-Mike
tl;dr
PostPosted: 00:19 - 27 May 2011    Post subject: Reply with quote
John
All the dissadvantages of a motorbike, none of the advantages.
All the dissadvantages of a car, none of the advantages.
added to the inherent instability of a motorcycle, only notionally propped up by a third wheel, asymetrically aligned, so not rpoviding teh 'base' of a trike or car, and the perversions of asymetric single wheel drive....
They are.... an complete ANATHMA.....
I'm pretty perverse, and love a challenge... but side cars!?!?!?!
I'm semi crippled, and cant garantee I can hold up my 'big' bikes any more.... always being told to trike the 750 or fit a chair... but no.... NO.. I just CANNOT wrap my head around them!
dandygallop
PostPosted: 00:33 - 27 May 2011    Post subject: Reply with quote
Many thanks for the replies and opinions.
My grandad used to ride a 'proper' bike. Had done for years. Then he and my nan had a bad smash.. he was uninjured, she broke her back. Thanks to some flippin' good doctors she ended up making a very good recovery, but lost the use of her left arm. My grandad didn't want a car (not wanting to be in a box runs in the family) and my nan wanted to be able to go out with my grandad on the bike, so the sidecar was the option for them. Like I said before, my grandad is 76 now and my nan 79, and they are still going.
My reasons for wanting one are slightly different. Some of it is for sentimental/nostalgia reasons, but the main reason is that I want to be able to transport my kids around. My hubby is the driver, I cannot and will not drive a car. He is due for a double knee replacement, which will put him out of action for a while. We live in the middle of woodland, miles from anywhere and I don't want to be stranded and/or have to rely on friends.
I know that having a sidecar isn't going to be the same as solo riding. I am under no illusion there.
PostPosted: 00:35 - 27 May 2011    Post subject: Reply with quote
What sort of bike do you fancy as a chair tug and what sort of chair do you like?
You don't necessarily need to pass your test to ride a sidecar outfit. You can ride a combo with a power: weight ratio of up to 0.16 kiloWatt/kilogram on L-plates and a CBT (you'd have to do the CBT on a solo machine).
If you've never ridden either and a sidecar is what you want to ride, it might be better to just ride one from the get-go.
It bears virtually no resemblence to riding a solo bike other than the position of the controls anyway. Learning to ride a solo bike first might actually make things worse.
If you want to pass a test and ride a more powerful outfit though, you'll need to do it on a solo bike.
It's an odd calculation for the learner laws. A squire ST3 sidecar weighs 91kg. A CB500 weighs 180kg so at roughly 270kg for the outfit so at 0.16kw/kg you can have a bike with 43kw power output. A CB500 puts out 42 Kw.
So essentially, you can ride a full power CB500 with a moderately large chair attached on L-plates. You'd have to work it out for each bike/chair combo you wanted to ride though, hence my first question. The heavier the bike+chair, the more power you're allowed. You could also ride an Ural combo on L-plates.
I should add my customary disclaimer that sidecars are horrible, unstable, terrifying things to ride but people who have always ridden one seem to have less of a problem than people who are used to a solo bike.
CaNsA
PostPosted: 00:37 - 27 May 2011    Post subject: Reply with quote
What about a trike?
dandygallop
PostPosted: 00:42 - 27 May 2011    Post subject: Reply with quote
The dream is to have a Gemini. I could get the kids in there, plus some groceries. Wink They are pretty weighty, so would need a hefty machine to tug it along, methinks.
Anyway, from all this reading, I know now I need to do it solo to pass the test, and I don't mind that. Who knows? Maybe I will love being on 2 wheels and the sidecar will be but a distant memory. If that happens, the kids can walk..
PostPosted: 01:14 - 27 May 2011    Post subject: Reply with quote
You could probably fit one of those things to a 'busa and still be in under the learner legal power:weight ratio. Laughing
In all seriousness though, you're probably looking at a slightly older bike to fit one of those to (practicalities of size, frame design for the clamps etc.). I'd be very surprised if they weigh in at under 100kg. I've seen a few of those chairs being hauled about on BMW R100s
So how about a BMW R100. Weighs 234kg. So you're looking at a 334kg outfit (minimum). Multiply by 0.16 = 53.4kw. An R100 makes 48kw. Good to go on L-plates.
You are seriously not going to be going over 60 with a gemini car on tow so you don't actually need all that powerful a bike to haul it.
dandygallop
PostPosted: 01:32 - 27 May 2011    Post subject: Reply with quote
Seriously? Now that would be a dream come true, because there is one on fleaBay at the mo. 1976. Definitely the cup of tea for this odd bod. L-plates?? Really??
