| Flywheel |
 Flywheel Two Stroke Sniffer
| mr jamez |
 mr jamez World Chat Champion
| tatters |
 tatters Exxon Valdez
 Posted: 16:51 - 25 Aug 2004 Post subject: |
your timing could be to far advanted or retarded and this would cause over heating l had this problem on a AF1 125 were the flywheel nut came loose and the flywheel rotated on the crank (ate the bushkey), check to see if the flywheel is set correctly on the right timing mark (just take the flywheel cover off) ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
 Posted: 01:59 - 26 Aug 2004 Post subject: |
Does an NSR have a thermostatic valve in it?
This is a heat sensitive valve that stops coolant circulating through the radiator until the engine reaches a certain temperature, it opens mechanically (differing metals expanding at different rates) when the temperature reaches a certain level. Most liquid cooled bikes have one in a compartment just below the radiator filler cap (although location varies) and if this was faulty, the bike would overheat very quickly. Test it by bunging it in a pan of boiling water and watching to see if it opens.
Check yer plug to make sure it isn't running lean.
Could be a blockage in the radiator? give it a run through with a flushing compound, available at most car spares places for a couple of quid.
If that is all OK, I would suspect the head gasket too. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Odie |
 Odie World Chat Champion
| Flywheel |
| Odie |
| Supersport |
 Supersport Derestricted Danger
| Supersport |
The last post was made 22 years, 60 days ago. Instead of replying here, would creating a new thread be more useful? |
