| SpannerMonkey |
 SpannerMonkey World Chat Champion
 Posted: 13:29 - 07 Jun 2011 Post subject: How to stop 6v bulbs blowing? |
So when I actually GET to ride my '72 pc50, I have this nasty habit of over-revving the engine some-what.
Being a 6v direct lighting system with no battery or fuses, every time I go downhill and do anything over 33mph-ish my back light will blow... which then leaves a heavy load on the headlight, which follows within the next 15 minutes.
I understand the theory that goes into engines really well... but I seriously struggle to comprehend electrics as I cant picture whats going on. So how the hell do I stop these lights from blowing? besides using less throttle
Would a 6v battery wired between the power source (Dynamo? magneto? I dont even know what you call these things...) smooth out the current? Also maybe keep my lights brighter at low revs? ____________________ My bike? A YX140 powered one-off Monkey Bike, something a little different! |
| Willson |
 Willson Traffic Copper
| G |
 G The Voice of Reason
| SpannerMonkey |
| stinkwheel |
 Posted: 14:09 - 07 Jun 2011 Post subject: |
Make sure you get a motorcycle specific bulb. They tend to have and extra "leg" supporting the filament. It might be vibration rather than overload that's making it blow.
Another option would be to fit a higher wattage bulb in either the front or rear light. They'll be more dim at lower revs but it's really just a position light anyway. I certainly wouldn't try riding inthe dark with it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| SpannerMonkey |
| kramdra |
 kramdra World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 16:39 - 07 Jun 2011 Post subject: |
Vibration is a bulb killer, but 6v bulbs and direct lighting are notoriouse.
Old fasioned way of dealing with it was to fit lower wattage 12v bulbs.
Power = Current x Volts
Volts = Current x Resistance
So 15w 6v bulb, current would be 15/6.... call it 3 Amps. Resistance would then be 6/3 or 2 Ohms
A 15w 12v bulb, do the same you get 15/12 for 1.5A and Resistance 4 Ohms
So fit a 4Ohm 12v bulb to a 6v system, and it would draw, Volts / Resistance, 6/4 1.5Amps
So, Power = Volts x Amps, you'd get 6x1.5 or 9W from it instead of 15...
So you crunch some numbers to find out what 'sort' of 12v rating gives 'similar' lighting power...
Then you try it, and see how it works.... becouse often the 12v bulb at lower revs wont get enough juice to make it glow.... and you then go down a rating..... but, should find one that works acceptably, and that wont 'blow' when high revs over voltage is applied to it.
Alternatively..... yes, you want a little regulator circuit and battery, which can easily be wired up from components, and Maplins do some quite small, sealed lead acid 6v 'alarm' batteries that would do quite a nice job.....
HOWEVER...... your bike, PROBABLY has a regulator already..... and it's fucked!
6v direct systems often had a 'zenner diode' regulator. Its a diode working backwards, so it clips voltage over threshold, to prevent over volts... not very efficient, but they do work... and that's teh first place to look... do you have one? and is it working?
On Hondas often looks like a blade fuse in the headlamp, black, with a diode symbol on it ->|- if not, could be on the fork yoke or head stock, or under the ignition key, and possibly have a bit of heat sink around it.
If you dont have one, a 6V Zenner of suitable rating might be a solution, rather than full regulator circuit... and a nice descrete mod, it can be wired 'in line'... but, I think I'd go for a small sealed lead acid and a regulator circuit, hidden away somewhere, for 'reliable' lights for modern roads. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| stinkwheel |
 Posted: 16:54 - 07 Jun 2011 Post subject: |
I think you overestimate the complexity of these bikes Mike.
It has a headlight and a tail light that run on single phase AC direct lighting. It's a 7 wire loom (see attached picture, that's ALL the wiring).
No brake light, no flashers. The speedo back light is cunningly arranged by having a hole in the headlight reflector directly under the speedo. Similar arrangement for the hi beam (to make laughing noises) warning light.
If you want to sound the horn at the same time as you have the lights on, you have to pretty much redline it.
I very much doubt there is any form of regulator at all. It produces about 5A top whack and that's AC output. Start trying to rectify it and you have no chance. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| ThoughtContro... |
 ThoughtContro... World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 17:20 - 07 Jun 2011 Post subject: |
| stinkwheel wrote: | I think you overestimate the complexity of these bikes Mike.
I very much doubt there is any form of regulator at all. It produces about 5A top whack and that's AC output. Start trying to rectify it and you have no chance. |
Possibly Stink, hence suggestion to make regulator rather than use a Zenner.
@You Monkey: If you use a Zenner, it 'clips & dumps' the peaks of the AC voltage, so it wil lprotect the bulbs from over volts, but only at the expense of dumping useful power.
A four diode, bridge rectifier, would take ALL the AC power and turn it into DC. Putting that into a 6v battery, it would capture any excess the system MIGHT make during over voltage or when there's low or no load on the system, and make it available when the generators not delivering much.
