overheating problem
Flywheel
PostPosted: 14:35 - 25 Aug 2004    Post subject: overheating problem Reply with quote
hi thanks for looking
i have a problem where my ns125r keeps over heating every time i open the throttle all the way.The temperature will sudenly leap form normal to almost in the red.i dont know what the problem is.The radiator is full and the cooling system has been blead.The mixture is also correct.
Does anyone have any ideas?
cheers
mr jamez
PostPosted: 14:50 - 25 Aug 2004    Post subject: Reply with quote
Well as the coolant is full and the system is bled, it can only probably be the headgasket or the water pump. Not sure of the symptoms of a buggered water pump, but I think it would get hotter quicker than that. Get the bike up to temperature, if the hoses and rad are all nice and hot then the pump is working. Is it smoking a lot? the headgasket change is a 15 minute job, and costs about £8 for a new one. You just need to take the head off, clean the areas that mate with the gasket so all traces of dirt/gasket/crap are gone. Try not to get crap in the bore. Then just put the head gasket on the right way up and facing the right way, torque the head nuts up.
I would also clean up the temperature sensor (located on top of the cylinder head) incase that is dodgy. May also be a dodgy thermostat, put it in hot water, not quite boiling, it should slowly open up.
tatters
Exxon Valdez
PostPosted: 16:51 - 25 Aug 2004    Post subject: Reply with quote
your timing could be to far advanted or retarded and this would cause over heating l had this problem on a AF1 125 were the flywheel nut came loose and the flywheel rotated on the crank (ate the bushkey), check to see if the flywheel is set correctly on the right timing mark (just take the flywheel cover off)
PostPosted: 01:59 - 26 Aug 2004    Post subject: Reply with quote
Does an NSR have a thermostatic valve in it?
This is a heat sensitive valve that stops coolant circulating through the radiator until the engine reaches a certain temperature, it opens mechanically (differing metals expanding at different rates) when the temperature reaches a certain level. Most liquid cooled bikes have one in a compartment just below the radiator filler cap (although location varies) and if this was faulty, the bike would overheat very quickly. Test it by bunging it in a pan of boiling water and watching to see if it opens.
Check yer plug to make sure it isn't running lean.
Could be a blockage in the radiator? give it a run through with a flushing compound, available at most car spares places for a couple of quid.
If that is all OK, I would suspect the head gasket too.
Odie
PostPosted: 07:16 - 26 Aug 2004    Post subject: Reply with quote
Silly question (not yours) but is the temperature in the radiator actually rising?
It could just be a dodgy gauge?
Flywheel
PostPosted: 10:10 - 26 Aug 2004    Post subject: Reply with quote
Thanks for the help
Dont think it is the head gasket as it was replaced not that long ago and i cant see ant white smoke.
I checked the plug when it started to overheat and the inside looked fine but the metal bit that the spark jumps between was green for some reason, What does this mean? i also uped the jetting just iincase but it didnt make any didfference.
Not sure if the temperature sensor is nackered will checkk that today
Odie
PostPosted: 10:47 - 26 Aug 2004    Post subject: Reply with quote
Its infected? lol
No, not really, might be anti freeze?
PostPosted: 14:44 - 26 Aug 2004    Post subject: Reply with quote
You don't necessarily get white smoke when a head gasket is leaking, it can just be hot exhaust gas passing into the water jacket and emptying the radiator for you.
I would count recent top-end work as a possible reason for the gasket to be blowing unless you fitted it yourself and are perfectly happy the mating surfaces were clean, perfectly level and torqued down gradually and sequentially.
My mate got a bike back after a so-called motorcycle mechanic had done a top-end rebuild. Head gasket started blowing 200 miles later so we decided to do it ourselves (DOHC 4-stroke twin, so not something you do on a whim). Looked like they had removed the old gasket with a wire brush! Took four hours with a mirror and fine grinding paste to get the facings clean and level again (got a bit more power out of the engine too as a reward for all our efforts by reducing the squish).
Supersport
PostPosted: 16:13 - 26 Aug 2004    Post subject: Reply with quote
I'm the guy who fitted the head gasket and I can assure you that it most certainly is not leaking. The surfaces were thoroughly cleaned and properly torqued down. There is no coolant leak nor is there excessive pressure in the radiator so I'm fairly sure that the problem is not down to a head gasket leaking.
Bleeding doesn't seem to have helped so I have to consider that it might be the water pump, some restriction to flow through the radiator or more likely the thermostat sticking partially open but I haven't had a chance to look at it yet - hopefully this weekend.
PostPosted: 22:11 - 26 Aug 2004    Post subject: Reply with quote
Going with the above suggestions, but also a nice simple one first. Are you using too strong a mix of antifreeze / water? Had this with my RS125 and the resulting mix was too viscous for the impellor to pump round. Fine at idle / low speed, but as speed increased the temperature shot up yet the radiator stayed only just off cold.
Supersport
PostPosted: 15:15 - 27 Aug 2004    Post subject: Reply with quote
Just to put a new complexion on this. I have spoken to flywheel about this problem. It seems that at full throttle and fast speeds there is no overheating problem. The problem occurs when he slows down after a high speed run. Seems to me that the cooling system is depending on airflow to keep temperatures down (naturally) but can't keep up when the airflow drops. Some sort of restriction to flow might be the cause, thermostat not fully opening or radiator blockage. We'll try to sort it out at the weekend.
The last post was made 22 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.09 - MySQL Queries: 13 - Page Size: 71.94 Kb
