| Martay |
 Martay World Chat Champion
 Posted: 19:31 - 21 Jun 2011 Post subject: Tell tale signs a 2t is gonna go bang? |
Hi,
Bit out of the blue but;
I was once told a 2 stroke will only last about 10k before needing a rebuild. How true is this?
The bike in question is my Honda SH50 which i mainly use for hooning to town on so i dont have to drag the car out, or when i cant be bothered to fill the car up! The bikes done 11k, 400 fault free miles with me riding it flat out everywhere. Before me, it was a training school bike, im not sure if that means its been thrashed and crashed, or grannied around!
Is there any tell tale signs the piston/rings are on their way out? If it does go bang, provided the barrel ISNT SCORED will it be worn enough to warrent an oversize piston, or will a standard size be sufficient. They are available from a .25 up to 1.0 oversized. I understand you cant say for sure, sat there infront of your computer miles away, but an opinion would be nice
1 more question, a barrel + piston kit with rings, pin and gaskets is £40 delivered. Is that TOO cheap?
Thanks ____________________ Eat well, poo hard
Drives: Cavalier 2.0 16v
Rides: Slightly ratted Honda City Express  |
| cb1rocket |
 cb1rocket World Chat Champion
| cb1rocket |
| Martay |
 Posted: 19:53 - 21 Jun 2011 Post subject: |
Ok that sounds good
I know for sure its getting oil, smokes like a trooper when cold, clears when its warm, i do keep an eye on the level. Im just worried about it going and either leaving me stranded or taking the bottom end with it!
Recently i took it for a jaunt which involved 45minutes on an A road. I dont know if it started to nip up or there was a headwind, but the speed dropped off and it wouldnt pull. I stopped to let it cool off. It smelt a bit funky, but after a burger it fired up and ran absolutly fine. I dont really plan on getting rid of it, just keep it going for ever!! I want to see triple figure thousands of mines before i get rid of it!! I might change the piston as a service item. Oversize or standard?
EDIT: Ok so i might get a kit from wemoto rather than this ebay special. 56quid from wemoto!! ____________________ Eat well, poo hard
| cb1rocket |
 Posted: 20:24 - 21 Jun 2011 Post subject: |
ok if you were going flat out and it felt like it was nipping ie down on power then check the oil pump lever is actually working/moving and that the notches on the oil pump lever is in line or however it should be set up according to the workshop manual (or owners manual if it actually tells you how).
Check the air filter is present and not falling apart causing the bike to run lean. Do a plug chop at full throttle riding / A roads and check the condition of the plug. Coffee colour/tan is what you want. Bits of white spots is ash and your running lean. Black sooty/oily and your runing rich.
Check this guide
https://www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html |
| cb1rocket |
 Posted: 20:26 - 21 Jun 2011 Post subject: |
| Martay |
 Posted: 20:29 - 21 Jun 2011 Post subject: |
Plug chop sounds like a plan, what is one!? Am i right in thinking its flat out, key off, coast to a halt, change plug, ride home, check condition of removed plug? Its got a new air filter as it ate its last one! Oil pump arm starts moving with the throttle, and reaches its end stop at full throttle
Thanks for all the help, its greatly appreciated  ____________________ Eat well, poo hard
| cb1rocket |
 Posted: 21:05 - 21 Jun 2011 Post subject: |
thats the idea but put the same plug back in if you wanted. Take photos at the road side with a good camera or do as you suggested.
