DIY Gaskets
nowhere.elysium
The Pork Lord
PostPosted: 19:51 - 14 Jul 2011    Post subject: DIY Gaskets Reply with quote
While I would ordinarily turn to the nearest cornflakes box at the merest suggestion of needing a gasket, I need ones for my GS carburettors, and bollocks am I paying £40 for a set.
Can I just buy a sheet of gasket material for it, and is there any special type that has to be used for carbs?
:edit: - I know that it's possible to buy sheets of gasket material, it's more whether it's a special type that I want to know.
stonesie
PostPosted: 20:37 - 14 Jul 2011    Post subject: Reply with quote
As long as it is ok for petrol it should be fine, I know it turns some grades of silicone to mush.
Hylomar blue is fuel resistant Wink
nowhere.elysium
The Pork Lord
PostPosted: 20:41 - 14 Jul 2011    Post subject: Reply with quote
I believe it's the red version that's fuel resistant, what with having bought some recently. There's no way that I'm using instant gasket on a carb; that's asking for trouble, especially after forking out £65 quid to get them properly cleaned.
I suppose that I can go see if the local autofactors has any gasket material.
bryvw1973
PostPosted: 21:19 - 14 Jul 2011    Post subject: Reply with quote
i have used normal gasket paper on a carb float bowl with no problems but it was meant to have a paper gasket if that helps
temeluchus
PostPosted: 21:41 - 14 Jul 2011    Post subject: Reply with quote
Jbweld and similar can be used to seal up carburettors.
Ptfe tape can be used in place of o-rings on idle screws and the like.
nowhere.elysium
The Pork Lord
PostPosted: 21:45 - 14 Jul 2011    Post subject: Reply with quote
Bit less permanent, ideally. It's a rolling restoration, and I know I'm going to need to get in the carbs again at some point in its life.
Bit too 'rat' for this bike. Might give it a shot, if it comes to it. I've not encountered any overly expensive O-rings yet, though.
PostPosted: 21:57 - 14 Jul 2011    Post subject: Reply with quote
Does it need to be especially thick?
Cardboard is fine on carburettors. I've used it on inlet manifolds before.
jimspeed
PostPosted: 22:29 - 14 Jul 2011    Post subject: Reply with quote
/\ this, I have used filter box's before now on carbs and they have been fine once tight, you may want to re'tighten the fitting screws once its had chance to get the card wet tho (some carb gaskets for the old cars at work were getting very hard to find)
thinner is usually better unless you have lots of warpage Wink
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
nowhere.elysium
The Pork Lord
PostPosted: 07:51 - 15 Jul 2011    Post subject: Reply with quote
Cool. Cheers for the help guys: I'll go nick the cereal box now, then.
The last post was made 15 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 64.15 Kb
