| mat91 |
 mat91 Derestricted Danger
| N cee thirty |
 N cee thirty Banned
| mat91 |
| N cee thirty |
 N cee thirty Banned
| mat91 |
| Frost |
 Frost World Chat Champion
| Fairies attack |
 Fairies attack Banned
| Pete. |
 Pete. Super Spammer
 Posted: 04:39 - 31 May 2011 Post subject: |
Something is wrong with the fuelling or the replacement engine is knackered.
Could also be the timing is set up different for each, requiring the correct CDi. ____________________ a.k.a 'Geri'
| mat91 |
| mat91 |
| Kickstart |
 Kickstart The Oracle
 Posted: 09:58 - 31 May 2011 Post subject: |
Quick look and on stock gearing the GT should do 50.7 @9k in 4th and 70.7 at 10.5k in 5th. As such seems to match up with what you are getting / got before so the gearing seems to be the same between the 2 engines.
Does suggest that something else is wrong, but there are loads of things it could be. 120psi sound a bit low for compression on a 4 stroke, but being the same on both cylinders sounds unusual.
| P.addy |
 P.addy Red Rocket
| mat91 |
| mat91 |
| P.addy |
 P.addy Red Rocket
 Posted: 10:35 - 31 May 2011 Post subject: |
Your gearing should be 14 and 52... Think thats what mine was before we swapped them.
Was going to say if you was local, i'd come have a look, but thats missions  |
| Kickstart |
| mat91 |
| Kickstart |
 Posted: 12:06 - 31 May 2011 Post subject: |
Possible valve clearances could affect it, but I would be a tad surprised if it affected both cylinder equally. Also to lower compression the valve clearances would need to be tight, which would burn out the valves. And burnt valve are a far more likely cause of low compression. Damaged rings would be another likely cause.
Valve timing could possibly do it, but not sure how the cam drive is set up on the Hyosung engine so whether it could easily be out on both cylinders at once. Let alone if being that far out would have resulted in valves and pistons meeting.
However double check the compression (and see if someone else can confirm what it should be) as yours seems very low and strange for both cylinder to be equally low. You should be able to trigger the starter relay to crank the engine over (full throttle for a compression check) without the ignition on to prevent it starting on one cylinder.
| mat91 |
| Kickstart |
 Posted: 14:32 - 31 May 2011 Post subject: |
While easy things to double check, I wouldn't hold out much hope.
Not sure if the Hyosung has CV carbs but if so the plug colour will be fairly meaningless. Way too hard to control things to get a consitant amount of fueling for long to do a meaningful plug chop.
At the revs / speed you are at you should be on the main jet, or at least at a point where it has a major influence. The mixture screw will have a negligible effect on the fueling there. Suppose putting it in real world terms, imagine the mixture screw as a salt shaker, capable of making a plate of food salty. If you now use it on a giant cooking pot of food with enough there to server a regiment the effect will be negligible.
| mat91 |
| zombie_dave |
 zombie_dave Borekit Bruiser
| Kickstart |
| Livefast123 |
 Livefast123 Nearly there...
 Posted: 18:29 - 31 May 2011 Post subject: |
The Hyosung service manual states that the compression should be between 156 - 185 Psi with the service limit running at 142 Psi so if you are reading 120 Psi then you have got some major ring wear or another problem with the valves
Are you sure that you did the compression test right with the engine up to working temperature, if you did it cold then the reading will be well down?
Hyosung engines are not restricted, have you checked the obvious stuff like fuel filter, spark plugs etc and the exhaust is not partially blocked. Something to note is that airfilters are very expensive if you buy them in the UK so many don't bother changing them. I'd check it as it only takes a few minutes and if blocked would make the bike run stupidly rich which would give poor top speed.
Check the throttle is properly adjusted as they have a stupidly long action throttle and it may not be opening properly.
Might be an idea to post on https://ukhyo-ownersclub.co.uk/ or Korider as many more Hyo 125 riders hang about there. ____________________ Current ride - Yamaha MT-07 |
| mat91 |
The last post was made 15 years, 131 days ago. Instead of replying here, would creating a new thread be more useful? |
