How would you remove this, and how do you fit dust covers?
hazza
PostPosted: 19:51 - 31 May 2011    Post subject: How would you remove this, and how do you fit dust covers? Reply with quote
Hi,
First off, is this dent fillable?
https://i1239.photobucket.com/albums/ff501/harrybarfield/photo-7.jpg
or would i need to pop it out some how? how would i do this?
also the dust overs on the forks are shot. The seals dont leak at all so im not going top mess with them. am i right in thinking i just need to prop the bike up (el250) and undo the bolts holding the stanchions on and slide them down in order to remove the old covers and just pop in the new ones?
Thanks in advance!
H
PostPosted: 19:54 - 31 May 2011    Post subject: Reply with quote
Nah, you can pop that out.
Leave a little fuel in the bottom, chuck a lit match in, and jam your hand over the filler. During the resulting explosion if your tank isn't blown into several pieces the expansion of the gas inside will force the dent out.
(Just fill it, or pull it out.)
hazza
PostPosted: 19:58 - 31 May 2011    Post subject: Reply with quote
cheers! how could i pop it out?
Ive filled bigger dents on cars in the past (girlfriend likes to crash alot) but was just worried as its a bit of an awkward position!
Bloggsy
PostPosted: 20:20 - 31 May 2011    Post subject: Reply with quote
Take it to a car dent removable expert
hazza
PostPosted: 20:24 - 31 May 2011    Post subject: Reply with quote
How can i remove it spending very little money, Im skint and im doing this project on the cheap!
PostPosted: 20:28 - 31 May 2011    Post subject: Reply with quote
Best way would be to push it out of course.
Kind of tricky on a tank since you can't get to the inside of it that well. You could try and pull it out, but that's more of a pros only kind of thing.
Google is your friend if you fancy giving it a whirl.
Nexus Icon
PostPosted: 21:19 - 31 May 2011    Post subject: Reply with quote
It looks like it has a crease in the middle of the dent, or is that just the light deceiving me?
If it's creased it's going to need filling to finish it anyway so you might as well stick a long bar in through the filler and bash it against the inside of the dent and finish it with filler.
If it's not creased, pressurising the tank 'might' blow it out but you'll get better results emptying and clearing the tank of fuel vapours, welding a stick to the middle of the dent on the outside, pulling out the dent and then grinding off the weld and finishing the metal back to smooth before repainting.
Greetings from Shitsville!
hazza
PostPosted: 20:29 - 01 Jun 2011    Post subject: Reply with quote
Hi,
No its not creased, thats just the crappy iPhone camera decieving you! I think for all the fuss, ill take you advice and just fill the bugger!
Thanks Guys.
The last post was made 15 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 60.71 Kb
