CBR 600 engine chatter
Ditto
PostPosted: 18:43 - 04 Jul 2011    Post subject: CBR 600 engine chatter Reply with quote
Only had this bike a few days so a bit unsure Confused
Basically at around 5K (Maybe more, cant hear above that with the wind) there is a noise from the engine. Sounds like someone chattering their teeth together really fast.
It also happens when engine braking.
Is this the infamous CCT problem? I'm hoping its that and not valves out of spec.
CBR 600, 2000, 15K miles
Cheers!
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
UnknownStuntm...
PostPosted: 20:21 - 04 Jul 2011    Post subject: Reply with quote
Camchain tensioner. Is quite straightforward to fix apparently.
Noxious89123
PostPosted: 21:53 - 04 Jul 2011    Post subject: Reply with quote
Mine is very noisy at 5k, never been an issue tbh. It has gotten a little noisier lately, however my bike is at 31.5k or so, and is due a vavle adjustment.
PS. Update your sig Wink
Ditto
PostPosted: 22:28 - 04 Jul 2011    Post subject: Reply with quote
Nice bike by the way, I like the colour scheme Wink
Yeah valves could do with checking aswell. I was just hoping it was the CCT rather than valves tbh.
Also im hearing mixed reports. Some people are saying if the CCT is rattling its bad news, the timing could slip and I should sort it ASAP!
Others are saying its just blocked with oil, could do with a clean but in the meantime its just slapping about inside the engine Confused
Which am I supposed to do?
temeluchus
PostPosted: 22:38 - 04 Jul 2011    Post subject: Reply with quote
If its constant its more likely to be the valves.
If it comes and goes when revving up and down I'd say the cct.
Ditto
PostPosted: 22:42 - 04 Jul 2011    Post subject: Reply with quote
Yeah its only really noticeable when engine braking to be honest.
DrDonnyBrago
PostPosted: 08:21 - 05 Jul 2011    Post subject: Reply with quote
Mine has a rattle at 5k due to CCT. It's on it's 3rd now: If I had known the previous owner had changed it for the "uprated" one I wouldn't have bothered.
It's a bit noisy but Idon't believe it is a dangerous noise, just an annoying one.
Mine is also louder when coming down to 5k, comes from the RHS of the engine and sounds like a load of bolts rattling in a frying pan.
PostPosted: 09:54 - 05 Jul 2011    Post subject: Reply with quote
Its so simple to replace, just buy it.. you are only a few miles from me... I'll fit it if you want Laughing But seriously.. pop plastic dress off and swap over. Simple as Mr. Green
DrDonnyBrago
PostPosted: 11:01 - 05 Jul 2011    Post subject: Reply with quote
Have you changed one on that model CBR?
You need a hand like jeremy beadle and a series of socket bends and extensions going through a hole in the frame to undo them. It's a simple albeit very annoying job Smile .
PostPosted: 11:05 - 05 Jul 2011    Post subject: Reply with quote
Nothing can be as bad as some of the shit i've worked on... Should try my cars 3 hour spark plug change Laughing
The last post was made 14 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 64.66 Kb