Teflon-Mike
tl;dr
PostPosted: 02:49 - 27 May 2011    Post subject: Reply with quote
Yup, you can still ride an outfit on L's, but you cant, curiosely take your test on it (unless dissabled)
Whilst ON L's though, you CANNOT carry a passenger, either on the pillion seat or in the chair.
Also if you do the test on a 125 (solo) you will have a 'restircted' licence, and the power to weight limit, sure stink can run the numbers for you, may not exceed that for a solo, but you are allowed the extra power to haul the extra weight.
Starter outfit is usually a Russian Ural, WWII BMW copy. The 'Nostalgia' thing 'got' My uncle about fifteen years ago, when nearing 40 he had his mid life, quit his job, (lost the company car) and went to University... and my Gran helped him by a Dnj... of fluckit! Ruskie thing! Bouyed up by the Two fat cooks or whatever they were, and her reminiscences of when My Grandad was an AA man after the war......
The aquesition of the rusian thing is now family 'legend', becouse I took him down to collect it, and the mad of bat insisted on riding it back from the hinterlands of Wildest Wiltshire to Birminham... having NEVER ridden a three wheeler of any sort before!
I looked at it.... and 'helpfully' suggested we arced and burned out the points to dissable it, and offered to then call the AA for 'recovery'.... no, he INSISTED on riding it home......
I pulled him over three times before we found the M4.... becouse I thought he was going to crash.... he just insisted he was 'getting used to the steering damper' and carried on......
We made the M4... I pulled him into the services, becouse trundling along at 35, I was getting pushed along by irate truckers!
He got me to 'have a go' accross the services car-park.......
"You were a bit wobbly there when you first started, but you got the hang of it by the time you turned round, almost managed a straight line!" He said!
"Got a spanner?" I asked
"Why" He said
"Well, if we wip the rocker cover off and close up the valve clerances so the valves stay opne, we can call the AA!"
"Philistine!" he retorted, and clambered back abouard and wobbled off past the filling station....
I got back in his wifes Pug, and followed him out... wondering if I would ever need fourth gear!
Dusk was settling, and we charted our way, onto the M5.... he was getting colder and colder and the eratic tacking of this 'Thing' was becoming more and more err.... spikey!
I think I ought to point out at this juncture, that I was riding a VF1000 every day at that time, and making excursions to such places as Glastonbury, from my home in Stratford Upon Avon, in, Oh... a little over an hour! this was near torture! WITHOUT having ruddy artics trying to give me a Volvo enema!
I ALSO ought o describe what I was looking at through the windscreen of the peugot....
The 'Russian Thing' was a three year old Dnjni--fukit- Ural Weimach BMW Outfit 'copy'... but some one had had the notion to paint it in desert camoflage colours......
My Uncle, had not ridden a Solo motorcycle for nearly six years. But having bought this 'thing', had pulled his 'best' motorcycling attire out of the back of the wardrobe..... that consisted of his one piece racing leathers, from when he had had the notion to have a go at that, becouse riding on the public road was 'too dangerouse'..... that were too small for him, and his Freddie Spenser replica Airai helmet..... BUT he had no gloves, becouse he had loaned them to some-one and forgotten, in the midsts of time, who!
So, we have something that looks like its been stolen from the Imperial War Museum, bring ridden by someone that looks like a refugee from a GP Paddock...... with iceicles!
I pulled him into the next services.....
"Whats Wrong NOW?" He demanded.
"I want a coffee" I said
"Is that all?" He retorted, "Fin, I'll carry on, and you can catch me up!"
I bit back a quip, that I'd meet on the slip road out of the Services then... and instead insisted, "NO, YOU need a coffee too!"
I think that the cold was starting to numb his brain....
Not that much rational thinking was taking place in it to begin with, having actually BOUGHT this 'thing'!
"Why? I'm fine!" He insisted.
"No your not, I'm standing on your foot! See you cant even FEEL it!"
"Oh... Ok, just a quick one, then!"
I made him have three, which was how long it took for him to change colour, from a sort of blue, to a ruddy red.
I made on last bid to convince him to let me tempererily parlise the damn thing, so we could call the AA, but he refused, so I stalled him and insisted he at LEAST check the oil, before we left the services.
Five miles up the M5, and the blue fug that has been actually deminishing the closer to home we got, was back with a vengence.
I could no longer see the spare tire on the back of the chair, through the fog coming out the exhausts.