Maplins, four 3A diodes, and a 6v alarm battery, be about a tenner.... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| ThoughtContro... |
 Posted: 17:46 - 07 Jun 2011 Post subject: |
Mike, if you're using a Zener regulator you'll usually use a shunt resistor too, see https://www.reuk.co.uk/Zener-Diode-Voltage-Regulator.htm
It's not the most efficient way of doing things.
If you use a 4 diode bridge rectifier, then you'll drop around 0.6-0.7V across the diodes, so you'll lose about 1.4V max across each diode pair, during each half cycle.
Also if you'd be better using an electrolytic capacitor to smooth out the output from your bridge rectifier, since it's smaller lighter and cheaper than piddling about with the complication of extra batteries, if you want to do it that way. ____________________ Prize cunt
"In a world of universal deceit telling the truth is a revolutionary act" - George Orwell |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 18:13 - 07 Jun 2011 Post subject: |
| ThoughtControl wrote: | Mike, if you're using a Zener regulator you'll usually use a shunt resistor too, see https://www.reuk.co.uk/Zener-Diode-Voltage-Regulator.htm
Also if you'd be better using an electrolytic capacitor to smooth out the output from your bridge rectifier, since it's smaller lighter and cheaper than piddling about with the complication of extra batteries, if you want to do it that way. |
I was thinking more along the lines that a lead acid would store charge long term, where a capacitor would just smooth the AC...
Hence using battery, riding in daylight, light's 'off' battery would charge. Night time, even at low revs, or engine off, charged battery would offer amps to keep lamps lit. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| ThoughtContro... |
 Posted: 18:42 - 07 Jun 2011 Post subject: |
| Teflon-Mike wrote: | I was thinking more along the lines that a lead acid would store charge long term, where a capacitor would just smooth the DC...
Hence using battery, riding in daylight, light's 'off' battery would charge. Night time, even at low revs, or engine off, charged battery would offer amps to keep lamps lit. |
Well it would work, so long as he's got somewhere neat to hide the battery and extra wiring (long wiring may cause a minor voltage drop too since any power loss is proportional to the square of the current, and a 6V system will use twice the current of a 12V system for the same wattage light).
The main drawbacks I can see is that to charge the extra battery at a suitable rate then the output from the bridge rectifier should be somewhere near 7V. If your diode pair on the bridge is dropping 1.2-1.4V, then you need the alternator to output 8.2-8.4V for a nice healthy charge. If it doesn't output anywhere near this then any charge will be a trickle rate, which isn't that useful. At night if the battery becomes flat then the alternator now has to try to charge the battery and supply the lights, which will likely lead to very dim lights. ____________________ Prize cunt
| SpannerMonkey |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 19:15 - 07 Jun 2011 Post subject: |
| LittleHonda50 wrote: | | ThoughtControl wrote: |
Well it would work, so long as he's got somewhere neat to hide the battery and extra wiring Yes, I'm fitting a topbox to the bike =P which will be an almost permanent fit
The main drawbacks I can see is that to charge the extra battery at a suitable rate then the output from the bridge rectifier should be somewhere near 7V Well the bike is almost CONSTANTLY at high rpm as I ride along a lot of NSL, 50, 40 and 30 roads, surely this'd provide excess current?. |
It is at THIS point, I venture the suggestion.... best person to answer such questions is YOU.....
Cost about a tenner.... give it a go!
Worst case, battery wont get much charge from the battery... in which case, you treat it like a rechargeable cycle lamp, and wallop in on charge off the mains every time you park up at home, to keep it topped up......
BUT I suspect that should 'work' or at least work 'better' than the direct lighting system you have now... which... lets face it... doesnt! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| ThoughtContro... |
 Posted: 19:43 - 07 Jun 2011 Post subject: Re: How to stop 6v bulbs blowing? |
| LittleHonda50 wrote: | nasty habit of over-revving the engine some-what.
every time I go downhill and do anything over 33mph-ish my back light will blow... which then leaves a heavy load on the headlight, which follows within the next 15 minutes. |
Re-reading the OP (it does help) , the problem is the just over-voltage to the rear light. If your over-revving constantly dim lights aren't your problem. Why not just use the bridge rectifier, and optionally, a small capacitor between the rear light wiring and the bulb, leaving the front headlight as AC? The two diodes will suitably reduce the rear light voltage to something more bareable by the bulb, the cap, if used, may smooth the peak voltage a tad, so then the bulb won't blow. The front light wont have the heavy burden so won't blow either.
If I comprehend G's post correctly this may have been Honda's solution in the C90, a mix of AC and DC powered lighting? ____________________ Prize cunt
| SpannerMonkey |
| ThoughtContro... |
| finpos |
 finpos World Chat Champion
| SpannerMonkey |
| ThoughtContro... |
| finpos |
| finpos |
| kramdra |
 Posted: 01:28 - 08 Jun 2011 Post subject: |
The last post was made 15 years, 142 days ago. Instead of replying here, would creating a new thread be more useful? |
