filling brakes from empty
bagger
PostPosted: 14:31 - 30 May 2011    Post subject: filling brakes from empty Reply with quote
hi ive got a complete front braking system thats empty,any good tips/tricks for filling without spending hours trying to flush out airlocks?
its off a sv650
cheers
sv650s,cb350s
PostPosted: 14:34 - 30 May 2011    Post subject: Reply with quote
Fill up the callipers before bolting the lines on.
Marmalade
Flick the lever away from the bars, leave bleed nipples/s open or remove the pipe from master until fluid makes its way through, once it does reattach pipe and let fluid make way down pipe, bleed
Works for me
Serendipity
PostPosted: 16:49 - 30 May 2011    Post subject: Reply with quote
I’m in the same position. I’ve just rebuilt my callipers and bought new HEL hoses.
I was planning to try filling the system from the bottom up using a large syringe attached to the bleed nipple by plastic tubing. Once full I’ll then bleed through as normal.
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
CaNsA
PostPosted: 18:56 - 30 May 2011    Post subject: Reply with quote
If you are certain the system is full, yet you still cant get the brakes to bite take the master cylinder off and angle it so all the air rises into the reservoir.
Blasted m/c airlocks are sooooo easily over looked.
temeluchus
PostPosted: 18:57 - 30 May 2011    Post subject: Reply with quote
Run a length of hose from the bleed nipple to a funnel or suitable bottle with the bottom cut out. Have the funnel/bottle at the level of the reservoir, and fill from there until fluid starts to fill the master.
Avoids having to spend loads of time bleedong the breaks.
ZRX61
Victor Meldrew
PostPosted: 05:53 - 31 May 2011    Post subject: Reply with quote
Fill from the bottom.
They're not one night stands, they're auditions.
truslack
PostPosted: 11:29 - 31 May 2011    Post subject: Reply with quote
Fill from top, attach a piece of clear pipe to bleed nipple, suck on pipe.
Health and safety warning: don't drink the brake fluid or bad things may happen.
MarkJ
PostPosted: 12:19 - 31 May 2011    Post subject: Reply with quote
Do this.
bagger
PostPosted: 22:08 - 31 May 2011    Post subject: Reply with quote
cheers guys good stuff Thumbs Up
sv650s,cb350s
ZRX61
Victor Meldrew
PostPosted: 20:16 - 01 Jun 2011    Post subject: Reply with quote
If you can't find a big enough syringe, use a trigger type oil can instead.
chrisjpartrid...
PostPosted: 12:46 - 02 Jun 2011    Post subject: Reply with quote
If you'd lke an excuse to spend money on new tools these are pretty good:
https://cgi.ebay.co.uk/Sealey-Vacuum-Tester-Brake-Bleeding-Kit-VS402-/180652929439?pt=UK_Hand_Tools_Equipment&hash=item2a0fc0f19f
Serendipity
PostPosted: 14:01 - 02 Jun 2011    Post subject: Reply with quote
A decent length of clear PVC tubing and a 100ml syringe can be had off Ebay for a very small handful of the Queen's coin.
I originally bought my syringe for measuring fork oil.
The last post was made 15 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 74.77 Kb