I over took, and pulled him onto the hard shoulder.....
"Its fine, its FINE, its just the excess oil we topped up wit at the last services burning off!" he insisted and nerly dented his missus' mota, in an errant tack riding past me to get back on the motorway between two forty ton lorrie, going three times as fast!
I had a fag, and let him get ahead a bit.... before following him.
There is a long steep hill, on the M5 just before Glauster...... and as we aproched it, the smog was like LA on a bad day.... and he was getting slower and slower and slower, until I could stand no longer the jugganauts attempting anal intrusion!
And pulled him over, onto the hard shoulder YET AGAIN!
"What is it THIS time" he yelled at me..... As I stepped out of the smoke screen, the engine still chuffing over.
I waved some fumes away and suggested he have a look.....
"Well its a BIT worse!" he admnitted..... "But it'll make it back, I'm sure"
"You were down to 15 mph...."
"Well, we're goiing up hill! I'll be fine coming down the other side!"
I stood, patiently looking at him.... and the bike coughed, spluttred, and as he tried blipping the throttle, finally died....
"Now look!" he grumbled "If I'd kept going it wouldn't have conked out!"
He started fiddling with the kickstarter and jumping up and down on the lever, cursing as he bruised himself on the side of the chair....
I left him to it, and went back to the car, got my helmet and jacket, and dug my AA card out of my wallet, and returned, with his missus' mobile phone.....
"CALL them!" I urged.
"No! No! She'll star, she's just a BIT HOT!" he said, making a few more futile lunges over the kicks starter.... "Well, OK, but I have some tools in teh car,. maybe we can fix it.... What do you think it is!"
I looked at the still lingering smog.... "Fucked!" I offered, as a highly technical diagnosis!
"No, no, come on, Gummed rings" He enquired, hopefully "Maybe just a valve stem seal's gone" He added, in shear delusional optimism.....
I waved a little smoke asside..... "More likely cracked rings, or a completely cracked valve guide, but my guess is you have a very holed piston"
"You reckon?" He asked... "Nah! Still running, look!" He prodded the kicker again, but it didn't do anything....... "Well, maybe the AA can get it running again... I'll call them!" he said, as if it was all HIS idea all along!
But I had to call them, becouse it was MY AA card...
I spent the next twenty minutes trying to tell them where we were.... "Some where on the M5 just outside Glauster, in a cloud of smoke!" apparently it wasn't on thier map..... bu the biggest consternation was caused when I tried to give the vehicle details....
I STILL cant even spell it! In the end I told them it was a BMW!
AA patrol, turned up about 45minutes later.... And we got 'MrAngry' AA-Man Esq!
"THAT'S Not a Fucking Motorbike!" he yelled! "They told me it was a Motorbike. How the hell am I supposed to put that on my tail lift!"
And started ranting at me, and grumbling I didn't tell them it had a side car...... until he got back onto the radio and they told him I HAD told them it was a side car, but they didn't have the 'option' on thier computer thing, for one!
So they called for a flat-bed.... Mr Angry, COULD have left at this point, but no, he insisted on staying until teh recovery truck arrived, ranting about the AA Control centre, customers in general, and 'bludy motorbikes'... half in wonder at this 'thing' and half expressing his general disgruntlement at motorcycles and motorcyclists in general, NOT being convineintly conventional and being easy to deal with like 'cars'!
THEN the Recover truck arrived.... and for THIS bit of the saga, my Uncle has YET to be forgiven!
Remember, the AA Card is in my name, and covers the driver... so I 'technically' had to be riding the outfit.
So before the AA man had arrived, I's stuck my leathers on... and remember it was freezing cold.... so I had put my leather trousers and boots on to stay warm......
The Recovery truck Driver, whose Iveco Trcuk cab I cringed in the corner of for the next fifty minutes was a vewy nithe man, cawled Jiylz........ who lived with his partner Dewithk, and they weawed heiff'z, and they alw have naymes, dont you know, becouse they ar awl unique, and have thier own indiviguell pethonalitieez... Oh yis, when we go out to give them thier feed.....
Which wouldn't have been QUITE so err..... bad.... apart from not ONLY being as camp as a field of tents..... he was a really touchy feelie, one..... FINE...... except he was touching and feeling my KNEE.... err... no, thats a little bit lower!
EVERY time he made a 'you know!" comment, he patted my leg, and got higher with each pat...... and was COMMENTING on the texture of the leather!
"Oh, that MUST have come from a Jersey cow! So is it a BMW?"
