really wobbly whilst riding
mealies
PostPosted: 12:05 - 31 May 2011    Post subject: really wobbly whilst riding Reply with quote
I have had my bike 12 weeks now and whilst my general riding is getting better one thing that keeps happening is that i start to get a wobble on, usually when i am coming up to or leaving junctions. Not sure if it is me or the bike causing it (i assume me).
I have been unable to ride due to illness for the last 6 weeks and when i got back on this weekend it was like i had forgotten how to ride. i was wobbling all over the place. I've been told that i would find it easier on a bigger bike but i want to be able to ride my 125 properly before i get my full license.
i checked my tyre pressures and backs were spot on but the front was 5psi over - would this be the cause?
Andrew
dan0h
PostPosted: 12:26 - 31 May 2011    Post subject: Reply with quote
I found I was like that initially on CBT, but my instructor suggest that at junctions or in traffic, to just hang back from pulling off for a few seconds so that when you do start to move you can do it a little more quickly, the faster you get over 5mph, the quicker you gain your balance.
Its just practice I think - though check both your wheels for any hint of side play, as knackered bearings will send you all over the show!
CBT: 9/5/11 (PASS) - THEORY: 15/6/11 (BOOKED) - MOD1: ?? - MOD2: ??
Commute weapon: 2008 Derbi Mulhacen 125 (3/6/11)
c clarke
the wheel bearings might off gone, if this wobbling keeps happening get it serviced asap Thumbs Up
cclarke
PostPosted: 12:31 - 31 May 2011    Post subject: Reply with quote
Might be worth getting an experienced rider to have a wee go on your bike just to check it's all as it should be.
It's often just confidence and someone telling you there's definately nothing wrong with the bike can be enough to give you that extra bit of confidence.
Also keep your head up and look at where you're going. The clutch lever and throttle are in the same place they were last time you looked.
dan0h
PostPosted: 12:34 - 31 May 2011    Post subject: Reply with quote
Haha! Thats exactly my problem, watching the controls, though thankfully I'm starting to shake that habit off now!
Just read your around the UK blog, awesome work that man, nicely done!
mealies
PostPosted: 12:41 - 31 May 2011    Post subject: Reply with quote
yeah i think it's just a confidence thing - and not keeping my head up enough.
I am going to be getting my bike serviced this week. I am a little suspicious as I went to renew the tax disc and the dvla are saying my bike has been untaxed since before i bought it. so am taking it to another shop just to have it checked out.
Teflon-Mike
tl;dr
PostPosted: 13:55 - 31 May 2011    Post subject: Reply with quote
RELAX...
You're over thinking what you are doing.... brain's going TOO fast... Bike's going TOO slow!
what's most likely happening, is you clunk away from a stand still.. each change of dynamic, like starting to move and balence shifting from your leg to bike, or as weight shifts as you put foot back on peg, as you tirn and steer and lean... every thing that causes a causing a 'change'.. you react to...
Brain in hyper drive over reacts... causing yet ANOTHER change.... and you are into a possitive feed-back loop of wobbling, over reacting to the wobble, causing more wobble etc etc etc.....
Relax... LET it wobble.... it WILL sort itself out.... go faster, think less.....
It will get better!
FirebladeRuss
PostPosted: 14:54 - 31 May 2011    Post subject: Reply with quote
THe point about wheel bearings is a valid one.
Mine had a shot front wheel bearing, and I too had that 'wobbly' feeling until it was changed - and even though the play was barely noticeable when wobbling the wheel by hand, with new bearings it feels much nicer.
Twitter is for people who can't STFU even when they're by themselves
shereen
PostPosted: 08:08 - 01 Jun 2011    Post subject: Reply with quote
Just a thought but how fast are you bringing your legs up after pulling away? I used to bring them straight up after pulling away which used to make me wobble a bit. Rolling Eyes
binge
Emo Kiddy
PostPosted: 08:30 - 01 Jun 2011    Post subject: Reply with quote
Headstock bearings can be another cause for this.
Somebody experienced will tell you. A good way to check will be to put the bike on the center stand, get somebody to push down on the rear seat to hold the front wheel off the ground.
