Spoked wheel lacing - help needed
Gazdaman
I did a trackday!!!
PostPosted: 13:47 - 22 Jun 2011    Post subject: Spoked wheel lacing - help needed Reply with quote
So this is for my KE 175 project. I've had the hub and rim powder coated, and I bought a set of new spokes.
So I came to lace it today and let's say it's not gone well.
I've only started the front wheel, so we'll stick with just that at the moment. Here are the photos of the original spoke pattern before I destroyed them.
https://www.gaz-racing.co.uk/images/vehicle_1171.JPG
https://www.gaz-racing.co.uk/images/vehicle_1173.JPG
So I started off working from the diagram.
https://www.gaz-racing.co.uk/images/vehicle_1554.JPG
And got this far:
https://www.gaz-racing.co.uk/images/vehicle_1555.JPG
That's got all of the drum brake side spokes fitted, and it's got all of the clockwise spokes from the other side (they have an angled neck on the spoke. The anti clockwise on the non-drum side are 90 degree necks.
But the trouble is, they just don't quite reach, the nipples fit over the end of the spoke, but not enough to actually screw any thread on.
https://www.gaz-racing.co.uk/images/vehicle_1556.JPG
Like so.
So my thinking is either:
a) It's an adjustment thing and they can be pulled in.
b) I've done something wrong, either with the order, or got the rim on the wrong way round, but I would assume it's symmetrical, it certainly looks it.
c) The spokes are the wrong length
I don't think it's an adjustment thing, because the hub is pretty central in the rim i.e horizontally if the rim was fitted to the bike. And if it were, some of the remaining spokes would fit, and others wouldn't. In this case none of them appear long enough.
b is very plausible, I juts don't know what I've got wrong.
c I'm not sure. The spokes were off eBay, and from a foreign country, but they were listed for my exact model of bike.
Any tips/help is much appreciated. Logically, I'll probably try it with rim the other way round, because that's the only real glaring error I think I could have made. Also, none of the spokes are tight, the nipples are only on by a few threads.
Gaz
PostPosted: 13:50 - 22 Jun 2011    Post subject: Reply with quote
There was an article in CMM a couple of months back about lacing spoked wheels, I'll try to remember to have a look and get back to you. Thumbs Up
truslack
PostPosted: 14:10 - 22 Jun 2011    Post subject: Reply with quote
Place one next to one of the spokes you took out, and see if they are the same length?
When relacing wheels, I find it much easier to remove and replace 1 spoke at a time, makes the job much more pleasant.
PostPosted: 14:21 - 22 Jun 2011    Post subject: Reply with quote
There are a lot of videos on bicycle wheel building on youtube. The principle is exactly the same.
Looks to me like you've got it twisted up so the hub is rotated excessively in relation to the rim.
Sheldon Brown is always good for getting to the root of a problem. Here's a very complete article on the subject of bicycle wheel building:
https://www.sheldonbrown.com/wheelbuild.html
yen_powell
PostPosted: 16:35 - 22 Jun 2011    Post subject: Reply with quote
When I visited a professional wheel builder he had a jig that kept the hub and the rim in the correct position in relation to each other. He also carefully measure the sideways offset of the hub to the rim before dismantling the wheel which doesn't always sit in the middle as you'd expect. It may be that your hub is too far to one side which would make some spokes come up short.
XT1200Z and a DR350 in bits
PostPosted: 18:08 - 22 Jun 2011    Post subject: Reply with quote
Hi Gaz, I've found a couple of issues of CMM with articles on wheelbuilding, however its a 3 part jobbie and I don't have the first issue with me (I put a load of stuff in storage recently).
It does seem however that the very first thing they did was build a wheelbuilding jig to hold the rim in place. They used the old wheel to do this, and they laid it down on a board and screwed some smaller pieces of wood over the rim to hold it in place.
From what they say it sounds like that is pretty important to the process...
Gazdaman
I did a trackday!!!
PostPosted: 13:18 - 23 Jun 2011    Post subject: Reply with quote
See my assumption (correct or not) is that when I do the spokes in opposite directions on one side of the hub would get the hub to the right position of 'twistedness' in relation to the rim.
And then if I left the spokes nice and loose (which I did) there should still be enough play to join up the spokes on the other side.
The lateral position of the hub is going to be a bit of guess work. The hub does have a concave indent that I suspect will need to be true with the rim, but I can true that up afterwards.
The annoying thing is that I couldn't replace one spoke at a time because I needed to strip the hub and rim off completely in order to get them powder coated. And they were in such a state that they couldn't be removed.
What I will do next is remove all the spokes and make exactly sure what's what length. If some are a slightly different length that'll make all the difference.
Failing that, I'll try and see if I can fit the spokes that don't fit, first. If they aren't long enough to fit without any other forces, then it's a spoke length issue.
Gaz
Gazdaman
I did a trackday!!!
PostPosted: 14:23 - 24 Jun 2011    Post subject: Reply with quote
Vincent, that would be very useful. The part I'm interested in is which spokes don't have a 90 degree bend. Some of them have a more relaxed angle to the head, and I'm not sure where they're supposed to go.
The KE125 is the same too btw.
I have found that of the 27 90 degree spokes, 9 of them are slightly shorter. So chances are I've got the wrong length spokes in the wrong places.
Gaz
PostPosted: 14:30 - 24 Jun 2011    Post subject: Reply with quote
Gaz
Oh yeah, according to the CMM article, there are outer and inner spokes, but it didn't seem to explain which were which. It said the 90 degree ones were one type and the less ones were the other type, but as I said I don't know which way around they go.
Gazdaman
I did a trackday!!!
PostPosted: 15:39 - 24 Jun 2011    Post subject: Reply with quote
Gaz
That's my feeling, I think the more than 90 degree angled ones have the nipple facing outwards, because they then bend back on themselves slightly.
That would then free up 9 longer 90 degree ones to go on the other side. (Where my original ones weren't long enough).
Gaz
Gazdaman
I did a trackday!!!
PostPosted: 18:30 - 24 Jun 2011    Post subject: Reply with quote
Thanks for the offer buddy, that's proper dedication. I'm 80% sure I know how it should go, and even then, it won't take much trial and error to work it out.
But I appreciate the thought. And beware, now I know you have one, I'll be messaging like "Where does this bit go?".
Gaz
Gazdaman
I did a trackday!!!
PostPosted: 08:53 - 25 Jun 2011    Post subject: Reply with quote
Definitely of use. I'm aware they're quite different but there are a lot of interchangeable parts.
The bit in the manual would be useful!
Parts have been surprisingly ok. I even got a nos 2t oil pump and headlights. Then a rev counter from a 125. Which hopefully is usable, part number is very similar.
I do need an ignition switch, which is tough to get for the 1976 model.
And a decent exhaust is like gold dust.
Luckily my bike is mostly complete and ebay hopefully handles the rest.
Gaz
Gazdaman
I did a trackday!!!
PostPosted: 21:22 - 25 Jun 2011    Post subject: Reply with quote
Tried it again today
The relaxed headed spokes go on the inside of the drum brake side, then the shorter 90 degree headed ones go on the outside.
Then the 18 longest 90 degree headed spokes go on the speedo drive side.
All went together nicely, and I built a little jig to true it up when my key comes.
Thanks for the help guys.
Turns out it was option b, I'd fucked up.
Gaz
The last post was made 14 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 104.33 Kb
