Tell tale signs a 2t is gonna go bang?
Martay
PostPosted: 19:31 - 21 Jun 2011    Post subject: Tell tale signs a 2t is gonna go bang? Reply with quote
Hi,
Bit out of the blue but;
I was once told a 2 stroke will only last about 10k before needing a rebuild. How true is this?
The bike in question is my Honda SH50 which i mainly use for hooning to town on so i dont have to drag the car out, or when i cant be bothered to fill the car up! The bikes done 11k, 400 fault free miles with me riding it flat out everywhere. Before me, it was a training school bike, im not sure if that means its been thrashed and crashed, or grannied around!
Is there any tell tale signs the piston/rings are on their way out? If it does go bang, provided the barrel ISNT SCORED will it be worn enough to warrent an oversize piston, or will a standard size be sufficient. They are available from a .25 up to 1.0 oversized. I understand you cant say for sure, sat there infront of your computer miles away, but an opinion would be nice Smile
1 more question, a barrel + piston kit with rings, pin and gaskets is £40 delivered. Is that TOO cheap?
Thanks
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
cb1rocket
PostPosted: 19:43 - 21 Jun 2011    Post subject: Reply with quote
thats a good question but I guess its down to mainteance or no mainteance (ie no oil) and an instance bang!
Usually they happen quite sudden without warning, my H100S did this when flat out and holed the piston!
Generally the 10k rule is usually for sport tuned bikes like the RS125 NSR125 etc which involves a new piston and rings.
You could service the bike with new rings and a new piston to be safe but someone would need to clarify that. Every top end rebuild I have done has been rebored and an oversize piston. I have only done it twice on two different bikes over my 7 years of riding.
I tend to favour the saying "look after the bike and the bike will look after you". So if you keep an eye on the oil pump and it's cable and checked that there are no leaks on the oil lines then I couldnt see any problems hitting 40 - 50k which by then you would of probably scraped the bike by then!
cb1rocket
PostPosted: 19:47 - 21 Jun 2011    Post subject: Reply with quote
And in answer to your question £40 quid does sound cheap then then its bloody good value for money if its a good kit. See if you find any reviews on the kit.
I wish my H100S was like that. You can get a kit for them MINUS the barrell so once my barrell is knackered and no more oversized piston then i'm screwed basically. Unless I went for a linear which is ££££
Martay
PostPosted: 19:53 - 21 Jun 2011    Post subject: Reply with quote
Ok that sounds good Smile
I know for sure its getting oil, smokes like a trooper when cold, clears when its warm, i do keep an eye on the level. Im just worried about it going and either leaving me stranded or taking the bottom end with it!
Recently i took it for a jaunt which involved 45minutes on an A road. I dont know if it started to nip up or there was a headwind, but the speed dropped off and it wouldnt pull. I stopped to let it cool off. It smelt a bit funky, but after a burger it fired up and ran absolutly fine. I dont really plan on getting rid of it, just keep it going for ever!! I want to see triple figure thousands of mines before i get rid of it!! Laughing I might change the piston as a service item. Oversize or standard?
EDIT: Ok so i might get a kit from wemoto rather than this ebay special. 56quid from wemoto!!
cb1rocket
PostPosted: 20:24 - 21 Jun 2011    Post subject: Reply with quote
ok if you were going flat out and it felt like it was nipping ie down on power then check the oil pump lever is actually working/moving and that the notches on the oil pump lever is in line or however it should be set up according to the workshop manual (or owners manual if it actually tells you how).
Check the air filter is present and not falling apart causing the bike to run lean. Do a plug chop at full throttle riding / A roads and check the condition of the plug. Coffee colour/tan is what you want. Bits of white spots is ash and your running lean. Black sooty/oily and your runing rich.
Check this guide
https://www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html
cb1rocket
PostPosted: 20:26 - 21 Jun 2011    Post subject: Reply with quote
this is better
https://www.aa1car.com/library/reading_spark_plugs.jpg
Martay
PostPosted: 20:29 - 21 Jun 2011    Post subject: Reply with quote
Plug chop sounds like a plan, what is one!? Am i right in thinking its flat out, key off, coast to a halt, change plug, ride home, check condition of removed plug? Its got a new air filter as it ate its last one! Oil pump arm starts moving with the throttle, and reaches its end stop at full throttle Smile
Thanks for all the help, its greatly appreciated Thumbs Up
cb1rocket
PostPosted: 21:05 - 21 Jun 2011    Post subject: Reply with quote
thats the idea but put the same plug back in if you wanted. Take photos at the road side with a good camera or do as you suggested.
Stick the picture up here! Thumbs Up
Bezzer
PostPosted: 21:53 - 21 Jun 2011    Post subject: Reply with quote
Nearly Very Happy , clutch in as well when you hit the killswitch so the engine isn't pulling more unburnt fuel in, then brake hard to stop it ASAP.
edit...it's an auto??, forget what I've put apart from braking hard so it sucks less fuel in Mr. Green
Piercee100
PostPosted: 05:43 - 22 Jun 2011    Post subject: Reply with quote
My H100a is on 17500 miles and never been rebuilt. I bought it off an engineer who gave me its full history- it was laid up for 15 years until he bought it and discovered a duff stator plate. I told him I would examine the piston and barrel when I got it home but he told me not to bother, its running sweet so just leave it until it doesnt Very Happy I have no idea how long they last but on these engines I've have been told that I should be more worried about the big end going.
