Mod 1 - Failed: UPDATE - failed again :-(
Intruder_Andy
PostPosted: 18:42 - 06 Jul 2011    Post subject: Mod 1 - Failed: UPDATE - failed again :-( Reply with quote
Hi guys, had my mod 1 today on day 2 of my DAS and locked up the rear wheel on the emergency stop - instant fail. Well gutted. Anyways just thought I'd let you all know.
Andy
Bike Bunker
PostPosted: 18:47 - 06 Jul 2011    Post subject: Reply with quote
Ahh no waay gutted Sad
Goodluck next time Thumbs Up
Jodie
PostPosted: 19:51 - 06 Jul 2011    Post subject: Reply with quote
Try not to let it get you down Andy, you've seen on this forum how often it happens.
Get it booked straight away and good luck next time Thumbs Up
rtho782
PostPosted: 20:04 - 06 Jul 2011    Post subject: Reply with quote
I was having this problem in mod1 training.....
Then I did as a biker friend suggested, cover the back brake but don't put any force on it at all, do all your breaking with the front.
As long as they think you are using the back as well it is fine, the front has more than enough stopping power.
The E-Stop isn't really much of an E-Stop, more of an "unplanned" stop, that is, control is more important that "fuck me I need to stop NOW or I will get run over by that train"
maccidees2002
PostPosted: 20:38 - 06 Jul 2011    Post subject: Reply with quote
I was given that advice off a few peeps off here when I got stuck in the habit of hitting the back brake too hard on practice runs.... worked a treat on the day so all good.
Good luck with the retry Thumbs Up
Theory= 11/3/2011 , C.B.T= 11/3/2011 , Mod 1= 14/3/2011 , Mod 2 18/3/2011.
Bikes= 1992 xj600s & 1998 cbr600
PostPosted: 20:45 - 06 Jul 2011    Post subject: Reply with quote
Bad luck on the fail. Shrug it off and learn from it. As above said. Just cover the rear brake. When you apply the front brake your weight will shift enough to push the rear brake down all you need.
SnowTigeress
PostPosted: 22:07 - 06 Jul 2011    Post subject: Reply with quote
Bad luck...............I also failed my mod 1 today also................but i locked the front wheel and ended up on the floor..... Embarassed
Hope you dont have to wait to long for a retest...........and Good luck with it...........
Ive booked in for it again on monday on my own bike.
Real bikers build their own Renovated and Riding a 1986 Honda CB125TD-C called the Pup. Full Licence
13/09/2012, 1994 Moto Guzzi 750 Strada
Can-Do Girl that does spanners TOO!
TheSmiler: binning it is better than going around a roundabout the wrong way
MadCatLady
PostPosted: 23:01 - 06 Jul 2011    Post subject: Reply with quote
Don't let it get to you. Best of luck for next time Thumbs Up
McFlufferson
PostPosted: 01:33 - 07 Jul 2011    Post subject: Reply with quote
That's harsh. Seriously though, like it's already been said a hundred times, it happens to so many people.
Oldie
PostPosted: 20:04 - 08 Jul 2011    Post subject: Reply with quote
Yeah, bad luck folks. Just gotta keep plugging away and it'll be over with Thumbs Up
Intruder_Andy
PostPosted: 17:02 - 05 Aug 2011    Post subject: UDATE - Failed again! Reply with quote
Re-booked, got thru emergency stop ok, peged it thru the speed trap for the swerve (65kph!!!!) and lost it when I tried to stop after the swerve, locked it up, fishtailed it and ended up 10 yrds past the cones. BUGGER! Just cant seem to get the stopping technique right!
SweenyT
PostPosted: 17:37 - 05 Aug 2011    Post subject: Reply with quote
That's rough mate.
Sounds like you went into a kind of 'oh crap' mode when you had to brake. I did that yesterday day when I had to stop sharpish and locked the back wheel (2nd time in 2 years) but I wasn't concentrating Embarassed
You know how to stop okay otherwise you wouldn't have managed the emergency stop. Just keep practising stopping and remember on the swerve after you come through the trap, come off the throttle and let your speed carry you through the swerve and down the straight to the box that way you can come to a slower more controlled stop with less brake.
Good luck on the re-take.
Current ride - 2005 Suzuki GSX-R600 K4 - 2x 2014 Honda NC750s long term courtesy bikes - 2003 Fazer FZ6 written off as idiot reversed into me - 2009 YBR125 - still have from new
ThatsTheBadge...
PostPosted: 05:04 - 07 Aug 2011    Post subject: Reply with quote
The Mod 1 wants getting rid of!
