| proximity |
 proximity Crazy Courier
 Posted: 23:50 - 04 Jul 2011 Post subject: DR350 running lean problems |
Hi all,
I bought a DR350 and rebuilt it as it was cosmetically not great. Now that its finished i'm having trouble with it running lean.
It misfires over about 75% throttle and doesn't like high revs. The airbox has had its snorkle cut out, which according to everything I read on the net suggests it needs a 140 main jet. It currently has a 142.5 main jet and 40 pilot. I have checked that the carb is clean.
It has the mikuni pumper carb.
It runs hot, so hot that last time I went out on it, it melted its side panel, and burnt out the stator. The exiting exhaust gas it also really hot even at idle, it will burn your hand. It pops on decel a lot.
I'm quite confused because it is jetted richer than any other DR350 I have read about on forums, it even has the stock exhaust.
I taped off part of the airbox inlet as a test and it runs much better at the top end, no stumbling, but seems a bit rich down low like this. I have also lowered the carb fuel height as it was quite high (I know this only makes it leaner, but I thought its best to have things as they are supposed to be).
Lowering the float height has introduced a new problem whereby the idle is so low that it often stalls when coming to a halt, BUT it also hangs at about 4000rpm or so, I either get this, or it stalls. I cant win.
Any help would be MUCH appreciated as I'm not sure what to do next, I could up jet but people don't seem to even need 150 mains with a free flowing exhaust let alone the stock one. Also the guy that had it before me ran it like this for 7 years, so I doubt it had this issue for him.
Jason ____________________ 2004 Aprilia Tuono |
| P.addy |
 P.addy Red Rocket
| Bezzer |
 Bezzer World Chat Champion
| proximity |
 Posted: 19:58 - 05 Jul 2011 Post subject: |
I have attached a pic of the plug after I did a chop after holding high revs and throttle for about a minute, just around where it does its thing of pretending to be out of fuel.
I'm not one to be identifying plug colours but to me it doesn't look too bad, though i'm unsure of why it has black speckles on it?
The pic is from a phone and the colours are a bit off, it actually looks more grey and less like a brown colour in real life.
https://i54.tinypic.com/i4fxc8.jpg ____________________ 2004 Aprilia Tuono |
 ---- World Chat Champion
| proximity |
 Posted: 21:24 - 05 Jul 2011 Post subject: |
Have a read through the tech pages over at Maximum suzuki
They have covered most issues with these bikes and were helpful when i was asking about jetting...
Coil on ebay for about £10 Clicky
Parts are cheap as fuck for these bike  |
| proximity |
| proximity |
 Posted: 10:37 - 06 Jul 2011 Post subject: |
I'm sure there are plenty with the likes of hamsterly forest etc, I just haven't found them
I thought about joining the TRF to get to know some decent lanes, just haven't got round to it yet. ____________________ 2004 Aprilia Tuono |
| proximity |
| waffles |
 waffles World Chat Champion
| proximity |
| proximity |
 Posted: 00:28 - 10 Jul 2011 Post subject: |
Found this little chart, I think my jet marked RD could be one of those Precision engineering jets.
https://faq.ninja250.org/wiki/Dynojet_-_Mikuni_-_Keihin_jet_sizes_conversion
Unfortunately the chart doesn't go big enough to find out the drill sizes I need to make it right
Edit: that can't be true as it would mean the jet is 1.425mm, which it isn't, its more like 0.95mm ____________________ 2004 Aprilia Tuono |
 Posted: 09:42 - 10 Jul 2011 Post subject: |
Get to a local dealers and buy (even in the cheap make) a few different jet sizes.
142.5, 145, 147.5 should do ya
I have no idea about the needle but you said yourself, you put in another jet and it ran better...
Carb jet's are literally about £1 each so it's no real expense
edit: Actually i still have a few sizes here. I think i have 137.5 standard, a 140, 142.5 and i think a 147.5.(maybe 145 not sure which i used now.
You can have them if you come and get them, but it'll probably cost you less to go to a dealers (petrol to get here) |
| proximity |
 Posted: 21:48 - 18 Jul 2011 Post subject: |
Right well i'm about at breaking point with this now, it's one thing after another.
I ordered a new 5 position needle and range of jets to suit. Fitted them, went for a ride. Piece of shit.
Seems to be down on power quite a bit, no lean bog at the top end but instead a sort of stutter like it is misfiring every second or so.
That's not the biggy because I can rectify that by playing with the jets some more, what is the main problem is the bike will not run below what I am guessing is about 1500 - 2000rpm (I have no tacho).
It will idle, but any amount of throttle about about 10% will cause it to stall, it makes it almost impossible to ride, it stalls in a way that if I let off the throttle when it is stalling it will pick back up again.
If I am riding up a hill for example, as the revs slowly drop, 2000rpm its pullling fine, revs drop slightly and then BAM hit a brick wall like I have hit the kill switch, let off the throttle and it comes back.
Same with going down a hill, open the throttle, nothing, bike is coasting like the key is off, rolling down the hill picking up speed, I hit 2000rpm and shazam shes away again.
It confuses me that it is RPM related. I suspected ignition because it just seems like it gets no spark under load at low RPM, but I have checked the spark as I suspected this, but by adding a second gap to the lead to see a spark, I could see that the plug is still firing when it does this 'issue'. I rewound the stator while waiting for the jets to come, but didn't touch the hall sensor or CDI coil.
Lifting the needle didn't help. I seriously don't know what to do with it.
I would really really appreciate some help. I like the bike a lot, but I have had it in bits so many times it's at the point where I just want to sell it and move on. No I lied, I want to burn it.
The last post was made 15 years, 87 days ago. Instead of replying here, would creating a new thread be more useful? |
