diversion 600
graham mackie
PostPosted: 01:06 - 13 Jul 2011    Post subject: diversion 600 Reply with quote
Bike has always started no problem, has only done 12500 miles.
Today I stopped for a minute to make a call home and when I tried to restart her, when I pressed the button nothing happens apart from the red oil light comes on and the green neutral light goes off. Called out the AA man he managed to get the starter motor to turn over just like normal but it would not start, plenty of fuel in it, just wont spark up. Anyone got any suggestions please.
Thanks in anticipation.
Graham Mackie
weasley
PostPosted: 06:25 - 13 Jul 2011    Post subject: Reply with quote
Is the kill switch on? I had an XJ600 which did the same thing and it was the kill switch wire that had detached.
graham mackie
PostPosted: 12:02 - 13 Jul 2011    Post subject: Reply with quote
Tried the kill switch it's ok cheers though, I suspect it is something to do with the gear changing/selection situation.
PostPosted: 12:07 - 13 Jul 2011    Post subject: Reply with quote
Does the green neutral light go off by pressing the start button? If so you have an earthing issue most likely. Check the battery negative terminal and the other end of that lead too.
graham mackie
PostPosted: 14:43 - 13 Jul 2011    Post subject: Reply with quote
the green light does go off will try this out
The last post was made 15 years, 76 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.63 - MySQL Queries: 13 - Page Size: 42.17 Kb
