Santa Pod first time . Advice?
thx1138
PostPosted: 21:08 - 30 May 2011    Post subject: Santa Pod first time . Advice? Reply with quote
https://www.santapod.co.uk/calendar.php
Sat 4th (weather permitting Rolling Eyes ) going along with some mates from my club on their bikes.
Never done it before, and my bike is standard, '57 plate fazer 1000.
Don't really know what to expect. Any advice?
Bendy
Mrs Sensible
PostPosted: 21:16 - 30 May 2011    Post subject: Reply with quote
Queue, queue, queue, queue, queue, ride bike for 10 seconds, queue, queue, queue.
Repeat, with occasional diversion past the burger van. Thumbs Up
AngelGrinder
PostPosted: 10:05 - 31 May 2011    Post subject: Reply with quote
There's no line on the actual track, you have to gauge it from the lights. Slowly ride up near to the marshall, and the first amber staging light will come on. Then, the next bit is up to you. Make sure your in 1st gear and your visors down. Right foot on the floor, left foot underneath the gear lever.
At Santa pod, as soon as your both staged (both amber lights on) they almost immediately whack the green light to go. SO...if your second to finish staging, have your revs up before you hit the second light and be ready to go almost immediately.
To launch, you want alot of revs, in your powerband ideally, and launch using the clutch. You want the clutch up, and throttle on fully as quickly as possible without the front coming up. So play around with launch revs and clutch control.
Practice this, as it can be fairly scary if your not used to pinning it from a standstill, and read about it online a bit....Good luck!
PostPosted: 10:14 - 31 May 2011    Post subject: Reply with quote
If you want to do a burn out do that on the wet patch. You actual start is between 2 lines, so creep forward until you are position correctly.
You don't really need much revs on a normal bike. The speed you accelerate is down to torque which is fair constant through the revs and drops off at higher revs (well, unless you have a bike in a high state of tune - or a sports 2 stroke). Better to start at fairly low revs, minimise the clutch slipping and be using as much throttle as possible as soon as possible.
Ben.
PostPosted: 11:26 - 31 May 2011    Post subject: Reply with quote
on a litre the trick is to get the clutch out as quick as possible.
slipping the clutch is for under powered bikes, try and get that clutch out as soon as you can, i usually launch at about 6k revs on the r1 in a race, slip the clutch for a second or two then roll on the power as hard as you can without the front coming up.
follow my racing season
Race bike - R6
Road bike - sv650
PostPosted: 11:34 - 31 May 2011    Post subject: Reply with quote
As the others have said for the start. Leave your tyre pressures where they are.
Once you're rolling get yourself crounched down and all your arms and legs tucked in as soon as possible.
If you're Angelgrinder they'll be a blue B1H ahead of you as well. Razz
AngelGrinder
PostPosted: 18:04 - 31 May 2011    Post subject: Reply with quote
FFFFFFFFFFFFFFUUUUUUUUUUUUUUUUU
PostPosted: 19:49 - 31 May 2011    Post subject: Reply with quote
thx1138
PostPosted: 11:03 - 03 Jun 2011    Post subject: Reply with quote
I'll probably start conservatively at about 4k, and build up from there.
Day to day riding I pull away at tick over, tried some half hearted launches yesterday to get the feel, and 4k is fine, 5to7 it all starts lifting up and feeling a bit skittish.
I can ride laid over the tank all tucked in, I usually wear an open face crash helmet on the road, and often tuck down out of the wind when I get a move on.
So, I plan to just pull away, get into second ducked down and tucked in and take it from there.
It will probably all go to shite on the first attempt anyway, as I forget to do everything I've just said Laughing
I'm sure I'll get better as the day goes on, most of all I shall have fun with a bunch of mates, most of whom will be quicker.
AngelGrinder
PostPosted: 11:38 - 03 Jun 2011    Post subject: Reply with quote
You'll definately get better during the day as you get more confident.
Also, you'll find out which gears work best, I tried to hold 3rd gear, but it would hit the limiter just before the finish line, so you'll need to keep an eye on that. And make sure you whack the gear lever hard enough that you don't hit any false neutrals Embarassed
thx1138
PostPosted: 21:00 - 03 Jun 2011    Post subject: Reply with quote
https://www.youtube.com/watch?v=dSFoHoDBG0w
found this useful 5 minute guide to santa pod on a bike Thumbs Up
thx1138
PostPosted: 17:34 - 04 Jun 2011    Post subject: Reply with quote
https://img.photobucket.com/albums/v616/THXII38/santapod1.jpg
https://img.photobucket.com/albums/v616/THXII38/santapod2.jpg
https://img.photobucket.com/albums/v616/THXII38/MF4M0227.jpg
https://img.photobucket.com/albums/v616/THXII38/MF4M0229.jpg
https://img.photobucket.com/albums/v616/THXII38/MF4M0642.jpg
that was fun Thumbs Up Very Happy
thx1138
PostPosted: 17:43 - 04 Jun 2011    Post subject: Reply with quote
Right, don't laugh at my reaction time, thanks. Embarassed
+.5910 Reaction
2.1402 60ft
5.2581 330ft
7.6838 1/8 ET
101.05 1/8 MPH
9.7928 1000' ET
114.95 1000' MH
11.5971 1/4 ET
123.40 1/4 MPH
Ariel Badger
PostPosted: 20:40 - 07 Jun 2011    Post subject: Reply with quote
do not make the photographers fall over
thx1138
PostPosted: 20:48 - 07 Jun 2011    Post subject: Reply with quote
Ariel Badger wrote:
I just laughed very hard at that. Thumbs Up
thx1138
PostPosted: 23:32 - 07 Jun 2011    Post subject: Reply with quote
I just did a search on youtube, and ....... my first every try at this is on there. Someone filmed the Buell I was up against. I'm in the back lane.
https://www.youtube.com/watch?v=rxhKcKeBp7k
Old Git Racing
PostPosted: 23:48 - 07 Jun 2011    Post subject: Reply with quote
Top man, you were out there doing it, was it a good buzz and what did you learn?
The time on track is pretty limited but the craic is good Very Happy
OGR
thx1138
PostPosted: 11:17 - 08 Jun 2011    Post subject: Reply with quote
OGR
I learned that what appear to be knackered old ford rust heaps can go like the proverbial off a shovel!
That I don't suffer from nerves on the start line, but my heart goes like a jack hammer when I've slowed down at the other end.
That I really, really do need to kick hard into second, cos I did get into neutral one run. Embarassed Still, I stayed calm, let off the throttle, adjusted my speed, aborted the run and cruised to the finish line.
Refused to take any stick from my mates in the stands that were not running, at least I put my money where my mouth was.
That time is weird, actual time on the track is seconds, yet it seems to stretch out and last longer. I didn't think it was a waste of time at all, I loved every minute of the day, seeing the cars in the queues, talking to the other bikers in the queues, watching from the stands, the whole lot. Great fun.
Gerrard
PostPosted: 16:51 - 17 Jun 2011    Post subject: Reply with quote
I did a run wot you brung years ago and had a great day.
Its harder than you think but as another poster said there is a lot of queing.
But enjoy it... I did.. Thumbs Up
Honda Blackbird the great all rounder.
Chillin near Malaga.
Marco Simoncelli 58
The last post was made 15 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 106.78 Kb