Rides: Honda H100a (Retired), VT500e (Sold), Kawasaki ZX400 (sold), Kawasaki GT550 (Sold), Suzuki Inazuma (Daily), Honda CD185t (Broken), LML Star 2t (Last run edition).
Martay
PostPosted: 16:45 - 23 Jun 2011    Post subject: Reply with quote
Just been for a lovely run and 'plug chopped' her. Was fun, throttle off, key off, lock up the rear to disengage the clutch. Pushed it into the garden popped the plug out and found this:
https://i279.photobucket.com/albums/kk125/MartayP/P230611_17330001.jpg
Cant really complain i dont think.
Chriss
PostPosted: 16:59 - 23 Jun 2011    Post subject: Reply with quote
Looks good from here but could do with a profile shot really just to be sure. Can't see the bit that the spark jumps across. The middle of the spark plug, what's that bit called?
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
iooi
PostPosted: 18:48 - 23 Jun 2011    Post subject: Re: Tell tale signs a 2t is gonna go bang? Reply with quote
How true is this?
Thanks
Lets put it like this.
I have had X7's, Lc 350, DT 175, Ts 100. All have had over 20 K on the clocks with no hint of a rebuild being required.
All they every had was regular service.
cb1rocket
PostPosted: 21:33 - 23 Jun 2011    Post subject: Reply with quote
looks good to me, nice dark coffee colour. Do a compression test as well just to be sure. You need to get the figures of the pressure from a workshop manual thou and a compression guage. But if its going well then I wouldn't worry.
Another thing is a decoke, they have incredibly small exhaust pipes that I can see that get easily clogged up with wet/oily carbon deposits
jjdugen
PostPosted: 13:31 - 24 Jun 2011    Post subject: Reply with quote
If its running, its going to blow up. If its not running, it has blown up.
Martay
PostPosted: 22:23 - 24 Jun 2011    Post subject: Reply with quote
Sigging!! Laughing
Bought a compression gauge tonight, not just for the bike, its just a handy thing to have kicking round.
Parts are still easy to come by so i guess im just going to stop being a worrying pansy and ride the fucker!! Very Happy
temeluchus
PostPosted: 01:48 - 25 Jun 2011    Post subject: Reply with quote
You know when they let up when the back wheel locks up solid and sends you weaving across three lanes of motorway traffic.
kal9001
PostPosted: 10:47 - 25 Jun 2011    Post subject: Reply with quote
Two strokes needing to be rebuild every 10k is a myth. Its true to an extent on two stroke sports bikes that are built for performance and sacrifice reliability.
If its not "tuned" then many two strokes will probably last longer then a four stroke before any replacements are needed as theres no cam chain or valves to worry about.
A mate of mine once had a Kawasaki KH100...or is it KX100...I dont remember. Hes had it for 10 or so years uses it in the winter or when its wet to commute (Uses an RSV1000 when its nice) and its never needed to be rebuilt since hes had it. Its needed a few new spark plugs but thats meh. He doesnt thrash it and it looks scruffy but the engine is built like a rock.
Anyone stupid enough to think we will drag a load of wooden horses full of soldiers into our city is certanley stupid enough to drag all of ours into theirs!
stevo as b4
PostPosted: 22:21 - 25 Jun 2011    Post subject: Reply with quote
As long as a 2stroke bike or scooter is:
1, Well maintained and has the correct oil pump settings and is serviced as per the factory schedule.
2, Not home tuned or has aftermarket pipe and filter fitted without re-jetting etc
3, Is run on a decent fully sythetic oil.
then most bikes will last a very long time. The high performance 200bhp/litre+ bikes will experience much faster ring and piston wear than a low powered commuter engine. The 10'000m reccomendation is more of a guide than anything else, but any high performance engine will do well to run well for longer than this IMO. You normally get harder starting, poorer running and more smoke as engine wear gets more noticable. A compression check is one good indication, but then so is a dyno test. on a 60bhp 250cc bike you might not notice a 10-15% drop in power if it's a high performance engine with a sharp powerband. But if the same bike later only makes say 48-50bhp on the same dyno, then you have a noticeable drop off in power which is a good time to suggest a re-build should be considered.
I do agree that 2strokes can and do blow up, or seize or hole a piston etc with little or no warning from time to time, but assuming The first 3points are adhered to then often a blow up happens only from running a worn out engine for too long when it's overdue a rebuild. You can still get things like gaskets failing causing an air leak, and cold seizures from not warming up a bike properly etc, but a lack of maintainence, use of cheap oil and clueless idiots messing with the engine or exhaust, filters or carb are the most likely reasons for an engine to go pop within it's scheduled maintaince intervals.
I've known people who have said to leave an engine alone that starts and runs ok, and to a point this is good advice. You need to know what sounding ok is like though for your particular engine, as some engines still sound really crisp when they are on their last legs and vice versa. Some engines are more mechanically noisy than others.
My last KMX200 could have saved me a fortune if id known for certain when it was likely to blow up. You can usually tell with plenty of experience though when an engine is worn and sounds a bit loose and rattly etc. I know that on a well abused and bodged KMX that 19480 miles was too much to expect.
I wasn't at this point using it for anything other than short trips and leisure use, as i did'nt have the confience in a 19000mile engine with little history and in a bike that had obviously seen some really serious off road abuse. I was riding back from watchin some motocross racing and was just pootling along down a long 30mph hill less than a mile from my house, when a chunk of piston broke off and allowed the rings to move and get jammed in the ports snapping them and gouging out big chunks of Nikasil plated cylinder bore.
The result is far more expense and hassle than a full top end re-build would have normally been.
The last post was made 14 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 119.07 Kb
