| pepperami |
 pepperami Super Spammer
 Posted: 21:46 - 06 Jul 2011 Post subject: Getting bearings off a yoke spindle HELP! update! |
OK ! so the great Sachs XTC saga continues
Well today I took the front wheel out and dropped the forks, no major issues there thankfully
After a bit of swearing and cursing the yokes finally let go , the top bearing looks and feels to be in good order.
However the bottom bearings are absolutely f*cked.
I`ve got a new set to go in, but the bearing shell in the head-stock and the bearing on the bottom yoke just refuse to let go (bi-metalic corrosion I suspect).
So mighty BCF!, I seek your advice , how do I get them out without destroying the yoke and head-stock? ____________________ I am the sum total of my own existence, what went before makes me who I am now!
| Raffles |
 Raffles World Chat Champion
| temeluchus |
| robocog |
 robocog Traffic Copper
| andys675 |
 andys675 World Chat Champion
| stinkwheel |
 Posted: 23:13 - 06 Jul 2011 Post subject: |
It's a complete bastard of a job. Just keep at it. A good sharp drift for the one in the headstock is invaluable, if the edges are rounded, face it off again with a file.
The bottom one will let go eventually. I usuaslly prise it off with a pry bar and/or a cold chisel and hammer, just keep working round and round. Do not expect to retrievve the dust seal intact.
If you have access to a welder, run a ring of weld round the race in the headstock and it'll either drop out or shatter when you hit it with a hammer. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| pepperami |
 Posted: 20:12 - 08 Jul 2011 Post subject: |
Much thankness for your replies folks  ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| pepperami |
 Posted: 22:37 - 08 Jul 2011 Post subject: |
Well that`s the bearing off the yoke done with a mixture of heating and cooling + some bashing , no damage done to the yoke or the yoke stem .
Now for the shells in the headstock . ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| pepperami |
 Posted: 17:20 - 10 Jul 2011 Post subject: |
Well I got the bearing off the yoke and the bearing guides/shells out of the head-stock...........so far so good,
Now I find a problem , the top guide/shell went in as it should ie a tight/firm fit.
However the bottom guide/shell just pushed in and appears to be a tiny bit loose? .
So either I have wear in the head-stock or the bottom bearing is a different size?
I have looked in the manual and I can see nothing about diffreing sizes of bearing on the yoke or in the head-stock?.
so mighty BCF , what did you do when the head race bearing were a bit loose?, did you pack them? what with? ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| stinkwheel |
 Posted: 19:23 - 10 Jul 2011 Post subject: |
Sure you have them the right way round? (ie. bottom in bottom and top in top?)
If it's just a bit loose (as in not rattling), you can use bearing fit compound which essentially glues it in place.
That said, as long as it can't move and rotate in the seat, it ought to be ok. It can't drop out when it's all assembled ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| kestrel |
 kestrel Nearly there...
| Ariel Badger |
 Ariel Badger Super Spammer
| stinkwheel |
| Pete. |
 Pete. Super Spammer
 Posted: 11:13 - 11 Jul 2011 Post subject: |
Loctite bearing fit or a similar product would be fine. They specify a minimum 2 thou gap anyway. ____________________ a.k.a 'Geri'
| pepperami |
 Posted: 21:00 - 11 Jul 2011 Post subject: |
Well I have been doing some research and I definately have the right bearings and I am putting them in the right way!
Talking to the owner reveals that the front end has been messed around with at some time in the past and crashed .
I`m guessing that the front end was`nt tightened up properly last time and this has caused wear and tear on the bottom hole of the head-stock.
I take on board what you chaps say about bearing-bond, this may be the solution........... I hope (fingers crossed) ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
The last post was made 15 years, 110 days ago. Instead of replying here, would creating a new thread be more useful? |
