| cmorris0 |
 cmorris0 L Plate Warrior
| stinkwheel |
 Posted: 14:47 - 01 Jun 2011 Post subject: |
If you can post the picture, someone should be able to tell you what they're called.
Once you know what they're called, your best bet would be to call david silver spares, if they can't get them, you're going to struggle. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| cmorris0 |
| stinkwheel |
 Posted: 15:50 - 01 Jun 2011 Post subject: |
The 10mm sealing washers?
Honda Part number: 90403ML4610 at position 19 on the diagram you linked to?
David silvers have one in stock ready for dispatch. You'd need to give them a call to see if they could get another one in: https://www.davidsilverspares.co.uk/parts/by-part-number/partnumber_12724/
A google for the part numbershows they are also used on the rocker cover of the VT1100. Lings Honda shows a lead time of 3 days @ £3.98 each.
Since it's used on a 1997 bike, I'd expect any honda dealers to be able to get them in if you just ask for the part number. From previous experience, it's probably best to just ask for the part number. If you mention it's for an old superdream they'll just suck their teeth and claim the part is no longer available without even looking. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| cmorris0 |
| stinkwheel |
| Carvel |
 Carvel World Chat Champion
 Posted: 19:19 - 01 Jun 2011 Post subject: |
Are you on about the rubber inserts that the bolt sits on?
https://i979.photobucket.com/albums/ae271/RxsOllie/SNC00161.jpg
The bit under the washer?
Both of mine leak  ____________________ 2002 Aprilia RSV1000R, Cbr600Fs, Mk1 B12, Vfr400 NC30...
Matt B: I can deal with crushed nuts to beat Ollie. |
| cmorris0 |
| Bias69 |
 Bias69 L Plate Warrior
 Posted: 10:38 - 03 Jun 2011 Post subject: Rubber seals |
the only rubber seals on the Superdream that are anywhere near those bolts are the ones that sit on the outer rear bolts that feed oil to the topend.
Ive got mine in bits at the moment and can only see 2 rubber seals and they are between the barrels and the cylinder head on the rear outer bolts
https://www.cmsnl.com/honda-cb250nb-1981-england_model15821/partslist/E03.html
part number 4 is what I reckon your after. |
| cmorris0 |
 Posted: 10:51 - 03 Jun 2011 Post subject: |
| Bias69 |
| cmorris0 |
| paddlesat16 |
 paddlesat16 Crazy Courier
| bigegg |
 bigegg L Plate Warrior
The last post was made 15 years, 130 days ago. Instead of replying here, would creating a new thread be more useful? |
