Honda Bonus choke madness.
Visitor Q
$25 whore
PostPosted: 14:01 - 05 Jun 2011    Post subject: Honda Bonus choke madness. Reply with quote
Right, so I have one of these;
https://a4.sphotos.ak.fbcdn.net/hphotos-ak-snc6/248447_10150609882175545_538730544_18455819_8267551_n.jpg
I've been fettling with it continuously and now it's actually running/riding really well...
Until yesterday, where it developed the need to be kicked about 10 times before it caught. I went to go have a look today and the bastard wouldn't start at all.
Got the plug out, jet black but a good spark. Electric starter wouldn't even spin the engine, and bumping didn't work. Cleaned off the plug and reset the gap a bit closer so it sparked well (being kicked). Still think it needs a new battery, but after some cleaning of all the points I go it started today.
One thing that seems to be the main issue is the choke assembly, or rather, I'm not sure which position the choke is off. I've been experimenting and fully up/fully down seemed to work best. But after fouling the plug I was obviously wrong.
Today it would only start in the middle (after messing about for an hour). Seems to be a vane between carb and airbox (will clean out/check airbox tomorrow) but was curious if anyone knew how this arcane bastard works?
https://www.bikechatforums.com/download.php?id=79070
Also, the cable and block to the left of the picture are attached to what /should/ be the choke lever, but obviously at the moment it's flapping loose. It doesn't fit into the choke lever at present, and the little dowel inside wouldn't fit the gap in the lever anyway... Thinking
Also, this is the first bike I've had with a manly kick start. Trying to pre-compress (or whatever it's called) with one slow steady push followed by a proper kick, it stops halfway sometimes and kicks back like a cunt. Does that just mean really good compression, or something I should be worried about?
If someone can find out the microfiches for this I'd be grateful. Or where I can find some info on the bike to help the search?
Nexus Icon
PostPosted: 14:08 - 05 Jun 2011    Post subject: Reply with quote
Fully up closes the butterfly completely and you'd really only need that for starting on a pretty cold day. Middle position should start it most days and can be left there for fist couple of minutes riding. Fully down opens the choke right up and is the normal warm start/running position.
If the plug is really sooty it suggests it's running rich and ergo you riding with the choke closed to some degree.
Greetings from Shitsville!
Visitor Q
$25 whore
PostPosted: 14:14 - 05 Jun 2011    Post subject: Reply with quote
Cheers fella.
Idle speed barely changes for some reason, and I'm in Vietnam so theres no such thing as a cold start. Weird that it's having such a marked effect Thinking
Will try to find the idle screw tomorrow as well.
Any good ways to test how much poke/life is left in a battery? It sparks a bridging screwdriver, and the lights will come on with just the ignition on but not running... but it won't turn over now (with button). I've had shitty 125's 4t's I've run without batteries before, just using kick, so I know they're not that important....
And what is the bit called that charges the battery. Because that could be the issue, not the battery Thinking
In a perverse way, I've missed this kind of irritation Laughing
Visitor Q
$25 whore
PostPosted: 14:19 - 05 Jun 2011    Post subject: Reply with quote
Also, please idiot friendly 'fully up' for me.
If the lever is fully up, than the actuator is fully down, so I'd guess the butterfly would be fully closed. But I'm not sure whether it is mounted inline or perpendicular...
Nexus Icon
PostPosted: 14:24 - 05 Jun 2011    Post subject: Reply with quote
The lights will work when it's not running but won't work when it is? Does the battery recharge if you flatten it completely?
I'm not sure what charging system that has, although it looks like a generic Honda air-cooled 125 engine so is probably similar (if not identical) to a 90s CG.
Visitor Q
$25 whore
PostPosted: 14:35 - 05 Jun 2011    Post subject: Reply with quote
This may help;
https://cdn.bikechatforums.com/files/sdc11002.jpg
I don't think it's standard, I've never been on a 125 with so much poke... although it only has 4 gears I suppose.
The lights just always work it seems, but the starter used to occasionally work. Or would at least turn the engine, even if it only caught when warm.
Could be the battery isn't holding a charge. I think I can replace it for 6 quid, so will probably do that tomorrow and give that a go.
Nexus Icon
PostPosted: 14:43 - 05 Jun 2011    Post subject: Reply with quote
It actually looks spookily like my old '77 CG under the plastic. That was fast, for a 125. It was certainly quicker than my mates on their RG125, AR125 and GP100. Only the guy with the GP had taken pains to try and derestrict it though.
Nexus Icon
PostPosted: 15:12 - 05 Jun 2011    Post subject: Reply with quote
Ahh, that makes sense. It has been 24 years since I owned the CG!
PostPosted: 15:22 - 05 Jun 2011    Post subject: Reply with quote
rob yarrr wrote:
its got a xl engine or something
cam chain,not push rod like the cg Thumbs Up
Quite possible, with 4 gears rather than the XL125's 5 gear setup.
Looks "fairly" similar to my CLR which is from an XL125r
Nexus Icon
PostPosted: 15:36 - 05 Jun 2011    Post subject: Reply with quote
But my old CG had a 4 speed box...
Perhaps it's something cobbled together from the parts bin.
Visitor Q
$25 whore
PostPosted: 16:33 - 06 Jun 2011    Post subject: Reply with quote
Ooooh, god this thing is irritating sometimes.
Spent yesterday checking contacts etc, got it started. Today, cleaned out the airbox (removing the wad of bubblewrap blocking one inlet, and all the sand inside the box) and made it spangly.
Got it so that it started with the gentlest of wafts near the kickstart... even the battery charged up enough to start on the button.
Took a friend to the shops, and even she noticed how great it was running. Parked it in the sweatbox dungeon and went shopping. By the time I'd come out, it had cooked it's ECU/Reg (not sure which, the bastard that controls the spark directly), and now I'm going to have to pay $30 for a new one. Sad times.
How the hell does that even happen Crying or Very sad Everyone is besmerching my good bike. How dare they...
The last post was made 15 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 83.64 Kb
