How to stop 6v bulbs blowing?
SpannerMonkey
PostPosted: 13:29 - 07 Jun 2011    Post subject: How to stop 6v bulbs blowing? Reply with quote
So when I actually GET to ride my '72 pc50, I have this nasty habit of over-revving the engine some-what.
Being a 6v direct lighting system with no battery or fuses, every time I go downhill and do anything over 33mph-ish my back light will blow... which then leaves a heavy load on the headlight, which follows within the next 15 minutes.
I understand the theory that goes into engines really well... but I seriously struggle to comprehend electrics as I cant picture whats going on. So how the hell do I stop these lights from blowing? besides using less throttle Razz
Would a 6v battery wired between the power source (Dynamo? magneto? I dont even know what you call these things...) smooth out the current? Also maybe keep my lights brighter at low revs?
My bike? A YX140 powered one-off Monkey Bike, something a little different!
Willson
PostPosted: 13:34 - 07 Jun 2011    Post subject: Reply with quote
In short: No. Without a wiring diagram I couldn't say for certain, but there should be a Regulator/Rectifier between the alternator (correct?) and the rest of the electrical system which converts AC to DC (the Rectifier bit) and smooths out the voltage/current (The regulator bit). If that's not working correctly it could be the problem, but I have no knowledge of these bikes.
That's at least how I understand it.
Willson
Benson: Wouldn't life be easier if we were all turtles?
Me: Pig on bread = The way forward.
Riding: '00 Suzuki SV650S. Previous: '99 Kawasaki ER5 - sold, '02 Suzuki GZ125 Marauder - sold
PostPosted: 13:37 - 07 Jun 2011    Post subject: Reply with quote
It's probably running AC. (Confusingly the c90 runs both AC and DC through the rear bulb.)
I'm sure there is various ways (probably just a resistor in the right place, etc?) but I'm too rusty on such things to give good advice.
SpannerMonkey
PostPosted: 13:50 - 07 Jun 2011    Post subject: Reply with quote
I seem to remember it being 6v AC... I'll have a check when I get home and have my manual to hand.
PostPosted: 14:09 - 07 Jun 2011    Post subject: Reply with quote
Make sure you get a motorcycle specific bulb. They tend to have and extra "leg" supporting the filament. It might be vibration rather than overload that's making it blow.
Another option would be to fit a higher wattage bulb in either the front or rear light. They'll be more dim at lower revs but it's really just a position light anyway. I certainly wouldn't try riding inthe dark with it.
SpannerMonkey
PostPosted: 14:16 - 07 Jun 2011    Post subject: Reply with quote
I've ridden in the dark with an old CZ that had worse bulbs than the imagination can conjour.
The bulbs Im using are from the halfords motorcycle range, So pretty generic.
EDIT: Also, I dont remember the bike having a Reg/Rec anywhere.
kramdra
PostPosted: 15:04 - 07 Jun 2011    Post subject: Reply with quote
try fitting some small orings on the headlight mounting bolts. Stops all vibration. I went through 6 bulbs from november to feb, and havent used any more since.
Teflon-Mike
tl;dr
PostPosted: 16:39 - 07 Jun 2011    Post subject: Reply with quote
Vibration is a bulb killer, but 6v bulbs and direct lighting are notoriouse.
Old fasioned way of dealing with it was to fit lower wattage 12v bulbs.
Power = Current x Volts
Volts = Current x Resistance
So 15w 6v bulb, current would be 15/6.... call it 3 Amps. Resistance would then be 6/3 or 2 Ohms
A 15w 12v bulb, do the same you get 15/12 for 1.5A and Resistance 4 Ohms
So fit a 4Ohm 12v bulb to a 6v system, and it would draw, Volts / Resistance, 6/4 1.5Amps
So, Power = Volts x Amps, you'd get 6x1.5 or 9W from it instead of 15...
So you crunch some numbers to find out what 'sort' of 12v rating gives 'similar' lighting power...
Then you try it, and see how it works.... becouse often the 12v bulb at lower revs wont get enough juice to make it glow.... and you then go down a rating..... but, should find one that works acceptably, and that wont 'blow' when high revs over voltage is applied to it.
Alternatively..... yes, you want a little regulator circuit and battery, which can easily be wired up from components, and Maplins do some quite small, sealed lead acid 6v 'alarm' batteries that would do quite a nice job.....
HOWEVER...... your bike, PROBABLY has a regulator already..... and it's fucked!
6v direct systems often had a 'zenner diode' regulator. Its a diode working backwards, so it clips voltage over threshold, to prevent over volts... not very efficient, but they do work... and that's teh first place to look... do you have one? and is it working?
On Hondas often looks like a blade fuse in the headlamp, black, with a diode symbol on it ->|- if not, could be on the fork yoke or head stock, or under the ignition key, and possibly have a bit of heat sink around it.
If you dont have one, a 6V Zenner of suitable rating might be a solution, rather than full regulator circuit... and a nice descrete mod, it can be wired 'in line'... but, I think I'd go for a small sealed lead acid and a regulator circuit, hidden away somewhere, for 'reliable' lights for modern roads.
