Yamaha Neos 50 - won't start :-(
grantp
PostPosted: 06:32 - 03 Jun 2011    Post subject: Yamaha Neos 50 - won't start :-( Reply with quote
Was going along the other day, it lost all power, when I applied any throttle it just seemed to die and after about 10 seconds of rolling it died. I tried to start it and then all I heard was a bang out the exhaust (backfire) and now it hasnt started since, It had fuel in and had a full tank of castrol 2t oil..
I ran out of petrol the other week and I took the carb apart and cleaned it 'cos i had sucked all the debris and stuff through.
Had a few mates round to see if we could get it started last night, its got a spark. Theres fuel going to the carb not sure about to the engine..
Anyone shed any light as to what it could be?
Edit : my kick start is also grinding as I kick it, sounds really bad.. doesnt spring back up either..?
Livefast123
PostPosted: 10:04 - 03 Jun 2011    Post subject: Reply with quote
Does your engine turn over when you hit the electric start?
Current ride - Yamaha MT-07
GREENI3
PostPosted: 12:13 - 03 Jun 2011    Post subject: Reply with quote
Could be your carb again. Maybe flooding, check the float height or the float needle is worn or stuck causing TOO MUCH fuel to enter the float chamber.
Before that I would check the simple stuff like fuses, battery and the rest.
As for the kickstart, get your drive belt cover off and take a look at the teeth on the kickstart quadrant and engaging pinion.
If all is good, put a bit of 3 in 1 all over them and this should give it a smoother action as you kick it and should spring back again.
cb1rocket
PostPosted: 13:55 - 03 Jun 2011    Post subject: Reply with quote
do you have any compression for a start? If its grinding, then its possible the piston has shattered itself and blown up. Full top end rebuild me thinks.
Gazdaman
I did a trackday!!!
PostPosted: 15:27 - 03 Jun 2011    Post subject: Reply with quote
I second that.
Get a someone to do a compression test on it. You need a special tool (but it's pretty cheap) to test compression. Screw it into the spark plug hole and kick the engine over. See what reading you get.
My guess you get pretty much nothing and it'll need a top end rebuild (which is pretty cheap, I paid £50 for a barrel and piston for an Aerox (same engine)).
Gaz
grantp
PostPosted: 04:18 - 05 Jun 2011    Post subject: Reply with quote
Not had a compression test but stuck my hand over spark plug hole and its blowing my hand so i'm sure it isn't a compression issue..
Gazdaman
I did a trackday!!!
PostPosted: 08:32 - 05 Jun 2011    Post subject: Reply with quote
Well that's a compression problem ruled out then!
Do a proper compression test. It doesn't have to be down by much to stop it running. The tester isn't very expensive, I think I paid less than £20 including postage for mine, and it's been great for diagnosing faulty bikes and cars.
Gaz
AmirasDaddy
PostPosted: 09:12 - 05 Jun 2011    Post subject: Reply with quote
I had a similar problem on my vivacity, turned out to be a wire break in the immobilizer antenna. the back fire was due to flooding of the carb.
worth check I replaced my antenna and it works.
grantp
PostPosted: 01:00 - 06 Jun 2011    Post subject: Reply with quote
this would make sense, I took the carb apart to clean the jets. I must of not put it back together properly, getting up early to try and sort it out as I need the moped to get to work :/
grantp
PostPosted: 21:24 - 06 Jun 2011    Post subject: Reply with quote
Problem solved Very Happy it's being sold tomorrow! still not running but it's gonna be someone elses problem now, can't be bothered with it!
The last post was made 15 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 64.83 Kb
