Side Stand cut out
Kai.Wilson
PostPosted: 12:03 - 01 Jul 2011    Post subject: Side Stand cut out Reply with quote
Bikes got a side stand anyway to by pass the switch so it still runs with stand down?
Reason being i do alot of on off bike would be easier with out sidestand
Kai
P.S Good to be back!
PostPosted: 12:05 - 01 Jul 2011    Post subject: Reply with quote
Just cut the wires and join them together.
Kai.Wilson
PostPosted: 12:23 - 01 Jul 2011    Post subject: Reply with quote
Deffintly work dont wanna me left without bike lol
Kai
PostPosted: 12:28 - 01 Jul 2011    Post subject: Reply with quote
Yes, done it on plenty of bikes, get the sidestand switch...cut the wires and get rid of the switch, join the wires and it would "make" the circuit as if the switch was pressed.
Win
Kai.Wilson
PostPosted: 12:31 - 01 Jul 2011    Post subject: Reply with quote
Cheers paddy <3
Kai.Wilson
PostPosted: 12:33 - 01 Jul 2011    Post subject: Reply with quote
Whats best way to join? strip and tape? x
hazza
PostPosted: 12:39 - 01 Jul 2011    Post subject: Reply with quote
bullet connectors.
PostPosted: 12:40 - 01 Jul 2011    Post subject: Re: Side Stand cut out Reply with quote
Kai
Until you forget one day, turn into a corner and end up on your arse.
herulach
PostPosted: 12:59 - 01 Jul 2011    Post subject: Reply with quote
Surely the side stand switch only cuts it if in gear with stand down? Can't see why you'd need that particular configuration for anything on a regular basis.
Are you sure it's not the neutral switch that is buggered?
If you're going to cut the cables get a multimeter and check its definitely supposed to be closed with the stand up.
YBR 125>FZS600
Kai.Wilson
PostPosted: 13:09 - 01 Jul 2011    Post subject: Reply with quote
it's a twist and no go Sad
PostPosted: 13:23 - 01 Jul 2011    Post subject: Reply with quote
Stripped, soldered an taped up my one. I do some half arsed bodges sometimes though..
PostPosted: 14:14 - 01 Jul 2011    Post subject: Reply with quote
You don't have to cut anything. Just unbolt the switch, and tie it up somewhere out of the way. Grease and bag it to protect it from corrosion while you're at it. Job done.
PostPosted: 14:18 - 01 Jul 2011    Post subject: Reply with quote
Depends what type of switch, with my stand up.. it pushes the button on the switch in. So if I just take off... it will still do it.
Fairies attack This post is not being displayed because the poster is banned. Unhide this post / all posts.
The last post was made 14 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 77.47 Kb
