Superdream 250/400
Moo.
PostPosted: 17:41 - 11 Jun 2011    Post subject: Superdream 250/400 Reply with quote
Im just wondering whether putting 400 barrels and pistons on the 250 will work, i know the obvious, change the carb jetting.
But my wonders are, in the haynes manual the valve spring free lengths for the 250 are longer then the 400. Would the 250 head still work with the 250 head?
Also, the valve timings, on the 250 the inlet closes at 30 degrees but on the 400 they close at 35 degrees. Is this going to cause a problem?
And with the cdi, am i right in thinking this controls when the sparks ignite? And that this is to do with the valves open/closing. What would the 400 cdi do differently to the 250, considering all the timings are the same, apart from the 30/35 degree difference.
Many thanks.
A2 Passed 18/6/10
MattWadz
PostPosted: 18:53 - 11 Jun 2011    Post subject: Reply with quote
The bottom end is only designed to run 250 pistons/barrels...
Pitbike x2, Mini Moto x4, China Quad, 02' Suzuki AP50 > 03' MBK Nitro > 86' Suzuki GP100 > 02' Yamaha Jog R > 57' Honda Lead 100 > 95' Piaggio ZIP Rst 50 > 51' Suzuki TS50x > 83' Honda CB125TDE Twin > 51' Yamaha Aerox > 98' Kawasaki KX60 > 89' Yamaha DT50MX > 80's Honda QR50 > 05' CG clone > 125cc China Pitbike > 91' Honda MTX125 RW-L > 09' Peugeot Speedfight 2 LC LR > Lucky MX 140cc > Apache Tomahawk 50 Quad (current = 2010 Yamaha WR125R
Moo.
PostPosted: 19:15 - 11 Jun 2011    Post subject: Reply with quote
I know theres a difference in the strokes.. but theoretically, if i put the pistons and barrels on.. shouldn't it still work? And the timings be the same?
Or.. are the pistons longer as well as wider? Hence the longer stroke..
This is working on the theory i could create a 323cc engine..
Displacement is Pi/4 x bore(squared) x stroke x no of cylinders..
Making 323cc..
Would this work? Taking into account jetting etc..
Just like putting a big bore kit on something..
A2 Passed 18/6/10
PostPosted: 20:07 - 11 Jun 2011    Post subject: Reply with quote
Fair chance that you would land up with a very low compression 323cc engine.
Teflon-Mike
tl;dr
PostPosted: 20:14 - 11 Jun 2011    Post subject: Reply with quote
Theoretically, the bike would still run... ish.
The cam timings are close enough to not be such a big difference, 400 timings are basically a bit 'wilder' with a longer duration.
Your main problem would be, compression.
If you have 250 bottom end, and 400 barels, where will the pistons sit in the barel at TDC.
400's longer stroke, will mean it probably has longer con rods, and or a different gudgeon to crown height.
You could have piston skirt fouling crank counter balences at BDC or the piston crown fouling head / valves at TDC or you could simply have piston sitting half an inch from the combustion chamber at TDC giving no compression.
But, if that's all OK.... then you'll simply have a 75cc over bored 250 engine..... possibly need re jetting to suit new displacement, might, on 250 carbs run out of breath at the top end.... other wise, would run like a bored out 250....
Given availability of 250N motors and bits, and cost / effort of rebuilding one.... though, one does have to ask if its worth it.
New pistons will set you back about £70, a Gasket set £20, and a rebore or second hand barel, IF you can get a 400 barel, probably another £50.... then you have to set it up......
When you can buy a taxed, & tested mid 90's CB500 for a few hundred quid.... you have to question the ecconomics of muggering about with a thirty year old commuter, and trying to eek a bit moore oomph out of it.......
Moo.
PostPosted: 21:14 - 11 Jun 2011    Post subject: Reply with quote
What if i were to say i have 2 250 engines, a full gasket set, and 400 barrels and pistons laying around Laughing
I was expecting it to run like a bored out 250, im pretty sure the crankcases are the same, the 400 is just bored out more, with a slightly different crank and longer cod rods. If the pistons are just wider and not any longer, it should fit in..
If physically the engines are no different, how can the 400 have a longer con rod? Would the head be different?
Whats the difference between the 250 and 400 pistons? Are the 400's just wider? If so wouldn't it sit in the same position as the 250 at tdc? Using the 250 crank and conrods..
A2 Passed 18/6/10
PostPosted: 21:25 - 11 Jun 2011    Post subject: Reply with quote
If the stroke is longer then either the head is further from the crankcases or the rod is shorter. However a longer rod would be preferred to go with the longer stroke which suggests the head is quite a bit further from the crankcases (ie barrels quite a bit longer).
You might be able to bore out the 250 barrels to take the 400 pistons, assuming the distance between the gudgeon and piston crown is the same.
Moo.
PostPosted: 21:33 - 11 Jun 2011    Post subject: Reply with quote
This is what i dont understand. Physically the engines are exactly the same, if the barrels were any longer the engine would foul the frame. The engines are the same size dimension size on the outside, so how can the conrods be longer? Wheres the extra space come from :o
Sorry if its really obvious and im missing it.. Laughing
A2 Passed 18/6/10
PostPosted: 21:54 - 11 Jun 2011    Post subject: Reply with quote
Difference in stroke is about 9mm, so half of that required as extra height for the stroke. From memory of my 400 many years ago there was enough clearance for 4.5mm extra height.
That said looking at the parts lists the top mounting bracket and the frame are the same between the 250 and 400 (have the same part numbers).
The cod rods do have different part numbers. If the 250 has longer rods to go with its shorter stroke the you might be OK. If the rods are shorter (normally stroke is a multiple of con rod length for a certain engine characteristic - shorter rods tend to be used on more revvy engines) and then the height made up with a different distance from gudgeon pin to piston crown, then using the 400 pistons would give a lower compression.
Moo.
PostPosted: 22:13 - 11 Jun 2011    Post subject: Reply with quote
Many thanks for looking into that Keith Very Happy
Malc.
A2 Passed 18/6/10
MickC
PostPosted: 09:25 - 12 Jun 2011    Post subject: Reply with quote
Didn't they originally just put an extra sleeve in the barrels for the 250. i know i had an xs250 one time and that is what they did with them
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
The last post was made 15 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 73.8 Kb
