Piaggio Typhoon 50 problems
CraigS
PostPosted: 14:01 - 01 Jul 2011    Post subject: Piaggio Typhoon 50 problems Reply with quote
Hey, i'm new to the forum and i'm seeking advice on my Typhoon 50, i hope somebody can help.
I personally don't know much about motorcycles/mopeds and don't have any experience with them, but basically i brought a Piaggio Typhoon 50cc bike (year 2000) from somebody and with it it had a fitted 70cc cylinder kit, this seized up (i was pretty much sold a duff bike i think) and i couldn't change the piston or anything as there were loads of threaded bolts on the engine so it was almost impossible to get to anything.
So i decided okay, i'm going to buy a whole standard 50cc engine for the bike, so i got this and fitted it and the bike runs, however...
When the bike is running initially the acceleration is okay when i first go to pull away and it picks up to about 20mph fairly quickly, then you can hear the decrease in the acceleration sound and it won't go past 25mph and eventually it will drop down. If i'm lucky when i first pull away and don't let go of the throttle the bike will get up to 40/45 mph but the second i slow down the bike really struggles to accelerate. After about 5 minutes of the bike running it will cut out, it will start back up but i won't be able to get past 25mph and it will just cut out again.
I think it's something to do with the carb, but like i said i don't know enough about them to know.
If it accounts to anything the bike has a Hebo air filter and a Leo Vince ZX pipe.
Anybody got an idea of what the problem could be? and why the sudden lack of acceleration then die.
Thanks
joshdudeha
PostPosted: 18:45 - 01 Jul 2011    Post subject: Reply with quote
When you bought this engine, did you buy it with a variator/pulley/clutch as well or just the barrel and piston?
It could be that the rollers in the variator are squared off and are delivering no power to you.
It could also be a fuelling problem.
It'd be easier (imo) to look at the rollers. If they're fine then definitely take a look at the carb and clean it out if need be with compressed air and carb cleaner. Make sure the jets are lovely and clean. Take a look at the air filter too, could be clogged.
Piaggio Zip 50 -> Yamaha YBR 125 -> Kawasaki GPZ500S '96 -> Suzuki GSF600N Bandit -> Honda CBR 600FW
Theory Test: 13/07/2011 Passed! | Mod 1: 27/07/2011 Passed! | Mod 2: 17/11/2011 Passed!!!!!
CraigS
PostPosted: 21:57 - 01 Jul 2011    Post subject: Reply with quote
If the rollers were squared off would it still give me the power i get, for example when i first go to pull away without letting go of throttle i can reach around 45mph, but then as soon as i slow down and go to accelerate it won't do anything and then it will gradually lose power and then just cut out, ive had another look at the carb tonight, cleaned it etc and the air filter is also clean and i the problem still persits, i just don't understand why it cuts out?
also it did have clutch etc, was a full engine just didn't have carb
Thanks for your help by the way buddy Smile
joshdudeha
PostPosted: 22:17 - 01 Jul 2011    Post subject: Reply with quote
You'll probably have to wait for someone more knowledgeable to reply but I think that rollers could be a problem. It is strange that it accelerates if you hold throttle wide open.
It may be the rollers or the clutch at the other end. Have a look inside the case, it takes about 10 minutes to get the case off. Take a look at the rollers and clutch.
Also, maybe the carb isn't jetted correctly? (just thought of this).
If it is really struggling, might be running rich.
Anyway I'm not great with this, just trying to help but someone else will be better at helping Smile
thomp1983
PostPosted: 12:41 - 03 Jul 2011    Post subject: Reply with quote
if the bike has had a 70cc kit on it then the carb probably now has the wrong size jets in it for the 50cc lump you've fitted. take your carb apart and check if the jets have any size markings on them, if they do post them up here and ill compare them to the workshop manual i have
CraigS
PostPosted: 18:12 - 04 Jul 2011    Post subject: Reply with quote
i will do this shortly, thanks!
also what spark plug should i use for typhoon?
joshdudeha
PostPosted: 18:53 - 04 Jul 2011    Post subject: Reply with quote
Damn! didn't even see you had a 70cc kit fitted *doh*.
Yeah as said, definitely check the jets then!
The last post was made 14 years, 281 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 55.06 Kb
