adjusting the carb mixture
richk
PostPosted: 10:52 - 13 Jun 2011    Post subject: adjusting the carb mixture Reply with quote
my bike will only really run well with half choke all the time. the carb has been off recently, so im assuming i havent reset the mixture screw properly.
looking at haynes, it says just screw it in/out, but there seems no way to do this with the carb on the engine, cant get a screw driver in
i have a kinlon 125, and looks like a slide carb
are there any tricks
stirlinggaz
PostPosted: 11:19 - 13 Jun 2011    Post subject: Reply with quote
Which carb is it? pics?
is the mixture screw not on the bottom of the carb, facing towards the ground?
adjust using something like this https://cgi.ebay.co.uk/DRAPER-2-PIECE-PLAIN-SLOT-PZ-ANGLED-SCREWDRIVER-SET-/250628979303?pt=UK_Hand_Tools_Equipment&hash=item3a5aa6ba67#ht_1014wt_905
cheers,
GAZ
richk
PostPosted: 11:27 - 13 Jun 2011    Post subject: Reply with quote
yeah the screw is pointing down, that screw drivery thingy looks like the thing i need Smile sure i have one of those from an ikea set somewhere...
cheers
Robby
Dirty Old Man
PostPosted: 13:51 - 13 Jun 2011    Post subject: Reply with quote
It shouldn't need much force to move. I just use a screwdriver bit from a bit set and turn it with that.
richk
PostPosted: 15:26 - 13 Jun 2011    Post subject: Reply with quote
cool will give that a go. is it in or out to richen?
bacon
PostPosted: 15:54 - 13 Jun 2011    Post subject: Re: adjusting the carb mixture Reply with quote
I know nothing about your bike, but first check that you put it back on correctly, mainly no air leaks.
Assuming thats fine then I'd do as Robby suggested.
richk
PostPosted: 16:10 - 13 Jun 2011    Post subject: Reply with quote
ah an airleak, that would make sense. i will have a look. will the wd-40/carb cleaner trick (squirting some at the manifold) work on a bike?
PostPosted: 16:39 - 13 Jun 2011    Post subject: Reply with quote
Yup, that'll do it.
If you have one of the Mikuni / Den(h)i 26mm carbs with the choke lever on the carb itself, are you definitely flipping it down to turn it off? I only ask because after saying that upwards of a dozen times to other people, I forgot it myself after doing some work on my 125 and couldn't understand why it wouldn't idle with the choke "off". Embarassed
bacon
PostPosted: 16:06 - 14 Jun 2011    Post subject: Reply with quote
Screw out to richen, if you are sure there are no air leaks etc.
richk
PostPosted: 17:17 - 16 Jun 2011    Post subject: Reply with quote
cheers people, will give it a go tomorrow Smile
are there any guides on tuning a bike?
The last post was made 14 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 62.56 Kb
