CB500 Won't Start..Please Help!
rudeboy99999
PostPosted: 17:12 - 05 Jun 2011    Post subject: CB500 Won't Start..Please Help! Reply with quote
Hi, today i brought a CB500 from a local seller.
when i viewed the bike it had a cold engine and started on the first attempt
after getting it home shortly after and putting some petrol in it.. it simply wont start!
the starter motor makes a clicky whirly sound like it is trying to start it but nothing...it occasioanlly bangs or pops from the exhaust but doesnt start
i have tried using the choke and still nothing
the bike is in neutral with the lights for this and engine oil on as it should be.
all the lights work correctly
please help i dont know what to do Sad
Ingah
PostPosted: 17:34 - 05 Jun 2011    Post subject: Reply with quote
First thing i'd do is put the battery on charge. It's more than likely simply got insufficient power to get the engine started.
-- Ingah
Ariel Badger
PostPosted: 17:48 - 05 Jun 2011    Post subject: Reply with quote
Did your petrol come from the black pump?
rudeboy99999
PostPosted: 18:00 - 05 Jun 2011    Post subject: Reply with quote
no its regular petrol not diesel , i siphoned it from my other bike as not to waste it
i have the battery on charge currently leaving it overnight ready to try again in the morning but with it on the starter goes for it like the battery is giving sufficient power. it started fine with the same battery earlier today when i was viewing it :\
PostPosted: 18:03 - 05 Jun 2011    Post subject: Reply with quote
Probably syphoned a pile of crap out of the bottom if the tank. Drain your carbs and put fresh petrol in.
rudeboy99999
PostPosted: 18:35 - 05 Jun 2011    Post subject: cb500 Reply with quote
i think tomorrow morning if the battery doesnt start it im going to try drain my carb out although i don't really know how to do this
cb1rocket
PostPosted: 19:29 - 05 Jun 2011    Post subject: Reply with quote
theres a drain screw under the float bowls. Get the haynes, if you haven't and more so if you intend doing the service yourself. Its a good read and is useful experiance for when dealing with other bikes.
Slacker24seve...
PostPosted: 19:30 - 05 Jun 2011    Post subject: Reply with quote
My Hornet did the same thing when fuel wasn't getting through properly. Check the fuel tap, fuel lines and float bowls Wink
Banger rallies are ace
rudeboy99999
PostPosted: 22:09 - 05 Jun 2011    Post subject: Reply with quote
just read through the haynes manual but nothing seems to be relevent to my problem.. i guess i need to know what the specific problem is before referring to the book :\ thanks so far guys
AHurdwell
PostPosted: 20:16 - 07 Jun 2011    Post subject: Reply with quote
You do have the fuel tap to on don't you?
Left hand side, pointed down on a CB500.
If you're brum based and want a hand then give me a shout...
The last post was made 15 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.14 Sec - Server Load: 0.77 - MySQL Queries: 15 - Page Size: 61.92 Kb
