| mattyriddell |
 mattyriddell Derestricted Danger
| Chriss |
 Chriss World Chat Champion
| mattyriddell |
| Minty |
 Minty World Chat Champion
 Posted: 15:39 - 27 May 2011 Post subject: |
Lowering can easily screw up the handling if you are not careful.
At least you want to lower both the front and rear by the same amount to preserve the steering geometry. But even that can have odd effects. Ie, under hard acceleration a bikes rear suspension will normally extend due to the swinging arm spindle being higher than a line drawn between the gearbox output shaft and the rear wheel spindle. Lower it and that will likely not be the case anymore and the rear suspension will instead compress.
Also if you lower the bike remember you will probably need to shorten the side stand. And that you will reduce ground clearance when cornering.
Practical issues are that with usd forks (like the RS uses) often they are not a constant diameter at the top, limiting how much you can move the forks in the yokes to lower it. Also the RS rear suspension doesn't use conventional separate dog bones (which are easy to make to a different length to lower / raise the bike). The dog bones are part of one of the links making them harder to make.
Further point is the effect of lowering on spring rates. If you lower the back of the bike you will change the effective rate of the spring (rising rate suspension linkage, so the more it is compressed the quicker it compresses the spring). If you shorten a spring you will make it stiffer (bodge way of lowering cars is to chop a ring from the spring which will lower and stiffen the suspension). If you just drop the front down through the yokes you will not affect the spring rate, hence possibly landing up with them mismatched (although do it too much and there is the possibility the front tyre will touch something as the suspension compresses).
Overall none of these things are insurmountable, and most people just lower it and put up with the (normally not great) effects on handling.
| P.addy |
 P.addy Red Rocket
| Bendy |
 Bendy Mrs Sensible
| Slacker24seve... |
 Slacker24seve... World Chat Champion
| jimbothe |
 jimbothe World Chat Champion
 Posted: 19:16 - 27 May 2011 Post subject: |
I'm not familiar with the bike but if it's that much of a problem can you not lower the seat itself, i.e half the foam inside it.
A few people have done it and it seems to work ok, albeit with bigger bikes. ____________________ Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle |
| Wave2k |
 Wave2k G's Stalker
| Drake |
 Drake World Chat Champion
 Posted: 23:09 - 27 May 2011 Post subject: |
one word.... dwarf ____________________ was: derbi senda, aprilia sx125, nsr250 mc16, cagiva mito, cb600 hornet now: mk1 bandit, KR1S, landrover series 3 light weight 2.5 petrol, 5speed box |
| colin1 |
 colin1 Captain Safety
| hazza |
 hazza World Chat Champion
| MarJay |
 MarJay But it's British!
| Fahd |
 Fahd World Chat Champion
The last post was made 15 years, 131 days ago. Instead of replying here, would creating a new thread be more useful? |
