MOT possible failures?
HD
PostPosted: 20:41 - 08 Jun 2011    Post subject: MOT possible failures? Reply with quote
Okay, just spent a hefty sum getting my bike ready for the mot. Just a few things I am concerned about that I wanted to ask your opinions.
Firstly, when I sprayed my exhaust, I took it off and the bracket that secures it to the frame snapped. I didn't replace it is it would need welding. It is currently held on by the bolts into the cylinder and the hanger and it is secure, but is that bracket required?
Also, my thermostat didn't work so I bought a temperature gauge and that works lovely. I just wanted to know that is it compulsory to have a working one? I could bodge my current one to make it look like it works but when we put the temperature gauge in, we broke the top off of the thermostat off to see if it would go in there. But it didn't Razz
So do I need a thermostat and an exhaust bracket?
Also, my front is getting a bit bald in some parts. I have heard that 50's only need visible tread. Is this true?
Ta Thumbs Up
PostPosted: 20:49 - 08 Jun 2011    Post subject: Reply with quote
If the exhaust is secure it should be fine.
Stat doesn't matter for the MOT.
A 50 only needs clearly visible tread the whole way round and over the full width.
HD
PostPosted: 23:42 - 10 Jun 2011    Post subject: Reply with quote
Shit, I forgot one more.
There is a little rubber dust boot on the bottom of my rear master cylinder. I think when it was new there was a sort of retaining spring that expanded and grabbed it from the inside. It always falls down and I can clip it up but by the time I reach my destination it will fall down.
It is right at the bottom where the actual pin goes into the cylinder.
Would a picture make this clearer?
I can't find a replacement clip, so would it fail because this boot isn't on properly? (which I may be able to clip on around the corner before I do last minute checks).
PostPosted: 23:54 - 10 Jun 2011    Post subject: Reply with quote
Nothing about that in the MOT manual. As long as it doesn't adversely affect the brakes it should be fine
HD
PostPosted: 00:04 - 11 Jun 2011    Post subject: Reply with quote
No not at all. Only notice it when I get off the bike Laughing
The last post was made 15 years, 141 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 45.95 Kb