PostPosted: 16:54 - 07 Jun 2011    Post subject: Reply with quote
I think you overestimate the complexity of these bikes Mike.
It has a headlight and a tail light that run on single phase AC direct lighting. It's a 7 wire loom (see attached picture, that's ALL the wiring).
No brake light, no flashers. The speedo back light is cunningly arranged by having a hole in the headlight reflector directly under the speedo. Similar arrangement for the hi beam (to make laughing noises) warning light.
If you want to sound the horn at the same time as you have the lights on, you have to pretty much redline it.
I very much doubt there is any form of regulator at all. It produces about 5A top whack and that's AC output. Start trying to rectify it and you have no chance.
ThoughtContro...
PostPosted: 17:20 - 07 Jun 2011    Post subject: Reply with quote
If it's 6V AC that it's producing, then you can't wire a battery or capacitor to smooth out the voltage to the light. That nominal 6V is RMS BTW, the peak Voltage will be nearer 8.5V.
As mentioned, the best way is to upgrade the bulb to cope with any increased current at high speeds. You'd be best sticking a meter on the output to the light, and measuring it with the engine revving at the sort of rpm your getting when you're going downhill and blowing bulbs. Don't forget to switch your meter to AC tho, or you won't get an accurate reading.
Once you know what max voltage is the problem, then you can start messing around with equations to figure out what bulb you need (or suitable resistor if you can't find a bulb with the right rating.
Prize cunt
Teflon-Mike
tl;dr
Possibly Stink, hence suggestion to make regulator rather than use a Zenner.
@You Monkey: If you use a Zenner, it 'clips & dumps' the peaks of the AC voltage, so it wil lprotect the bulbs from over volts, but only at the expense of dumping useful power.
A four diode, bridge rectifier, would take ALL the AC power and turn it into DC. Putting that into a 6v battery, it would capture any excess the system MIGHT make during over voltage or when there's low or no load on the system, and make it available when the generators not delivering much.
Maplins, four 3A diodes, and a 6v alarm battery, be about a tenner....
ThoughtContro...
PostPosted: 17:46 - 07 Jun 2011    Post subject: Reply with quote
Mike, if you're using a Zener regulator you'll usually use a shunt resistor too, see https://www.reuk.co.uk/Zener-Diode-Voltage-Regulator.htm
It's not the most efficient way of doing things.
If you use a 4 diode bridge rectifier, then you'll drop around 0.6-0.7V across the diodes, so you'll lose about 1.4V max across each diode pair, during each half cycle.
Also if you'd be better using an electrolytic capacitor to smooth out the output from your bridge rectifier, since it's smaller lighter and cheaper than piddling about with the complication of extra batteries, if you want to do it that way.
Prize cunt
Teflon-Mike
tl;dr
PostPosted: 18:13 - 07 Jun 2011    Post subject: Reply with quote
I was thinking more along the lines that a lead acid would store charge long term, where a capacitor would just smooth the AC...
Hence using battery, riding in daylight, light's 'off' battery would charge. Night time, even at low revs, or engine off, charged battery would offer amps to keep lamps lit.
ThoughtContro...
PostPosted: 18:42 - 07 Jun 2011    Post subject: Reply with quote
Teflon-Mike wrote:
I was thinking more along the lines that a lead acid would store charge long term, where a capacitor would just smooth the DC...
Well it would work, so long as he's got somewhere neat to hide the battery and extra wiring (long wiring may cause a minor voltage drop too since any power loss is proportional to the square of the current, and a 6V system will use twice the current of a 12V system for the same wattage light).
The main drawbacks I can see is that to charge the extra battery at a suitable rate then the output from the bridge rectifier should be somewhere near 7V. If your diode pair on the bridge is dropping 1.2-1.4V, then you need the alternator to output 8.2-8.4V for a nice healthy charge. If it doesn't output anywhere near this then any charge will be a trickle rate, which isn't that useful. At night if the battery becomes flat then the alternator now has to try to charge the battery and supply the lights, which will likely lead to very dim lights.
Prize cunt
SpannerMonkey
PostPosted: 19:00 - 07 Jun 2011    Post subject: Reply with quote
Well it would work, so long as he's got somewhere neat to hide the battery and extra wiring Yes, I'm fitting a topbox to the bike =P which will be an almost permanent fit
The main drawbacks I can see is that to charge the extra battery at a suitable rate then the output from the bridge rectifier should be somewhere near 7V Well the bike is almost CONSTANTLY at high rpm as I ride along a lot of NSL, 50, 40 and 30 roads, surely this'd provide excess current?
Teflon-Mike
tl;dr
PostPosted: 19:15 - 07 Jun 2011    Post subject: Reply with quote
The main drawbacks I can see is that to charge the extra battery at a suitable rate then the output from the bridge rectifier should be somewhere near 7V Well the bike is almost CONSTANTLY at high rpm as I ride along a lot of NSL, 50, 40 and 30 roads, surely this'd provide excess current?.
