Noise testing
Bob R1
PostPosted: 14:58 - 09 Jul 2011    Post subject: Noise testing Reply with quote
Thinking of doing a track-day this year on my new bike,it has loud exhausts ,so before booking would like to get it noise tested incase it fails,Brands is my local track,am I allowed to go along to a track-day and get it tested even though I,m not actually booked on ,on that day? cheers Bob,...
Deano
PostPosted: 16:22 - 10 Jul 2011    Post subject: Re: Noise testing Reply with quote
you'll be fine just queue and get it tested, they wont say no, I know others who have done it. So go for it.
Dean Stone #777
EMRA 2012 final standings, Formula 600s 3rd, Superstock 600s 3rd.
www.triplesevenracing.co.uk: www.ljmotorcyclerepairs.co.uk www.gettaylored.co.uk BN RaceScience, Now officially run out of money to carry on racing Sad
swiftb
PostPosted: 19:34 - 10 Jul 2011    Post subject: Reply with quote
the bike ive just bought for track use has a scorpion end can - and has been jetted to suit - ive booked in on a trackday at donny (2hrs away) and im now worried that im gonna get there and get tested and be turned away! its 98db limit.
The exhaust doesnt seem too loud and on some receipts theres a receipt for a db killer but need to have a look in garage tommorow see if this is fitted or not (on first glance i dont think it is).
Do any mot places etc have facilites to test noise levels??
EDIT just checked - hole drilled in spout - no db killer Crying or Very sad I see there on ebay so wonder if some universal thing will fit - just hope it makes it below 98db without causing any running problems Thinking
Deano
PostPosted: 13:04 - 11 Jul 2011    Post subject: Reply with quote
Most local garages can noise test as its part of the MOT testing.
TBH if the can is a problem just put the stock one on or get a baffle sorted beforehaqnd as most tracks with the exception of Donnington you will really struggle to find a baffle for the day.
I have a universal one for emergancys and stuff a rag over it help with the baffling which has worked so far.
Dean Stone #777
Joeb46
PostPosted: 22:15 - 12 Jul 2011    Post subject: Reply with quote
Swift the donny trackday is 98 db ride by. not a static test, best to take a baffle with you but you should be ok for 98 db.
If not the emergency coke can baffles work well Smile
Current- Drz400sm- For sale
Kawasaki er-5 race bike# 106
swiftb
PostPosted: 22:24 - 12 Jul 2011    Post subject: Reply with quote
yeh ive read that but still a bit worried! Surprised I read somewhere that they may test BEFORE track time starts so this would obviously up close and personal with the bike. Id rather quash any doubts and get hold of a standard can but for some reason for this model people want stupid prices for an original can - even ones that are dented/roadrashed to hell.
I put a socket in the end of the 2" exit tonight which was a nice snug fit - leaving a 3/8" exit hole Laughing Made a massive difference so maybe a db killer will do the trick Thinking
Do they have any services at the track who can help you out if too loud??
PostPosted: 23:58 - 12 Jul 2011    Post subject: Reply with quote
Didn't think the MOT stuff specified a value - it's down to the tester's discretion - I've never seen a sound meter being used and have had quite a few fail then pass with a baffle, etc.
Deano
PostPosted: 10:57 - 13 Jul 2011    Post subject: Reply with quote
OK maybe Ive been misquoted as I was under the impression that was the case.
swift when I went to donny there was no static testing, you were just red flagged if you were too noisy on the fly by.
Dean Stone #777
swiftb
PostPosted: 20:52 - 19 Jul 2011    Post subject: Reply with quote
got all the info emailed over for the donny 98db day and says there will be noise testing BEFORE any bike goes out on track, -
ive now fitted a standard can but the things still fairly noisy , main bulk of the noise is coming from the downpipe area - it has aftermarket stainless steel downpipes as a replacement for the rotten standard ones - but as its stainless steel (and fairly cheap looking) its quite noisy (did have a small crack which was blowing ever so slightly but gungum took care of that).
This is with the fairings off also. Both fairings back on should eliminate a little noise.
Where exactly do they hold the tester when static? behind the end can spout?
Im hoping this should pass without issue but got a paranoia on now as dont want to get kicked off my first day! Crying or Very sad
Anybody know what your average (old) 600 kicks out roughly noise wise? or anyone had a standard cbr tested
PostPosted: 21:18 - 19 Jul 2011    Post subject: Reply with quote
Usually it is behind the endcan - they often have the tester on a stick to measure a metre, or whatever from it.
Tenko
PostPosted: 23:46 - 29 Jul 2011    Post subject: Reply with quote
I did one last year at Cadwell on a bike that failed the noise test. Mine was the only one too. Those nice chaps still let me out though - seems they do have discretion...
Souleh
PostPosted: 03:42 - 30 Jul 2011    Post subject: Reply with quote
[quote="swiftb38"]
My 03 636 was tested at 102db but its a carbon micron (54mm) with no baffle.
swiftb
PostPosted: 10:55 - 30 Jul 2011    Post subject: Reply with quote
Well there was no static testing - was fly by only which was recorded on the pit straight, some unbeliveably noisy bikes that were getting on fine, few black flags for too much noise but think this was mainly people trying there luck without baffles fitted. Would of gotten away no probs with just a baffle so know for next time anyway!
The last post was made 14 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.21 - MySQL Queries: 13 - Page Size: 80.08 Kb