And then check if the steering is loose, or notchy.
Ben
PostPosted: 08:36 - 01 Jun 2011    Post subject: Reply with quote
When approaching a junction/lights that you're going to stop at, transfer the last of the braking from the front to the rear brake. The front forks will uncompress and stop the last second pogo, and you'll feel much smoother. Same applies in slow moving traffic, keeping some light pressure on the rear brake reduces any jerkiness in your throttle/clutch control. Hie thee to an empty car park, and see how slowly you can ride around it, it's only a matter of practice and confidence.
Also, check your steering head bearings - with the bike on the centre stand (hope it has one Smile ) put some weight on the back so that the front wheel leaves the floor, then check that the bars move smoothly and freely left to right. They should be able to fall to the stops of their own accord. If there's any notchiness or sticking that might be the cause of your wobbling. [edit] wot Binge said as I was typing Smile
mealies
PostPosted: 11:41 - 01 Jun 2011    Post subject: Reply with quote
cheers for the advice - will check the bearings tonight.
I think Teflon-Mike is right in that i maybe over-thinking this and just need to chillax and just ride it.
Andrew
blurredman
PostPosted: 12:22 - 01 Jun 2011    Post subject: Reply with quote
I still have difficulty sometimes when at junctions.
The other day, I was at a tricky sharp junction and waited for a car to go past.
Then I went, I saw this old woman looking at me on the pavement opposit.
From there, I was pulling out, juddering with crap clutch control and fixated on her. Just managed to keep the bike from stalling and got away fine. Damn you woman!
l0p0l
PostPosted: 15:28 - 01 Jun 2011    Post subject: Reply with quote
Good old junctions !! I was very close to dropping my bike a few weekends ago while on my way to get it serviced.
I was travelling down a country lane and came to a particular bad junction which is nastily placed on the brow of a hill. "I was turning left".
Rushing and not watching where I was going I moved over to the left, handle bars turned, looked, car coming so I kick it into first and stopped rather quickly.
As my foot reached for the floor that wasnt there, the bike was almost right over. Stuck on this bloody hill, still in 1st and holding the clutch and bike for dear life I stayed in this position thinking of my next move. Due to the terrible camber of this hill I was not tall enough to right the bike, what felt like hours (it was a about a minute) I turned off the bike and dug my knee under the tank to stop if falling any further holding the bike on its back break.
Red faced and cars building up behind me I waited for my loving girlfriend to realise I was not getting this bike back up on my own to come to the rescue. Embarassed
Lessons learned !
1. Dont go that way again ... (Joking)
2. Slow down, make sure your upright when approching junctions and in the correct gear.
3. Take a spare set of pants everywhere you go
Kawasaki ER6n
Looking for 60's BSA / Triumph project
pork6156
PostPosted: 12:29 - 02 Jun 2011    Post subject: Reply with quote
I would have to agree with teflon mike.
It sounds like you really need to relax on the bike, I bet you are as stiff as a board, when your stiff your movements will be stiff, that will filter down through the bars making everything more jerky.
If the bike wobbles don't tense up, it will make it worse, as teflon says, let it wobble ride it out, the more you do that the more you will relax, end result no wobble.
Teflon-Mike
tl;dr
PostPosted: 14:00 - 02 Jun 2011    Post subject: Reply with quote
I just thought.... you told me you had NO wobbly bits!
Hyaon
PostPosted: 15:02 - 02 Jun 2011    Post subject: Reply with quote
I have my suspicions why this is happening...
Mod2 Passed 30/03/2011!
CBF125>GSF650 Bandit K8>B-King 2008+R1 2002
jrolph94
PostPosted: 11:43 - 04 Jun 2011    Post subject: Reply with quote
Are you looking down/ the road close to the front of the bike. This may be the cause. Make sure you are looking ahead.
Slacker24seve...
PostPosted: 10:28 - 05 Jun 2011    Post subject: Reply with quote
Even more than that, look where you want to go Cool
Banger rallies are ace
shereen
PostPosted: 10:32 - 05 Jun 2011    Post subject: Reply with quote
Damn - you got me!! Cool
The last post was made 14 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 112.86 Kb