When I did mine my Instructor advised that when you use your front brake it's about 70-80% of your braking force and that you should apply then squeeze to brake harder, just gently covering the back brake, that way you won't lock the back wheel and you stand less chance of locking the front which is a lot more dangerous.
It's a good way of doing it, and works well. Panic braking is so easy to both on test and out on the road!
You will do it, be positive and just keep focussed that you'll soon have that pesky Mod 1 Certificate!
Biker Alex
PostPosted: 11:23 - 07 Aug 2011    Post subject: Reply with quote
I locked up twice on the 'emergancy stop', I couldnt understand it. I went away TRYING to lock the back wheel up at home but I couldnt.
Anyway, so I loosened up the rear drum brake when I got the the test centre. There was no way I could of locked it.- I passed after this
what pissed me off was when I finished, some guy did the stop but it was like 5x the stopping distance as me. I was like WTF and they said it is a CONTROLLED STOP not an emergancy stop. An instructor even said you could go to the fence if you wanted.
Try and find a post on here where someone has failed because they did not stop in a short enough distance. I couldnt find one.
But you do have to stop in the box when you do the swerve
In both instances roll off the throttle as soon as you have done the speed trap but just incase I would practice this and see if you are comfortable with the engine braking whilsts doing a swerve. I didnt even need to use the brakes when stopping in the box.
95Theses
PostPosted: 11:44 - 07 Aug 2011    Post subject: Reply with quote
cover your back brake with your big toe, nothing else.
80% front 20% rear. It's not that hard really and it is good practice for being on the road. I stopped well short of the examiner in the pouring rain after passing the speed trap at 59 KPH so it can be done.
pits
PostPosted: 10:41 - 08 Aug 2011    Post subject: Reply with quote
I didn't use hardly any back brake when I did my mod 1, I came from riding a 2 stroke with awful brakes and no engine braking, so I have no problems grabbing a large handful of front brake, the more weight you have on the front, the less likely you are to drop it, my technique was to get hard on the front, then ease it off slightly and apply a tiny dab of rear, if you are locking the rear up you are using too much back brake, and if you do it on the road chances are that skid will turn into a drop.
Not going to say you wont drop it, but be a bit more assertive on the front, Thumbs Up
PostPosted: 10:48 - 08 Aug 2011    Post subject: Reply with quote
This.
The natural weight shift when you hit the front brake will cause the rear brake pedal to depress just enough to activate the brake without locking the wheel up. Get out and practice in the empty streets around your house.
Intruder_Andy
PostPosted: 17:17 - 24 Aug 2011    Post subject: Reply with quote
Hi all thanks for the replies, i understand the technique to be used and as stated I did emergency/controlled stop ok 2nd time round.
I just need to practice but on a 500 with reard disc brake as I have a 125 cruiser with rear drum brake which takes al ot more pressure to activate so practicing on this won't really help much to get the correct technique fine tuned.
Think when i rebook mod 1 again i'll ask for an hours practice session before hand as well to get used to the bike a bit.
Thanks again all,
Andy
Codemonkey
PostPosted: 18:28 - 24 Aug 2011    Post subject: Reply with quote
Never mind, keep trying, you'll crack it in the end! Took me 3 attempts then passed Mod 2 1st time no problems. Practice is definitely the key Thumbs Up
Test Passed 10/05/2011 Current bike: XJ6-N
SweenyT
PostPosted: 23:55 - 24 Aug 2011    Post subject: Reply with quote
Intruder_Andy wrote:
.........Think when i rebook mod 1 again i'll ask for an hours practice session before hand as well to get used to the bike a bit
+1 I would say that's a definite plan.
bikesplash
PostPosted: 09:57 - 26 Aug 2011    Post subject: Re: Mod 1 - Failed: UPDATE - failed again :-( Reply with quote
Andy
oh dear! Sorry to hear that Sad
Sherwood Bambi
PostPosted: 11:50 - 26 Aug 2011    Post subject: Re; MOD 1 Reply with quote
Sorry to hear that - bad luck !
Keep at it - you'll get there in the end I'm sure.
Did you get the chance to practice on the Test Centre yard before hand ?
When I did mine we had a couple of hours booked by our instructor on a Sunday afternoon - it made all the difference on the day !
trikeschick
PostPosted: 21:46 - 26 Aug 2011    Post subject: Reply with quote
Took me four times to pass Mod 1 and like Codemonkey passed Mod 2 first time! I really do believe that those extra Mod1 lessons contributed to my Mod2 skills and confidence.
Keep going, keep learning and you will be fine!
"Light travels faster than the speed of sound, which is why some people appear bright until they speak"
The last post was made 15 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 120.67 Kb
