Help !! Rieju RS1 Evolution
drumaboi628
PostPosted: 03:01 - 01 Jun 2011    Post subject: Help !! Rieju RS1 Evolution Reply with quote
Does anyone own a 2001 Rieju RS1 Evolution? 49cc motor.
I just bought the bike, used with 1800 miles. When i first tested it out at the sellers place, the bike was fine. But after bringing it back and have given it a few rides, the bike wouldn't start.
Can it be the fact that i have pulled the choke too many time causing it to flood? If so, what should i do?
Also, when i looked in the coolant tank, it was empty. Would that be the cause?
Does anyone know what kind of coolant i should use?
SORRY, TOTAL NOOB HERE! IM ABOUT TO GET FLAMED!
but if that what it takes to get answers, please do so!
Chi L
drumaboi628
PostPosted: 15:20 - 01 Jun 2011    Post subject: Reply with quote
rob yarrr wrote:
why would you get flamed :S?
you've probs Fouled the plug from running it on choke,get a new un'
fill the coolant up to the level,for some reason people cba filling it up ¬_¬
Hey, thanks for the advice. I will try that today.
I don't know. Usually when you are new to a forum, they would find any reasons to flame on you. BUT I GUESS WRONG!
THANKS!!!!
Chi L
drumaboi628
PostPosted: 03:40 - 02 Jun 2011    Post subject: Reply with quote
Update....
I tried starting it this morning and it started with no problem at all. I guess i did flood the engine, but leaving it over night without touching it solves the problem.
BUT.... now i have another problem...
The attached photo, i have circled in yellow the area that I'm having problems with.
Just right below the circled area, on the ground, i noticed there is a QUARTER size black liquid present after being left over night.
Does anyone know what that might be? Crying or Very sad
sigh, i spent $1400 on this and im troubles already.
Chi L
GREENI3
PostPosted: 11:20 - 02 Jun 2011    Post subject: Reply with quote
Thats just carbon deposits leaking from the exhaust. (oil + water mixture)
Same thing happens to mine at the exhaust header.
Nothing much to worry about, but if it bothers you that much look for a hole on the exhaust and if there is one get it welded up or buy a new exhaust.
drumaboi628
PostPosted: 20:15 - 03 Jun 2011    Post subject: Reply with quote
Thanks guys!!!!!
Chi L
drumaboi628
PostPosted: 06:28 - 08 Jun 2011    Post subject: Reply with quote
Once again, i have problems again. Sad
2001 RIEJU RS1
So i took my bike out around 7:30pm today. It was flaming hot today hence i took it out later in the day.
Every time i come to a stop sign or light and have the bike on Neutral, the bike dies after 5-10 seconds sitting there waiting for it to go green.
(we took a break from 8:45-9:05 and stopped by a friends place, then took off around 9:08)
Then around 9:18pm when i started riding again, when my bike is in gear and accelerating, my bike totally shut down. The bike wouldn't start. Let it sit for a good 5 minutes, started it up by giving it a little throttle, BUT COULDN'T stay running.
Since WE are in the middle of nowhere, the only way to get it back to my house was to keep giving it throttle. On a long run down the street, the bike seems to be fine, but once i decelerate, it start to feel that its going to die, so i kept giving it some throttle and kept doing that until i got home. (DIED TWICE AT A LIGHT)
This is what i noticed:
When it died the first time, the fuel light started blinking.
(Yes i do have fuel in the tank, just filled it up a day ago, but could it be that I bought regular fuel from BP?)
The motor itself is hot.
The Radiator is extremely hot. (Yes there is coolant in there, but never changed it when i bought it a week ago)
THE ONLY THINGS I'VE DONE TO IT WHEN I BOUGHT IT HOME IS CHANGED THE SPARK PLUG, CLEANED THE CARBURETOR AND ADDED SOME REGULAR FUEL FROM BP.
Can someone tell me what should i do besides getting rid of it? Sad Sad Sad Sad Sad Sad Sad Sad Sad Sad Sad Sad
THANKS IN ADVANCE!
