Unusually low top speed....
mat91
PostPosted: 21:45 - 30 May 2011    Post subject: Unusually low top speed.... Reply with quote
hey guys I have a hyosung gt125r which I recently changed the engine with one off a gt125 but for some reason it doesnt go past 9,000 rpm in 4th gear like its ran out of steam can anybody help me with this please? cheers mat
hyosung rider
mat91
PostPosted: 23:04 - 30 May 2011    Post subject: Reply with quote
getting 52mph at 9,000 rpm and before the bike used to get 75mph on redline in 5th gear at 10,500 rpm
hyosung rider
mat91
PostPosted: 00:00 - 31 May 2011    Post subject: Reply with quote
same as what came off my last engine
hyosung rider
Frost
PostPosted: 00:21 - 31 May 2011    Post subject: Reply with quote
Might have different internal gearing requiring different sprockets for the same result?
Fairies attack This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 04:39 - 31 May 2011    Post subject: Reply with quote
Something is wrong with the fuelling or the replacement engine is knackered.
Could also be the timing is set up different for each, requiring the correct CDi.
mat91
PostPosted: 08:31 - 31 May 2011    Post subject: Reply with quote
Engine is a 55 plate and is a Carb, my original was a 56 Carb but was thinking if the valve clearances Would affect the engine this much?
hyosung rider
mat91
PostPosted: 08:45 - 31 May 2011    Post subject: Reply with quote
Btw the compression is 120 psi in both cylinders, when I compression tested the front the back started the bike on its own so plenty of compression in the engine
hyosung rider
PostPosted: 09:58 - 31 May 2011    Post subject: Reply with quote
Quick look and on stock gearing the GT should do 50.7 @9k in 4th and 70.7 at 10.5k in 5th. As such seems to match up with what you are getting / got before so the gearing seems to be the same between the 2 engines.
Does suggest that something else is wrong, but there are loads of things it could be. 120psi sound a bit low for compression on a 4 stroke, but being the same on both cylinders sounds unusual.
PostPosted: 10:26 - 31 May 2011    Post subject: Reply with quote
Where are you based in the UK?
mat91
PostPosted: 10:27 - 31 May 2011    Post subject: Reply with quote
Hey Keith cheers for the info I have a 15 tooth on the front and 54 tooth. On back but this was the same on my last engine, even tho the carbs are the same off the original engine could it be a fuel/ air problem you think? Maybe I need to tweek the mixing screw a bit?? Cheers mat
hyosung rider
mat91
PostPosted: 10:28 - 31 May 2011    Post subject: Reply with quote
I'm in long Eaton not far from Nottingham and derby
hyosung rider
PostPosted: 10:35 - 31 May 2011    Post subject: Reply with quote
Your gearing should be 14 and 52... Think thats what mine was before we swapped them.
Was going to say if you was local, i'd come have a look, but thats missions Laughing
PostPosted: 10:41 - 31 May 2011    Post subject: Reply with quote
Could be a carb problem. You could have dislodged some rubbish in the tank while playing and have it blocked a filter or caught in a jet. Similarly you could have left off or kinked a vacuum line (although not sure the GT125 carbs have any external vacuum lines).
The mixture screw affects idle and tiny throttle openings and should be pretty much irrelevant at the speeds you are having issues with.
Think the GT125 compression should be 11~13 bar, so 160psi~190psi. Assuming you checked the compression properly it is very low.
mat91
PostPosted: 11:43 - 31 May 2011    Post subject: Reply with quote
Cheers Keith anyway I can up the compression? Maybe valve clearances? And where bouts are you paddy?
hyosung rider
PostPosted: 12:06 - 31 May 2011    Post subject: Reply with quote
Possible valve clearances could affect it, but I would be a tad surprised if it affected both cylinder equally. Also to lower compression the valve clearances would need to be tight, which would burn out the valves. And burnt valve are a far more likely cause of low compression. Damaged rings would be another likely cause.
Valve timing could possibly do it, but not sure how the cam drive is set up on the Hyosung engine so whether it could easily be out on both cylinders at once. Let alone if being that far out would have resulted in valves and pistons meeting.
However double check the compression (and see if someone else can confirm what it should be) as yours seems very low and strange for both cylinder to be equally low. You should be able to trigger the starter relay to crank the engine over (full throttle for a compression check) without the ignition on to prevent it starting on one cylinder.
mat91
PostPosted: 14:07 - 31 May 2011    Post subject: Reply with quote
Right what I shall do after work is check valve clearances and spark plug colour and adjust my mixing screw to alter colour of my spark plugs and see if they increase anything
hyosung rider
PostPosted: 14:32 - 31 May 2011    Post subject: Reply with quote
While easy things to double check, I wouldn't hold out much hope.
Not sure if the Hyosung has CV carbs but if so the plug colour will be fairly meaningless. Way too hard to control things to get a consitant amount of fueling for long to do a meaningful plug chop.
At the revs / speed you are at you should be on the main jet, or at least at a point where it has a major influence. The mixture screw will have a negligible effect on the fueling there. Suppose putting it in real world terms, imagine the mixture screw as a salt shaker, capable of making a plate of food salty. If you now use it on a giant cooking pot of food with enough there to server a regiment the effect will be negligible.
mat91
PostPosted: 16:54 - 31 May 2011    Post subject: Reply with quote
Hey guys I have found out that the engine is restricted does anyone know where they restrict these?
hyosung rider
zombie_dave
PostPosted: 16:58 - 31 May 2011    Post subject: Reply with quote
your engine is a 125 four stroke, it isnt going to be restricted................
only 2smokes and bigger bikes* get restricted (*e.g if you have a restricted licence)
ZombiE_DavE
PostPosted: 17:05 - 31 May 2011    Post subject: Reply with quote
UK one wouldn't be restricted (no need, not really going to exceed the learner power limit), and not sure what other markets would restrict them. Ie, think Germany has a licence or insurance category that is for bikes restricted to 80kmh.
Who has told you it is restricted and have they told you what market it was restricted for?
Main ways to restrict a bike would likely be an exhaust, carb or ignition change and I presume you have these from the old engine. Probably engine wise the easiest thing to change would be the cams but I would be very surprised if any maker bothered to change those for some local market restriction.
Livefast123
PostPosted: 18:29 - 31 May 2011    Post subject: Reply with quote
The Hyosung service manual states that the compression should be between 156 - 185 Psi with the service limit running at 142 Psi so if you are reading 120 Psi then you have got some major ring wear or another problem with the valves Thumbs Down
Are you sure that you did the compression test right with the engine up to working temperature, if you did it cold then the reading will be well down?
Hyosung engines are not restricted, have you checked the obvious stuff like fuel filter, spark plugs etc and the exhaust is not partially blocked. Something to note is that airfilters are very expensive if you buy them in the UK so many don't bother changing them. I'd check it as it only takes a few minutes and if blocked would make the bike run stupidly rich which would give poor top speed.
Check the throttle is properly adjusted as they have a stupidly long action throttle and it may not be opening properly.
Might be an idea to post on https://ukhyo-ownersclub.co.uk/ or Korider as many more Hyo 125 riders hang about there.
Current ride - Yamaha MT-07
mat91
PostPosted: 12:40 - 06 Jun 2011    Post subject: Reply with quote
I changed cdi as it gave power problems before but will check valve clearances and look at piston rings see what they look like but they said they only got 60 out of it in the bike it was from but does more than that it mine
hyosung rider
The last post was made 15 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.22 - MySQL Queries: 15 - Page Size: 127.85 Kb
