| mealies |
 mealies Borekit Bruiser
| dan0h |
 dan0h Two Stroke Sniffer
| c clarke |
 c clarke Borekit Bruiser
 Posted: 12:26 - 31 May 2011 Post subject: |
the wheel bearings might off gone, if this wobbling keeps happening get it serviced asap  ____________________ cclarke |
 Posted: 12:31 - 31 May 2011 Post subject: |
Might be worth getting an experienced rider to have a wee go on your bike just to check it's all as it should be.
It's often just confidence and someone telling you there's definately nothing wrong with the bike can be enough to give you that extra bit of confidence.
Also keep your head up and look at where you're going. The clutch lever and throttle are in the same place they were last time you looked. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| dan0h |
| mealies |
| Teflon-Mike |
 Posted: 13:55 - 31 May 2011 Post subject: |
RELAX...
You're over thinking what you are doing.... brain's going TOO fast... Bike's going TOO slow!
what's most likely happening, is you clunk away from a stand still.. each change of dynamic, like starting to move and balence shifting from your leg to bike, or as weight shifts as you put foot back on peg, as you tirn and steer and lean... every thing that causes a causing a 'change'.. you react to...
Brain in hyper drive over reacts... causing yet ANOTHER change.... and you are into a possitive feed-back loop of wobbling, over reacting to the wobble, causing more wobble etc etc etc.....
Relax... LET it wobble.... it WILL sort itself out.... go faster, think less.....
It will get better! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| FirebladeRuss |
 FirebladeRuss Spanner Monkey
| shereen |
 shereen World Chat Champion
 Posted: 08:08 - 01 Jun 2011 Post subject: |
Just a thought but how fast are you bringing your legs up after pulling away? I used to bring them straight up after pulling away which used to make me wobble a bit.  ____________________ "The Internet is the first thing that humanity has built that humanity doesn't understand, the largest experiment in anarchy that we have ever had" |
| binge |
 binge Emo Kiddy
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 08:36 - 01 Jun 2011 Post subject: |
When approaching a junction/lights that you're going to stop at, transfer the last of the braking from the front to the rear brake. The front forks will uncompress and stop the last second pogo, and you'll feel much smoother. Same applies in slow moving traffic, keeping some light pressure on the rear brake reduces any jerkiness in your throttle/clutch control. Hie thee to an empty car park, and see how slowly you can ride around it, it's only a matter of practice and confidence.
Also, check your steering head bearings - with the bike on the centre stand (hope it has one ) put some weight on the back so that the front wheel leaves the floor, then check that the bars move smoothly and freely left to right. They should be able to fall to the stops of their own accord. If there's any notchiness or sticking that might be the cause of your wobbling. [edit] wot Binge said as I was typing  ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| mealies |
| blurredman |
 Posted: 12:22 - 01 Jun 2011 Post subject: |
I still have difficulty sometimes when at junctions.
The other day, I was at a tricky sharp junction and waited for a car to go past.
Then I went, I saw this old woman looking at me on the pavement opposit.
From there, I was pulling out, juddering with crap clutch control and fixated on her. Just managed to keep the bike from stalling and got away fine. Damn you woman! ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 51k. |
| l0p0l |
 l0p0l Two Stroke Sniffer
 Posted: 15:28 - 01 Jun 2011 Post subject: |
Good old junctions !! I was very close to dropping my bike a few weekends ago while on my way to get it serviced.
I was travelling down a country lane and came to a particular bad junction which is nastily placed on the brow of a hill. "I was turning left".
Rushing and not watching where I was going I moved over to the left, handle bars turned, looked, car coming so I kick it into first and stopped rather quickly.
As my foot reached for the floor that wasnt there, the bike was almost right over. Stuck on this bloody hill, still in 1st and holding the clutch and bike for dear life I stayed in this position thinking of my next move. Due to the terrible camber of this hill I was not tall enough to right the bike, what felt like hours (it was a about a minute) I turned off the bike and dug my knee under the tank to stop if falling any further holding the bike on its back break.
Red faced and cars building up behind me I waited for my loving girlfriend to realise I was not getting this bike back up on my own to come to the rescue.
Lessons learned !
1. Dont go that way again ... (Joking)
2. Slow down, make sure your upright when approching junctions and in the correct gear.
3. Take a spare set of pants everywhere you go ____________________ Kawasaki ER6n
Looking for 60's BSA / Triumph project |
| pork6156 |
 pork6156 Renault 5 Driver
| Teflon-Mike |
| Hyaon |
 Hyaon Traffic Copper
| jrolph94 |
 jrolph94 Two Stroke Sniffer
| Slacker24seve... |
 Slacker24seve... World Chat Champion
| shereen |
The last post was made 14 years, 289 days ago. Instead of replying here, would creating a new thread be more useful? |
