Chain came off - Honda 125
_Troy_
PostPosted: 20:22 - 21 Jun 2011    Post subject: Chain came off - Honda 125 Reply with quote
Evening all.
The chain came off of my honda cityfly this evening on the way home from work.
Left the car park as usual, heard a little knock, but thought it was just a bump in the road. About 100 yards down the road the chain came off and locked the back wheel. Cue skidding and needing a change of boxers. Managed to drag the bike, back wheel locked, out of the middle of the road.
I then got the chain back on, tested it out around a car park, and decided to try and nurse the bike home. Just around the corner from my house and it happens again. Not surprising i guess.
Now what i want to know is why this happened? Would it just be because the chain was too loose? or would there be another reason.
Looks like the rear sprocket has been quite badly damaged by this, so need a new one of them. Possibly a new chain.
Anyway, thanks in advance for any help guys and gals.
Current bike: ZX6R J1
Previous bikes: CLR 125 | GS500 | ZX6R G2 | SV650
Quote Me Happy
PostPosted: 20:29 - 21 Jun 2011    Post subject: Reply with quote
When did you last check your chain tension? What condition are your sprockets in?
Check that the chain hasn't done any more damage.
neatbik
PostPosted: 20:31 - 21 Jun 2011    Post subject: Reply with quote
As Joe says, poorly adjusted chain (i.e way too slack) or worn sprockets could cause this.
cb1rocket
PostPosted: 20:33 - 21 Jun 2011    Post subject: Reply with quote
no chain mainteance? Have you left it to get really slacked? There isn't really any other reasons other than badly worn sprockets
_Troy_
PostPosted: 20:38 - 21 Jun 2011    Post subject: Reply with quote
The chain seemed fine to me, and i do try and check it as much as possible. I did rack up the miles over the weekend though, so i guess it has loosened itself. I can't see any more damage other than sever scratching to the frame and the need for a new rear sprocket.
Guess i'll have to get the rear wheel off over the weekend and have a proper look.
Thanks guys.
PostPosted: 20:44 - 21 Jun 2011    Post subject: Reply with quote
I'd change the chain too, you don't know what links have been weakened by being jammed. Since you've got to do the rear sprocket, might as well get the full set so you know what you're dealing with from now on.
PostPosted: 20:45 - 21 Jun 2011    Post subject: Reply with quote
Thanks guys.
Its definitely too slack, shouldnt have much up/down movement at all.
Knackered sprockets...with general abuse my cityfly did 9000 miles on the chain and sprockets I fitted.
Never lubed it.. and it didnt snap.. Laughing
cb1rocket
PostPosted: 20:50 - 21 Jun 2011    Post subject: Reply with quote
No offence to the OP but some people think they have lubed the chain really well so its nice and oily but forget to tension the chain!
_Troy_
PostPosted: 21:13 - 21 Jun 2011    Post subject: Reply with quote
cheers for all the quick responses everyone. obviously my fault for the lack of checking after such extensive use over the weekend.
i'll be sure to get a chain with the sprocket, was planning on it anyway.
Quote Me Happy
PostPosted: 21:20 - 21 Jun 2011    Post subject: Reply with quote
Get both sprockets, not just the rear one.
The last post was made 15 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 63.14 Kb
