| LordShaftesbu... |
 LordShaftesbu... World Chat Champion
| P.addy |
 P.addy Red Rocket
 Posted: 11:27 - 15 Jul 2011 Post subject: |
Just take calipers off, strip and clean them.
Re-bleed and its all good  |
| chris-red |
 Posted: 11:32 - 15 Jul 2011 Post subject: Re: Seized brake calipers? |
| Doug97 wrote: | I usually only ride my ER-6n in the winter, hence it's always covered in crud and salt. I remember at the end of winter 09/10 I took it in for a service and was told afterwards that they had had to fix seized front brake calipers. I had noticed a drop in braking power but hadn't thought too much about it.
Now after riding it over winter 10/11, and it having sat outside since then, I'm riding it at the moment (till the Street Triple is fixed) and have noticed the same loss of braking power.
How would I go about checking whether or not the same seizing has happened? And if the calipers are seized, would just some WD40 fix it? |
You need to buy somethings,
I can of brake cleaner (£5)
a 2 pack of toothbrushes (Tesco value 10p)
Silicon Grease (£??)
Copperslip (£??)
Take them off (one at a time) take the pads and clips out, pull the brake lever and watch the pistons in the caliper move. Make sure none of them come out too far. If not all your pistons are moving it is seized. The best way to free the seized one is hold the moving pistons in with you hand a squeeze the brake lever a fer times this should free it off.
The pistons will likely be covered in Shit, using the brake lever squeeze out all the pistons evenly until you can see clean metal.
*If you squeeze too much you will pop a piston out and have to bleed the brakes*
Once there are all out use the brake cleaner to blast off all the shit any stubborn muck will have to be shifted with the tooth brake. Use liberal amounts of brake cleaner.
Once all the pistons are clean apply the silicon grease to all the pistons then squeeze them back in so they are flush with the caliper This can be tricky with 4 piston calipers. Then put the pads etc back in using copperslip on the backs of the pads and on the retaining pin/any parts you need to remove the pads.
Then do the other one a nice easy satisfying job.  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| DrDonnyBrago |
| LordShaftesbu... |
 Posted: 11:57 - 15 Jul 2011 Post subject: |
Thanks everyone.
OK, I'm going to come across as borderline retarded during this process, but I've barely ever done anything mechanical. I mean seriously, I've never even changed my own oil, and I don't even know where the spark plugs are.
I'll start with the easiest thing first, checking that it actually has seized. So I need to remove the brake pads and 'clips'. A couple of questions:
1. What clips?
2. How do I remove the brake pads?
If I get that sorted I can see if any pistons aren't moving (and then probably take it into a garage).
Thanks a lot!  |
| LordShaftesbu... |
 Posted: 11:59 - 15 Jul 2011 Post subject: |
OMG GOLD BLOB
AT LAST, HOW LONG HAVE I BLOODY WAITED????
sorry  |
| LordShaftesbu... |
 Posted: 12:07 - 15 Jul 2011 Post subject: |
I'm guessing I have to remove the brake from the brake disc first?
[EDIT]
OK does this video show a sensible demonstration? Because I think I could just about manage what he does (although knowing my luck all the screws will be seized and I'll strip the heads).
https://www.wonderhowto.com/how-to-replace-brake-pads-motorcycle-311652/
Step -1: Check I have all the right size allen keys etc., plus spares for when I break them.
Step 0: Remove brakes from brake discs.
Step 1: Remove legendary 'clips'
Step 2: Remove brake pads
Step 3: Squeeze brake lever and identify immobile pistons.
Do I have it right?
| chris-red |
| iooi |
 iooi Super Spammer
| P.addy |
 P.addy Red Rocket
 Posted: 12:15 - 15 Jul 2011 Post subject: |
Put the tools down, walk backwards slowly... further...further
I'm going by BCF map that you are MILES up north.
I'm sure there is a few BCF'ers local that will show you how to do it... but the first ever job I did was change the oil on my bike...admittedly, 4 bikes in
If you have any doubt at all, do not do it, you do not want your braking system to have ANY issues whatsoever  |
| LordShaftesbu... |
| LordShaftesbu... |
 Posted: 12:24 - 15 Jul 2011 Post subject: |
I might have exaggerated a little when I said I didn't know where the spark plugs were ... I know they're in the cylinder head.
Just don't ask me to point to the cyclinder head!
joking joking |
| chris-red |
| DrDonnyBrago |
 Posted: 12:35 - 15 Jul 2011 Post subject: |
Lol, if you are near Cardiff/Newport I'll happily help you .
If you do decide to do it then start on the rear brake as a practice, if you feck it up it can still be ridden to a garage. Your first bit of maintenance being the brake system might not be a great idea though, make an effort to do your own servicing for a year, spend the money you would have paid a garage on tools and a manual and you will learn a lot, save money and probably enjoy it a lot. There is something very satisfying about saving hundreds of pounds and spending time with your bike .
Doing just what chris said with the help of a manual should be fine though, you are just pumping the pistons out and giving them a scrub.
Do you have a torque wrench?
| P.addy |
 P.addy Red Rocket
| LordShaftesbu... |
 Posted: 13:35 - 15 Jul 2011 Post subject: |
| ##Paddy## wrote: |
Was that the set of levers that you can adjust the length with a small allen key? If so did you sort it/claim for anything? |
Yeah, them's the ones. It's sorted in that the Triumph is all fixed and back up and running. I didn't bother trying to claim from the Chinese seller, that wasn't going to get anywhere. I just couldn't face the hassle TBH.
| DonnyBrago wrote: | Lol, if you are near Cardiff/Newport I'll happily help you  .
Do you have a torque wrench? |
I live in Edinburgh but thanks for the offer mate. I don't have a torque wrench but I can get one. Is it required?
Is there all that much that can go wrong? I mean, that video makes it look simple ... |
| iooi |
 iooi Super Spammer
| P.addy |
 P.addy Red Rocket
| LordShaftesbu... |
| chris-red |
| TUG |
 TUG World Chat Champion
The last post was made 15 years, 49 days ago. Instead of replying here, would creating a new thread be more useful? |