Chi L
serlant
PostPosted: 08:17 - 08 Jun 2011    Post subject: Reply with quote
May sound silly but i had this exact problem on my 125, and it was because i left the choke, on, so first thing I would check is you didn't leave the choke on and that it retracts properly
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
drumaboi628
PostPosted: 14:40 - 08 Jun 2011    Post subject: Reply with quote
Hi thanks for replying.
What do you mean you left it on?
Mine is a retractable choke, so the minute i let go of it, it should close.
BUT i will double check on that....!!
any other ideas guys?! Any would help!
Chi L
the95th
PostPosted: 17:28 - 08 Jun 2011    Post subject: Reply with quote
Not all chokes are retractable, might get stuck on, Often have the same problem on my 125.
check the fuel line is actually feeding petrol into the carbs, check the carbs over from where you cleaned you may not of adjusted them correctly.
2004 Rieju Rs2 Matrix 50cc, 1982 Honda CG125, 1986 Honda Cm125, 1982 Honda Cb125..... I kill a lot of 125's
drumaboi628
PostPosted: 05:28 - 09 Jun 2011    Post subject: Reply with quote
Thanks for the info!
I will definitely give it a full check up this week. It's going to rain for the next couple of days! Sad
But in terms of the radiator, do you guys think there's something wrong with it? Would you recommend changing it?
Thanks
Chi L
skatefreak
PostPosted: 09:30 - 09 Jun 2011    Post subject: Reply with quote
Hey,
I know this is probably glaringly obvious but it had'nt been mentioned sooo....
You are putting two stroke oil in it yes?
The bike in the pictures is a 2 stroke and once it runs out of 2T oil the engine will eat itself and you havnt mentioned anything soo.. yeah.
Hope so.
Best regards
-Jvr
the95th
PostPosted: 13:55 - 09 Jun 2011    Post subject: Reply with quote
I have an rieju Rs2 matrix sitting in my garden, was supposed to rebuild it for my girlfriend, but she lost interest when she lost a nail. and i decided i might as well fix it up and sell it for another new bike...... Anyway, i used it for about 2 years as a run about commuter, and never had a single problem with the radiator. the only problem i could think you might have with it is, its out of coolant, in which just top it up, if you dont have coolant, use some water, it will do till you get coolant.
Its either the choke being gay. ( Take it off completely, and try it)
The carbs not being adjusted to the correct settings. ( I have a cb125 and i need to do it constantly)
The fuel line is blocked by crap. ( have you ran the petrol tank down low, in the last few weeks?) If not, just hop onto ebay and buy like a 6mm fuel pipe hose and replace it.
If their is a fuel line filter from the tank, remove it. Might be starving the engine. My RS2 didnt like having a filter i popped one in it to help keep the engine clean etc. for when i wanted to sell it, and it choked a lot.
Is their a hole in your exhaust? (Other then the big one at the end thats supposed to be there, and the smaller one at the front were its supposed to be there.)
A hole in your exhaust will lead to a loss in backpressure and your little 50 will choke on its own farts.
Your carbs may be blocked further from you cleaning them, might of dislodged some sealer.
Or the gaskets may be damaged.
All else fails..... back up plan:
TOP HER UP WITH CASTROL TWO STROKE. £12 a bottle, do a full oil change. pop in a brand new irdium NGK spark plug, do a spark test, unplug the NGK lead ( should be at the top of the 50 engine, underneithe the petrol tank) and pop a long screwdriver in the lead cap were it touches the coil. put the screwdriver shaft near the frame ( about 2 millimeters away) and see if the spark is a strong blue electric jump.
( i know people dont like them, but the fact they are the most expensive spark plugs means, you know they are good and wont be crap sparks)
Redex. (£10) ( only put a little bit in your tank about 10 millilitres.
this will clear out your engine completely. Now be wary, when you take it for a test ride youll have a MASSIVE boost in power. So just be careful
( it wont be massive, i just used that word so you notice, it will probably jump about 10mph very very quickly then burn out)
So if the home fixes dont work. £30. will.
drumaboi628
PostPosted: 23:41 - 09 Jun 2011    Post subject: Reply with quote
Thanks everyone for replying back...
Yes, there is two stroke oil in it.
I am fairly new to this motorcycle stuff and have plenty to learn so i will take your info and try to break it down before i do anything.
Thanks and i will keep you guys updated.
Chi L
The last post was made 14 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 92.54 Kb
