1998 SRAD Help??
Englewood
PostPosted: 18:11 - 26 Jun 2011    Post subject: 1998 SRAD Help?? Reply with quote
Hi, Ive decied to look around my SRAD this afternoon after taking it for a good few hours ride.
Im new to bikes but i know when something dont look right well i think so lol.
Anyway, while i was looking over my engine and air intake i came across this hose all split and cracked.
https://i7.photobucket.com/albums/y279/englewood10/IMG_1170.jpg
Where can i get a replacement part from and whats it called Confused ?.
Also ive notice that it was connected to 2 little hoses via this little black tube.
https://i7.photobucket.com/albums/y279/englewood10/IMG_1172.jpg
https://i7.photobucket.com/albums/y279/englewood10/IMG_1173.jpg
Im guessing this cant be right!.
So ive had a look at the air box and it has 2 outlets for the air and one is blocked off and one was connected to the cracked hose and to the little black tube with 2 tubes going to it.
So im guessing this cant be right surely???.
Bezzer
PostPosted: 23:25 - 26 Jun 2011    Post subject: Reply with quote
This is the 'fiche, No13 is the "Control air pipe" what it does/connects to I haven't got a clue Question , it's part no 13855-34E50 if you want to order one from Robinsons Foundry it's £11.53.
The blocked off outlet on the airbox was like that originally must have been an outlet they were thinking of using for something but didn't in the end as the bung is also listed on the fiche (No 11).
https://www.alpha-sports.com/supr/1999%20GSXR600/02.gif
SirEdward
PostPosted: 00:39 - 27 Jun 2011    Post subject: Reply with quote
You shouldn't pay much attention, this looks to be a pressure 'release' hose/valve, like you would have on any pressurised system working with gas/fluids.
The water cooling system of the engine is a good example, it also has an overflow hose behind the LH fairing, it's connected to the coolant reservoir. Very Happy
"Beyond a critical point within a finite space, freedom diminishes as numbers increase. This is as true of humans as it is of gas molecules in a sealed flask. The human question is not how many can possibly survive within the system, but what kind of existence is possible for those who so survive.
Pardot Kynes in "Appendix I: The Ecology of Dune""
Englewood
PostPosted: 06:44 - 27 Jun 2011    Post subject: Reply with quote
Ah cheers pal thats cleared things up for me, well ive just taped the part up with electrical tape for now untill i get a replacement part.
Thanks for the info!.
SirEdward
PostPosted: 07:05 - 27 Jun 2011    Post subject: Reply with quote
That's quite interesting: you have a pressure release hose from the airbox in case the cam train stops for whatever reason, thus ceasing to operate the intake valves. While the petrol is not a problem, the air build-up due to the Ram Air Direct is - the air box can blow up, if you're going at high speed and the aforementioned happens. Smile
It also can be to prevent the above from happening, if you're going downhill at closed throttle. Razz
Englewood
PostPosted: 08:57 - 27 Jun 2011    Post subject: Reply with quote
I haven't taped up the air out let just the hose that's cracked and split, it still allows air in and out!.
The last post was made 14 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 50.34 Kb
