cig lighter on a bike = bad idea
Auzfest
PostPosted: 10:01 - 23 Jun 2011    Post subject: cig lighter on a bike = bad idea Reply with quote
Returned to bike after finishing work to discover plastic side panel which houses my cig lighter totally melted,attempted to start bike and discovered that the battery was dead which I realised was a very good thing as the bike could of caught fire if the lighter got any hotter,called AA out and on inspection we discovered that some scrote jammed something in the lighter with the intention of burning my bandit to the ground,anybody else with cig lighters on your bike ..be wary where you park or keep the lighter hidden,that is all.[/img]
virus
PostPosted: 10:03 - 23 Jun 2011    Post subject: Reply with quote
Or wire it through a relay on the ignition so it only has voltage supplied to it when the key is in.
John
own: 81 xs1100g...
PostPosted: 10:07 - 23 Jun 2011    Post subject: Re: cig lighter on a bike = bad idea Reply with quote
Its about as useful as an ashtray on a motorbike! Wink
sickpup
Old Timer
PostPosted: 10:14 - 23 Jun 2011    Post subject: Re: cig lighter on a bike = bad idea Reply with quote
So it was neither fused nor operated by a relay then?
RichieZX6R
PostPosted: 10:37 - 23 Jun 2011    Post subject: Reply with quote
Can you remove your seat via key? If so just wire it so its out of sight? I used to charge the phone on my old CB when i was on it. Had it wired so it would go off when the ignition was off.
Current: Kawazaki ZX6R 51
Past: Kawazaki ZX6R 96 - Honda CBR 600F4 05 - Dragstar 125 02 - Honda CB 400 SF 94 - Honda NSR 125 51 - Gilera Runner XV125 04
Auzfest
PostPosted: 10:46 - 23 Jun 2011    Post subject: Reply with quote
Was fitted when I bought the bike,directly wired to the battery and fused.
DrDonnyBrago
PostPosted: 10:56 - 23 Jun 2011    Post subject: Reply with quote
rewire it and use a relay operated by something only live when the ignition is on (something like the rear brake light power supply). that way you need the key in and ignition on to operate the lighter.
RichieZX6R
PostPosted: 10:58 - 23 Jun 2011    Post subject: Reply with quote
oh, i would consider trying to move it then. If some one can stick some thing in it is there a possibility of rain getting into it?
Andy_Pagin
PostPosted: 11:20 - 23 Jun 2011    Post subject: Reply with quote
What's wrong with a 25p disposable gas lighter? Assuming you don't need to run any electrical gizmos.
Andy_Pagin
PostPosted: 11:24 - 23 Jun 2011    Post subject: Reply with quote
Sounds like an amateur bodge-up, obviously the wrong fuse, short circuiting the lighter should have blown the fuse before the wiring got dangerously hot, that's basically the point of a fuse, to prevent electrical fires from overheating wiring.
And of course the lighter should have been relayed through the ignition to prevent it flattening the battery.
virus
PostPosted: 11:25 - 23 Jun 2011    Post subject: Reply with quote
Do you HONESTLY believe ANYONE actually uses a car style cigarette lighter on a motorcycle?
12v socket = phone charger, mp3 player charger, satnav charger etc
Keep up at the back eh? Laughing
John
own: 81 xs1100g...
Andy_Pagin
PostPosted: 11:28 - 23 Jun 2011    Post subject: Reply with quote
Virus, after 28 years driving absolutely NOTHING would surprise me, I mean you wouldn't expect to see someone doing 70 on the M1 reading a broadsheet newspaper propped up on the steering wheel would you? I admit seeing that DID surprise me.
SirEdward
PostPosted: 11:49 - 23 Jun 2011    Post subject: Reply with quote
John
This. Although, I'd prefer a device-specific type of charger/mount, it's not often you have to charge your phone, your laptop, your mp3 player on a universal car cig lighter... GPS on the other hand. Wink
Shouldn't have melted if there was a fuse installed. Don't tell me it covered the ground wire. Shocked
"Beyond a critical point within a finite space, freedom diminishes as numbers increase. This is as true of humans as it is of gas molecules in a sealed flask. The human question is not how many can possibly survive within the system, but what kind of existence is possible for those who so survive.
Pardot Kynes in "Appendix I: The Ecology of Dune""
RichieZX6R
PostPosted: 11:56 - 23 Jun 2011    Post subject: Reply with quote
a few years back i seen a guy on a vespa with a open face type helmet having a siggy while pulling away from traffic lights. Couldn't even see how it was possible to be honest but i guess if the craving kicks in Laughing Razz
PostPosted: 12:03 - 23 Jun 2011    Post subject: Reply with quote
It shouldn't matter which wire the fuse is on, it'll get the same current through it either way.
I run a 12V socket fused but unrelayed since I want power even when the ignition is off. It came in handy yesterday when I left the parking lights on overnight ( Embarassed ) and could pour some electrons in through the socket without even taking the seat off.
If someone wants to knacker your bike, they'll knacker it. There's plenty of easily accessible wiring and fuel lines to be cut. Or they could just kick it over.
Jim Mc
PostPosted: 12:17 - 23 Jun 2011    Post subject: Reply with quote
You could still have the socket as dual purpose by wiring it directly to the battery with a diode to accept charge, and relayed to the battery via some ignition activated live to power your electronic gizmo's.
PostPosted: 13:30 - 23 Jun 2011    Post subject: Reply with quote
Have some Karma for the insight, although I do actually want it live with the ignition off.
kal9001
PostPosted: 18:29 - 23 Jun 2011    Post subject: Reply with quote
Fit a swtich then thats in an easy plase to get at it but isnt visable unless you know where it is. So you dont have to have the ignition on but when the switch is off it still cuts the power.
Anyone stupid enough to think we will drag a load of wooden horses full of soldiers into our city is certanley stupid enough to drag all of ours into theirs!
PostPosted: 18:56 - 23 Jun 2011    Post subject: Reply with quote
Seen it quite a few times myself.
sickpup
Old Timer
How to do it the right way Wink Clicky.
kingsknight
PostPosted: 20:44 - 23 Jun 2011    Post subject: Reply with quote
Or just use wire in a switch with a LED on your handlebars and just switch it on when you want to use it?
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
Old Git Racing
PostPosted: 23:55 - 23 Jun 2011    Post subject: Reply with quote
About as much use as tits on a fish. Charge your i-pod, rampant rabbit, i phone 4 etc at home first then stop for a fag and watch the world go by, lighting it prefferably with a zippo.
The worlds gone mad.
OGR
DrDonnyBrago
PostPosted: 12:54 - 24 Jun 2011    Post subject: Reply with quote
Do you still have a shop?
The link in your sig does bugger all for me.
PostPosted: 13:03 - 24 Jun 2011    Post subject: Reply with quote
15A blade fuse: £0.21p
https://ecx.images-amazon.com/images/I/21P9WyiEnIL._SL500_SS75_.jpg
Bandit side panel: £21
https://www.banditspares.com/images/items/itm_3461_12444881431_l.jpg
Bandit battery: £49
https://www.banditmaniashop.co.uk/ekmps/shops/banditmania/images/gsf600-95-04-mk1-2-bandit-varta-battery-1857-p.jpg
PostPosted: 13:37 - 24 Jun 2011    Post subject: Reply with quote
While we're on the subject of wiring... I've got a 12v -5v mini USB adaptor that I want to fit to my Buell. Its got an inline fuse and everything... I shouldn't need a relay to fit it should I? I should just wire it to the taillight feed?
The last post was made 15 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 132.72 Kb
