| binge |
 binge Emo Kiddy
 Posted: 11:35 - 17 Jun 2011 Post subject: YZF450 clutch |
Took the YZF out yesterday to test it after the rebuild.
Everything is fine
One little problem, on the re-build, I forgot to tighten on of the oil drain bolts back up.
Was riding for about 10 miles, then the back end felt like it had a flat tyre, sliding all OVER the place.
Pulled over to find oil, literally pumping out of the engine, all over my boots. FML!!!!
Anyway, Dammy popped up in his van with a spare m6 bolt, a spanner, some rag, and some oil.
One thing I have noticed is, the clutch doesnt like to dis-engage properly in first.
It is possibly because it's a heavy duty clutch.
It'll happily go into neutral with the engine off, so it's not gearbox related.
But with it running, it wont go to neutral properly.
Also, when you stick it into first, it wants to creep forwards.
The clutch pressure plate is DEFINITELY lifting, a good 4 or 5mm off the clutch basket/plates, as I've pulled the lever with the cover off.
I am wondering weather this is because I've fitted a Barnett race clutch, and HD springs, and some of the plates are just sticking together?
Any ideas?
Ta
Ben |
| N cee thirty |
 N cee thirty Banned
| garth |
 garth World Chat Champion
| binge |
 binge Emo Kiddy
| andym |
 andym World Chat Champion
| HD |
 HD World Chat Champion
 Posted: 18:44 - 18 Jun 2011 Post subject: |
A mate has this problem with his rs. Takes like 20 seconds to get it into neutral with the engine running. You also have to have the lever against the bar when stopped in gear.
I know its adjusted wrong but he says he likes and he is used to it but if I could persuade him it will change his neutral issues then it will be better. When I ride it too  ____________________ Rusty '02 Vito Camper + CBR600F3 |
| binge |
 binge Emo Kiddy
 Posted: 20:21 - 18 Jun 2011 Post subject: |
The clutch is 100% not adjusted wrong.
This is why I cant understand it.
I've a feeling the plates are sticking together. But you'd of thought that once they "break" free, they wont stick again, or drag.
The clutch pressure plate lifts a good 5mm away from the clutch basket.
Then I can physically move the plates and steels around with my finger (Well, up and down).
But when re-assembled with the cover on and oil in, it dont half drag.  |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 21:07 - 18 Jun 2011 Post subject: |
warped plates ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| binge |
 binge Emo Kiddy
| MaybeGuy |
 Posted: 23:54 - 18 Jun 2011 Post subject: |
did you only replace the friction plates? because they're not really what tends to warp are they? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| binge |
 binge Emo Kiddy
 Posted: 11:33 - 19 Jun 2011 Post subject: |
| mattsprattuk wrote: | did you only replace the friction plates? because they're not really what tends to warp are they? |
Nope, complete clutch pretty much.
Friction plates, Steels, and HD springs.
It's the springs that I think may be causing this issue, as they are pressing the clutch together F*cking tight.
| Howling Terror wrote: | Unsure if this applies to your clutch.
Some Barnett clutch packs have concave aluminium plates that have to be fitted a certain way round.
Worth a punt. |
I know the style you're thinking of. They are more along the lines of a stock replacement clutch. Where the first friction plate has a bigger ID than the rest, then the 2 diaphragm rings sit inside this.
Mine doesn't have that, It just has 8 identical friction plates.
Last night, I was tinkering in the garage, fitted my fat bars and Zeta top clamp.
The clutch doesn't seem as bad now. In gear with clutch in, I can turn the rear wheel, but it's not exactly free rolling.
Ben |
| MaybeGuy |
 Posted: 12:15 - 19 Jun 2011 Post subject: |
notched basket then? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| robocog |
 robocog Traffic Copper
The last post was made 15 years, 124 days ago. Instead of replying here, would creating a new thread be more useful? |