And proceeds to tell me how he and Dewithk, didn't have a TV, in thier cottage, but Dewithk, helped him work on his antique Frazer Nash sportscar, which was a birtish build pre-war BMW.... I winced, and shifted my leg as FAR into the door pocket as I could get it, as the inevitable 'don't you know' was accompanied by the flailing arm... that for once found not leather but free air, resulting in a nervouse laugh, and shuffle to find the gear lever!
I an NOT homophobic, but THAT chap nearly made me so!
So, when we FINALLY arrived back in Brum..... I invited him in for a coffee!
So my blasted Uncle could suffer a bit of him too...... "Oh is this Java?" he said, the arm waving.... as my Uncle handed him the cup......
This DID NOT endear Side car outfits to me any!
Turned out to be a very holed piston, BTW.... and three rebuilds and half a BMW engine later, it actually managed to make a ten mile journey without major maledy!
So he sold it! And bought another! And rode it round the Pyranese!
Last year, after completing his Doctorate, and a year or two belated for his 50th birthday, he treated himself to a Hinkley Bonnaville and Watsonian....... it was far too, 'boring' aparently, and he went back to the Russian things!
Be WARNED, outfits are a perversion, and it seems one that only gets WORSE the more you try and satisfy it.......
That vewey nice Jiylz, I THINK in retrospect, possibly HELPED dissuede me from being sucked into the fettish, through my uncle's infectiouse enthusiasm!
As the mere MENTION of 'outfits' gives me flashbacks of the whole unhappy episode to compound my natural, incomprehension of the creed......
I have to confess, that I DO see the attraction, I understand the appeal, and I DO find them fascinating... but on THIS one I think I'll remain a voyeur, rather than a participant!
PostPosted: 09:48 - 27 May 2011    Post subject: Reply with quote
Ahh. I didn't know this. You always used to be able to take a passenger in the chair but not on the bike on L-plates. Not so handy then.
PostPosted: 12:20 - 27 May 2011    Post subject: Reply with quote
Thanks Mike and Mr wheel, that's fascinating stuff.
I can never remember, does the power-to-weight limit calculation take into account 'extras' like fuel, luggage and bullets?
https://www.blackletter.org/news/Ural-jump.jpg
virus
PostPosted: 16:03 - 27 May 2011    Post subject: Reply with quote
I can wholeheartedly agree on this one. Laughing Thumbs Up
John
own: 81 xs1100g...
blurredman
PostPosted: 16:17 - 27 May 2011    Post subject: Reply with quote
I'd get a trike. Then you wouldn't need a helmet.
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 52k.
dandygallop
PostPosted: 19:49 - 27 May 2011    Post subject: Reply with quote
Thanks everyone. Love the tale Mike, thank you!!
I have been looking at trikes, but they ain't for me. I guess I just want to follow the family tradition. Smile
I will keep you posted as to what happens. Solo riding is the way start and that's the route I'm going to take for my test, but I will ultimately get my hands on an outfit, preferably a Gemini.
DG
Pete247
PostPosted: 20:19 - 27 May 2011    Post subject: Reply with quote
You'd still need a helmet, but you'd not necessarily be legally required to wear one.... again all down to the weight I think of the trike as to iff you legally have to wear a lid, think it would be massively foolish not to wear one tho!
PostPosted: 20:39 - 27 May 2011    Post subject: Reply with quote
Aye. If you get one, don't let John ride it. Virus has consistantly driven every sidecar he's ridden into a hedge or a fence within a few hundred metres.
blurredman
PostPosted: 21:38 - 27 May 2011    Post subject: Reply with quote
That's the joy of it. It's My Decision.
virus
PostPosted: 08:51 - 28 May 2011    Post subject: Reply with quote
Hey im not that bad.
Quarter of a mile on mouses bmw outfit before I dragged the back brake to try and tighten up in a left hand bend (like you would on a solo) and promptly binned it through a fence.
bout a mile on ferrets K series BMW outfit before I parked it in a dried out pond, but admittedly that was more of a visibility issue than a riding skill issue, it was very dark and id never seen that field in the light of day before.
Although I did park the K outfit halfway up a hedge with adam in the chair once because I drifted right too far for my liking and instead of corrective steering and acceleration I panicked and hit the brakes.
so yeah, I have crashed every sidecar Ive ever ridden pretty much every time Ive riden one, but the average distance between crashes has been going up. Laughing
John
own: 81 xs1100g...
The last post was made 15 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 2.31 - MySQL Queries: 13 - Page Size: 136.23 Kb
