Replacing Carb Drain Screws
Pernig
PostPosted: 22:22 - 14 Jul 2011    Post subject: Replacing Carb Drain Screws Reply with quote
I would like to hear from people who have had to change the carb drain screws on their bikes, particularly old Yamahas with the philips heads that are the same width as the threads and are concealed within the float bowl.
How did you get them out? Am I looking at delicately drilling them?
And another question, I am looking to replace the screws with the external cylindrical type hex head, so I won't have this problem again, but I can't seem to find anyone in the UK who can supply these. Have you any ideas?
Thanks for your help.
H100 Breaking for spares
finpos
PostPosted: 23:10 - 14 Jul 2011    Post subject: Reply with quote
You may find that this will become tiring fast.
The reason that the screw a) has no head and b) is made from cheese is because the end you can't see is conical and seals up into a similarly shaped seat. If you drill it out you will probably ruin the seat.
However if you want to fit something with a head (and presumably a soft washer) you may as well just drill it out and re-thread it, in which case any machine screw type thing will do.
f.
Pernig
PostPosted: 23:52 - 14 Jul 2011    Post subject: Reply with quote
Thanks. Two of the screws are OK, so I know roughly how far down I can get away with drilling. I guess replacing with a regular bolt like you suggested is an option if it gets screwed up.
The replacement one I am talking about retains the conical shape you mentioned, but is stainless with the external head to prevent these things happening again. I have a whole set of stainless screws for the carbs and these were the only ones that weren't included!
finpos
PostPosted: 11:49 - 16 Jul 2011    Post subject: Reply with quote
I've not heard of the modified screws - In all honesty I've had so much trouble with these in the past I've adopted the policy that carbs do not actually need draining and now either don't touch the drains or glue the screw in with sealant if they leak!
f.
The last post was made 15 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 40.28 Kb