It is at THIS point, I venture the suggestion.... best person to answer such questions is YOU.....
Cost about a tenner.... give it a go!
Worst case, battery wont get much charge from the battery... in which case, you treat it like a rechargeable cycle lamp, and wallop in on charge off the mains every time you park up at home, to keep it topped up......
BUT I suspect that should 'work' or at least work 'better' than the direct lighting system you have now... which... lets face it... doesnt!
ThoughtContro...
PostPosted: 19:43 - 07 Jun 2011    Post subject: Re: How to stop 6v bulbs blowing? Reply with quote
Re-reading the OP (it does help) Smile , the problem is the just over-voltage to the rear light. If your over-revving constantly dim lights aren't your problem. Why not just use the bridge rectifier, and optionally, a small capacitor between the rear light wiring and the bulb, leaving the front headlight as AC? The two diodes will suitably reduce the rear light voltage to something more bareable by the bulb, the cap, if used, may smooth the peak voltage a tad, so then the bulb won't blow. The front light wont have the heavy burden so won't blow either.
If I comprehend G's post correctly this may have been Honda's solution in the C90, a mix of AC and DC powered lighting?
Prize cunt
SpannerMonkey
PostPosted: 20:10 - 07 Jun 2011    Post subject: Reply with quote
Right, I really dont understand any of this electrical bollocks... what am I supposed to be fitting? what fits between where? I need someone to either educate me in electrics so I can make my own decisions, or for someone to make my decisions for me, and justify them lol
ThoughtContro...
PostPosted: 21:32 - 07 Jun 2011    Post subject: Reply with quote
OK possible suggested circuit diagram attached (MS Paint)
Components
1N5401 Diode x4 Maplin Code - QL82D, 29p each
(Rated 3A, 100V, so fine for any 6V bulb up to 18W, Any of the 1N5400 series will do really)
Optional
470uF 25V Electrolytic Capacitor Maplin Code - DT60Q, 31p each
(Not critical at all as long as rated voltage is well above 10V it'll be fine. Large uF value is nice for smoothing purposes, tho it's no big deal since we're running a filament bulb not a logic circuit. The one above is a High Temp Cap too. The only thing to make sure with Electrolytic Caps is make sure you solder them in the right way round, as they are polarised. Negative lead will be marked)
Prize cunt
finpos
PostPosted: 22:24 - 07 Jun 2011    Post subject: Reply with quote
Try muuuuuch higher. Automotive environments destroy normal electronics - it's the reason rectifiers etc cost so much money for what is nominally a handful of semiconductors - they have to be rated to absurd levels to survive the transient voltages for more than a few days.
I fear for your 1N5401.
f.
SpannerMonkey
PostPosted: 22:25 - 07 Jun 2011    Post subject: Reply with quote
f.
So what's your suggestion?
ThoughtContro...
PostPosted: 22:33 - 07 Jun 2011    Post subject: Reply with quote
f.
1N5408? Rated 1000V PIV or not absurd enough?
Prize cunt
finpos
PostPosted: 22:54 - 07 Jun 2011    Post subject: Reply with quote
eh... stick a bigger bulb in it! You can even try using 12V bulbs.
You could possibly put a vespa regulator (https://beedspeed.com/product_info.php?products_id=1663) in it, the worry being that the alternator won't put out enough power to operate that and the lights - in much the same way that simultaneous horn and lights can only be a dream. May be worth trying at £20.
f.
finpos
PostPosted: 23:38 - 07 Jun 2011    Post subject: Reply with quote
At a guess, no, you're still need to be worried about very high surge current etc. which is why there exists the stupidly expensive diodes designed for this use case and no other. There's plenty of data sheets around if you want to compare them.
If you build something with a 1N5401 you'll probably find it works fine one night and is broken in the morning. Turning off the engine killed it.
f.
kramdra
PostPosted: 01:28 - 08 Jun 2011    Post subject: Reply with quote
Schottky ftw. double them up, 15A rating is plenty for that bike.'
https://www.rapidonline.com/Electronic-Components/Discrete-Semiconductors/Schottky-Diodes/Power-dual-Schottky-rectifiers/78105
https://www.rapidonline.com/Electronic-Components/Discrete-Semiconductors/Rectifier-Diodes/High-power-dual-Schottky-rectifiers/76074
https://www.rapidonline.com/Electronic-Components/Discrete-Semiconductors/Schottky-Diodes/Power-Schottky-rectifiers-TO-220/78104
For DC to work, you need some REALLLY big smoothing caps. Small ones wont just not work, they will rapidly dry out and go bang... or something.... smells really bad anyway. Capacitors do disipate power = voltage x ESR (AC resistance).
https://www.rapidonline.com/sku/Electronic-Components/Capacitors/Radial-Electrolytic/Low-profile-snap-in-105-deg-C-2000hr.-electrolytic-capacitor/80204/11-3152
they dont do anything bigger... 2 or 3 of those in parallel.
The last post was made 15 years, 142 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 145.23 Kb
