GSXR750 Temp/FI error
PostPosted: 19:21 - 06 Jun 2011    Post subject: GSXR750 Temp/FI error Reply with quote
Rolling Eyes We see rain, the bike dies.. .typical Laughing
Rained bad this morning.. bike was fine..Left work today, wasnt raining... all good.
Got about 50ft from my door and the weirdest jerking/popping noise happened.
Got to my door with clutch in... the temp shows around 80, which is fine, but it swaps itself for the letters FI every 2 seconds.. so 80 ... FI ... 80 ... FI Confused
It "fires" and pops ... ive got it running since, but now its just popping.
Had it looked at saturday morning, he said valves sound perfectly fine, chains a bit tight and fork is leaking but aside from that, the mechanic was cool with it.
Any idea wtf could have caused this?! I have to go to work tomorrow Laughing
UKRedwing
PostPosted: 19:41 - 06 Jun 2011    Post subject: Reply with quote
Problem with fuel injection.. get a proper dealer to check it out tbh
Pete.
PostPosted: 19:50 - 06 Jun 2011    Post subject: Reply with quote
Look for a plug with 2 wires going to it in the left of the tailpiece. Probably ha a rubber cap. Move it to where you can get at it without turning off the ignition (or carry a spare key). Next time you have a FI light use a paperclip to jumper these two wires and it will give you the fault code. You have to do it without turning the ignition off (though you can kill the engine) because the fault is cleared when you turn off the key.
a.k.a 'Geri'
waffles
PostPosted: 19:53 - 06 Jun 2011    Post subject: Reply with quote
Fault codes
C14 - THROTTLE POSITION SENSOR
C15 - ENGINE COOLANT TEMPERATURE SENSOR
C21 - INTAKE AIR TEMPERATURE SENSOR
C22 - ATMOSPHERIC PRESSURE SENSOR
C23 - TIPOVER SENSOR
C24 - IGNITION SIGNAL #1
C25 - IGNITION SIGNAL #2
C26 - IGNITION SIGNAL #3
C27 - IGNITION SIGNAL #4
C28 - SECONDARY THROTTLE VALVE ACTUATOR
C29 - SECONDARY THROTTLE POSITION SENSOR
C30 - SECONDARY THROTTLE CONTROL UNIT
C31 - GEAR POSITION SENSOR
C32 - INJECTOR SIGNAL #1
C33 - INJECTOR SIGNAL #2
C34 - INJECTOR SIGNAL #3
C35 - INJECTOR SIGNAL #4
C41 - FUEL PUMP CONTROL SYSTEM
C42 - IGNITION SWITCH SIGNAL
C46 - EXHAUST CONTROL VALVE ACTUATOR (01-02 1000 and 06-07 600/750/1000 ONLY)
If you put it in dealer mode then it should tell you the fault code so you can work out whats screwed from that.
PostPosted: 20:25 - 06 Jun 2011    Post subject: Reply with quote
You dont say Laughing
Thanks guys, i'll attempt that... bike is chilling in the flat right now Shocked
Pete247
PostPosted: 20:35 - 06 Jun 2011    Post subject: Reply with quote
could be the SETT valve (think that is what its called) on the zorst. Attack it with some WD40 on the valve and tap it with a small hammer
PostPosted: 20:43 - 06 Jun 2011    Post subject: Reply with quote
C33 Rolling Eyes
Have removed and about to clean them... the connectors look all white and furry, with like "mould" looking stuff over them Laughing
My bedroom in the flat now looks like my dads garage...
Pete247
PostPosted: 22:14 - 06 Jun 2011    Post subject: Reply with quote
tis a common fault on the k6/k7 750, don't know about other models Smile
PostPosted: 00:51 - 07 Jun 2011    Post subject: Reply with quote
After a few hours of playing and using a toothbrush to clean various bits... she lives.
I'll give her a run tomorrow to work... gotta get her down 2 flights of stairs at 8am.. Laughing
PostPosted: 17:46 - 07 Jun 2011    Post subject: Reply with quote
Update - got to work fine.
Went on lunch, backfires like a mother bitch Laughing
Roll the throttle off at 4k.. pop pop pop Twisted Evil
Damn thing..
SirEdward
PostPosted: 20:46 - 11 Jun 2011    Post subject: Reply with quote
Had the same thing happen to me, FI cut off for a second during an overtake in 3rd at um, not 60 MPH. Shocked I've seen some shrooms in the circuitry in the tail. Smile
"Beyond a critical point within a finite space, freedom diminishes as numbers increase. This is as true of humans as it is of gas molecules in a sealed flask. The human question is not how many can possibly survive within the system, but what kind of existence is possible for those who so survive.
Pardot Kynes in "Appendix I: The Ecology of Dune""
The last post was made 15 years, 22 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 67.87 Kb
