Battery not charging
von1papen
PostPosted: 13:47 - 21 Jun 2011    Post subject: Battery not charging Reply with quote
This is a 2 month old battery as well, bought it for the cm200 fully charged it and put it in.... However now it seems to be reasonably flat!
Bought a new charger as the old one died, charged it over night and shes moved from about 8volts to 8.8 volts! Acid levels are proper and topped up as well, don't wana have to chuck a brand new battery Crying or Very sad
Bezzer
PostPosted: 15:47 - 21 Jun 2011    Post subject: Reply with quote
8.8 volts Shocked , it's a 12 volt system on them isn't it ?. Your battery is well and truly shagged there's a few knackered cells in it for that low a reading. Shouldn't be knackered after 2 months if your bike is charging right, it's not unknown for new ones to fail. Check it's charging right first, put a multimeter on 0-20v DC across the battery terminals with the engine running and you should see around 14 volts or so when you rev it. If you don't you've got a charging problem, if it's OK the battery was knackered and should be exchanged.
Chriss
PostPosted: 16:45 - 21 Jun 2011    Post subject: Reply with quote
Most battery companies give a warranty. Take it back and see! Thumbs Up
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
von1papen
PostPosted: 19:35 - 21 Jun 2011    Post subject: Reply with quote
Half the problem is now I can't start the bike with said battery, Must try and get a spare or something else to try and start the bike, then I'l know it's definitely the battery! Don't have the receipt for it anymore though.... Bugger!
Chriss
PostPosted: 20:09 - 21 Jun 2011    Post subject: Reply with quote
Jump or bump the bike? If after a good ride it's still low then it's the battery that's no good.
von1papen
PostPosted: 20:21 - 21 Jun 2011    Post subject: Reply with quote
The bike itself doesn't run very well, cuts out at high revs etc so its the battery that is now holding me back from working on it, may wheel it round somewhere to try and bump start it if I can
neatbik
PostPosted: 20:29 - 21 Jun 2011    Post subject: Reply with quote
Sounds to me like a charging problem if its killed 2 batteries in a short space of time.
As already mentioned, get it running and measure the voltage at the battery throughout the rev range.
The last post was made 15 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 50.12 Kb
