Decals removal
duncanpage
PostPosted: 18:07 - 28 Jun 2011    Post subject: Decals removal Reply with quote
Hi all
I searched these posts and tried the recommendation of using WD40 and elbow grease to remove the stickers.
I found UPVC cleaner worked better on the plastics but even using a hairdryer wouldn't budge the stickers on the tank.
Picking them off with my finger nail is taking forever and hurts as I keep getting bits stuck under there! PLus I don't have long nails and I'm not willing to wait for them to grow!
Does anyone have any other suggestions on how I could remove the tank decals?
It's a GPZ500 D3 1996. They've obviously been on a long time (15 years!)
Many thanks
Duncan
kerr
PostPosted: 18:38 - 28 Jun 2011    Post subject: Reply with quote
try boiling water, and t cut colour restorer to get rid of the glue and "ghosting" underneath.
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
tutton
PostPosted: 19:06 - 28 Jun 2011    Post subject: Reply with quote
Usually tank stickers in peticular are laquered so need to basically be sanded off as there sealed in.
delsol
PostPosted: 20:29 - 28 Jun 2011    Post subject: Reply with quote
Fast way:
DIY Hot Air Gun, set to high output (to soften the backing adhesive), then peel back decal.
Copious aerosol brake cleaner or brake & clutch cleaner to remove guey residue (have lots of small soft rags).
TCut as required (have lots of small soft rags).
delsol
Wyldkat
PostPosted: 19:22 - 29 Jun 2011    Post subject: Reply with quote
+1
I had this with my tank, tried scraping off with a blade; tried hair dryer; tried petrol on a rag - in the end, good old medium/high grit sandpaper done the trick.
It most probably will leave some scratch marks in the tank but if you go gently, then use a fine grade paper to finish off. Assuming you're re-painting, using a Hi Build/Filler primer will help with any fine scratches.
Oldie - 1987 Suzuki GP100 SOLD!
Current (as of 12/7/12) 2001 Honda Varadero 125
bagger
PostPosted: 21:22 - 29 Jun 2011    Post subject: Reply with quote
ive just taken some off was easy Wink but i was using a belt sander Razz
sv650s,cb350s
terrypaul02
PostPosted: 13:53 - 30 Jun 2011    Post subject: Reply with quote
i took the decals off my tank, and it took hrs ,i used a plastic ice scraper so as not to scratch the tank and lots of t cut polish and elbow grease Smile did work and looks great
duncanpage
PostPosted: 20:35 - 12 Jul 2011    Post subject: Reply with quote
I finally did it!
Everything I had tried didn't work, the tank decals wouldn't budge so I took the advice of someone on here and bought a toffee-wheel.
What an amazing piece of kit Thumbs Up
Took the decals off without messing up the paint.
Piece of cake to use, just fit in the drill and point in the right places...let it do the rest!
retrobiker
PostPosted: 22:16 - 12 Jul 2011    Post subject: Reply with quote
yeah i used one in past and recommended it to a guy on here
it worked well for me to and cheap
https://www.bikechatforums.com/viewtopic.php?t=221871&highlight=toffee+wheel
duncanpage
PostPosted: 09:22 - 14 Jul 2011    Post subject: Reply with quote
It was your reply that I read and took your advice Thumbs Up
neil.
PostPosted: 09:43 - 14 Jul 2011    Post subject: Reply with quote
On a petrol tank? Shocked
The last post was made 15 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 67.64 Kb