Stick the picture up here!  |
| Bezzer |
 Bezzer World Chat Champion
| Piercee100 |
 Piercee100 Trackday Trickster
 Posted: 05:43 - 22 Jun 2011 Post subject: |
My H100a is on 17500 miles and never been rebuilt. I bought it off an engineer who gave me its full history- it was laid up for 15 years until he bought it and discovered a duff stator plate. I told him I would examine the piston and barrel when I got it home but he told me not to bother, its running sweet so just leave it until it doesnt I have no idea how long they last but on these engines I've have been told that I should be more worried about the big end going. ____________________ Rides: Honda H100a (Retired), VT500e (Sold), Kawasaki ZX400 (sold), Kawasaki GT550 (Sold), Suzuki Inazuma (Daily), Honda CD185t (Broken), LML Star 2t (Last run edition). |
| Martay |
 Posted: 16:45 - 23 Jun 2011 Post subject: |
Just been for a lovely run and 'plug chopped' her. Was fun, throttle off, key off, lock up the rear to disengage the clutch. Pushed it into the garden popped the plug out and found this:
https://i279.photobucket.com/albums/kk125/MartayP/P230611_17330001.jpg
Cant really complain i dont think. ____________________ Eat well, poo hard
| Vincent |
 Vincent Banned
| Chriss |
 Chriss World Chat Champion
| iooi |
 iooi Super Spammer
| cb1rocket |
 Posted: 21:33 - 23 Jun 2011 Post subject: |
looks good to me, nice dark coffee colour. Do a compression test as well just to be sure. You need to get the figures of the pressure from a workshop manual thou and a compression guage. But if its going well then I wouldn't worry.
Another thing is a decoke, they have incredibly small exhaust pipes that I can see that get easily clogged up with wet/oily carbon deposits
| jjdugen |
 jjdugen World Chat Champion
| Martay |
 Posted: 22:23 - 24 Jun 2011 Post subject: |
| Vincent |
 Vincent Banned
| temeluchus |
| kal9001 |
 kal9001 Trackday Trickster
| stevo as b4 |
 Posted: 22:21 - 25 Jun 2011 Post subject: |
As long as a 2stroke bike or scooter is:
1, Well maintained and has the correct oil pump settings and is serviced as per the factory schedule.
2, Not home tuned or has aftermarket pipe and filter fitted without re-jetting etc
3, Is run on a decent fully sythetic oil.
then most bikes will last a very long time. The high performance 200bhp/litre+ bikes will experience much faster ring and piston wear than a low powered commuter engine. The 10'000m reccomendation is more of a guide than anything else, but any high performance engine will do well to run well for longer than this IMO. You normally get harder starting, poorer running and more smoke as engine wear gets more noticable. A compression check is one good indication, but then so is a dyno test. on a 60bhp 250cc bike you might not notice a 10-15% drop in power if it's a high performance engine with a sharp powerband. But if the same bike later only makes say 48-50bhp on the same dyno, then you have a noticeable drop off in power which is a good time to suggest a re-build should be considered.
I do agree that 2strokes can and do blow up, or seize or hole a piston etc with little or no warning from time to time, but assuming The first 3points are adhered to then often a blow up happens only from running a worn out engine for too long when it's overdue a rebuild. You can still get things like gaskets failing causing an air leak, and cold seizures from not warming up a bike properly etc, but a lack of maintainence, use of cheap oil and clueless idiots messing with the engine or exhaust, filters or carb are the most likely reasons for an engine to go pop within it's scheduled maintaince intervals.
I've known people who have said to leave an engine alone that starts and runs ok, and to a point this is good advice. You need to know what sounding ok is like though for your particular engine, as some engines still sound really crisp when they are on their last legs and vice versa. Some engines are more mechanically noisy than others.
My last KMX200 could have saved me a fortune if id known for certain when it was likely to blow up. You can usually tell with plenty of experience though when an engine is worn and sounds a bit loose and rattly etc. I know that on a well abused and bodged KMX that 19480 miles was too much to expect.
I wasn't at this point using it for anything other than short trips and leisure use, as i did'nt have the confience in a 19000mile engine with little history and in a bike that had obviously seen some really serious off road abuse. I was riding back from watchin some motocross racing and was just pootling along down a long 30mph hill less than a mile from my house, when a chunk of piston broke off and allowed the rings to move and get jammed in the ports snapping them and gouging out big chunks of Nikasil plated cylinder bore.
The result is far more expense and hassle than a full top end re-build would have normally been. |
The last post was made 14 years, 260 days ago. Instead of replying here, would creating a new thread be more useful? |
