cant get the feckin spark plug out
kerr
PostPosted: 14:50 - 23 Jun 2011    Post subject: cant get the feckin spark plug out Reply with quote
Evil or Very Mad try as i might it wont budge, is it safe to spay some wd40 on it? dumb question i know but id rather ask before i start spraying it all over the shop
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
DrDonnyBrago
PostPosted: 14:58 - 23 Jun 2011    Post subject: Re: cant get the feckin spark plug out Reply with quote
WD40 will not do it any harm but I doubt it'll help you get it out either. You'd be better off with a penetrating oil like plusgas. Either of these will just burn off or evaporate if they enter the combustion chamber so don't worry about it too much, it's not as if you will be spraying much on it.
Make sure you are turning it the right way and check the threads afterwards for signs of aluminium cylinder head in it, could be stripped and bodged back together if it is stuck hard.
kerr
PostPosted: 15:01 - 23 Jun 2011    Post subject: Reply with quote
anti clockwise Wink thats what worries me tbh i know there isnt much to the threads on plugs.
Willson
PostPosted: 15:11 - 23 Jun 2011    Post subject: Reply with quote
+1 on plus gas... don't over bollock it otherwise you could shear the plug.
Willson
Benson: Wouldn't life be easier if we were all turtles?
Me: Pig on bread = The way forward.
Riding: '00 Suzuki SV650S. Previous: '99 Kawasaki ER5 - sold, '02 Suzuki GZ125 Marauder - sold
BigGeeking
PostPosted: 15:17 - 23 Jun 2011    Post subject: Reply with quote
what are you using to try and get it out with can you not get a spanner on it or is it set too deep in the case Confused
kerr
PostPosted: 15:27 - 23 Jun 2011    Post subject: Reply with quote
using a t-handle spark plug tool
PostPosted: 15:36 - 23 Jun 2011    Post subject: Reply with quote
Why can't you put a long socket on it, and use a breaker bar/wrench to undo it?
Louis101993
PostPosted: 15:37 - 23 Jun 2011    Post subject: Reply with quote
That would be your problem, use something you can actually get some leverage from.
A2 License Acquired 18/05/2011
Daelim E5 '08 ->Honda CG '99 -> Kawasaki ZXR 400 RR '96 -> Suzuki SV650 '00 (Naked) -> Yamaha Fazer '99
kerr
PostPosted: 15:39 - 23 Jun 2011    Post subject: Reply with quote
iv tried but none of the spanners i have fit Sad
but surely the plug shouldnt be so tight Confused
DrDonnyBrago
PostPosted: 15:44 - 23 Jun 2011    Post subject: Reply with quote
When they have been in a while they can get quite caked in, if the recess is full of crap then find a way of cleaning it out first otherwise all that crap will fall into the cylinder.
Deep socket, extension and a breaker bar will give you ample leverage.
TBH even if it is seized in there isn't much you can do other than get some penetrating oil in there and hope that the last person didn't cross thread or overtighten it.
Well it does need to be air tight for compression.
Fairies attack This post is not being displayed because the poster is banned. Unhide this post / all posts.
kerr
PostPosted: 16:39 - 23 Jun 2011    Post subject: Reply with quote
went and got one to attach to my socket wrench, still wont budge Sad whole world of hurt coming methinks
kerr
PostPosted: 17:25 - 23 Jun 2011    Post subject: Reply with quote
got it Smile got pissed off and put all my effort in, came loose with a bang Shocked thought id definately fucked it.
thankfully the threads are fine, it did have some gunge around the edge probably the reason it wouldnt budge. surely the last owner didnt glue the thing in Shocked the end of the plug was black so hopefully thatl be the solution to the running issues.
neil.
PostPosted: 18:39 - 23 Jun 2011    Post subject: Reply with quote
When you put the new plug in, slap some copper grease over the threads. You won't have issues removing it later and the copper grease gives a better earth connection. Thumbs Up
The last post was made 14 years, 231 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 88.11 Kb
