What are your thoughts on Kawasaki ZXR750
Musketeer
PostPosted: 11:11 - 17 Jul 2011    Post subject: What are your thoughts on Kawasaki ZXR750 Reply with quote
I was checking prices of used ZXR400s and I found a few ZXR750s among the adverts.
What are they like? Would you buy it or pick ZXR400 instead?
Rob W
PostPosted: 11:18 - 17 Jul 2011    Post subject: Reply with quote
I loved my little 400 to bits, but after owning a couple of bigger bikes, I think I'd be wanting more power. I think riding torquey 'thous can make you lazy (it has me). I was funnily enough looking at one the other day on Gumtree, same colours as my 400 was (Green/White/Blue) and was actually quite tempted.
TS50 > Senda 125 > ZXR400 > CB-1 > GSX-R1000 > Bandit 600 > ZXR750 H1 > GSX-R750 SRAD > '98 Fireblade > T595 Daytona > Hornet 900 > '04 Fireblade > GSX-S1000F (x2) > '23 XSR900
c-m
PostPosted: 15:01 - 18 Jul 2011    Post subject: Re: What are your thoughts on Kawasaki ZXR750 Reply with quote
ZXR750 is a great bike, though seriously getting on now.
I had a J1 model and loved it.
The J1 was limited to around 100 or so BHP which helped with lower/mid range.
The front end was amazing, much better the ZX9R i bought afterwards.
I used to get around 180-220miles out of a tank too.
What was annoying was the short service interval. Valves ever 6k - but a least the cam chain didn't have to come off to change them.
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
keggyhander
PostPosted: 16:22 - 18 Jul 2011    Post subject: Reply with quote
Most gorgeous sports bike ever.
It is also the most uncomfortable.
CarlosCBR
PostPosted: 16:50 - 18 Jul 2011    Post subject: Reply with quote
Absolutely gorgeous. However its 3rd place in my list of favourite Kwaks behind the ZX7R and 2006 ZX10R.
c-m
PostPosted: 17:12 - 18 Jul 2011    Post subject: Reply with quote
I found it more comfortable than an 07 VFR and more comfortable than my 9R
Jenks
PostPosted: 17:41 - 18 Jul 2011    Post subject: Reply with quote
specify which 750 Smile
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
Musketeer
PostPosted: 07:58 - 19 Jul 2011    Post subject: Reply with quote
I don't know anything about them that's why I was asking...
This is the one I was talking about...
https://www.autotrader.co.uk/classified/advert/201120387335635
c-m
PostPosted: 08:41 - 19 Jul 2011    Post subject: Reply with quote
The L's and P#s are heavier, worse on fuel and the cam chain has to come off to adjust the valve clearnences. They do have more power though and a higher top speed.
The J and K is lighter, yes it's slower only 148mph top speed, but better on fuel and easier to work on.
PostPosted: 09:16 - 19 Jul 2011    Post subject: Reply with quote
They may be pretty, but I see no reason to go for one over a J model ZX6R, which generally seems to be a better bike, unless you want old, slow and lumbering handling.
Barry_M2
PostPosted: 09:21 - 19 Jul 2011    Post subject: Reply with quote
c-m wrote:
.... and the cam chain has to come off to adjust the valve clearnences.
No, it doesn't Wink
No easier or harder to work on at all, they are practically the same from J through to M models, with minor differences here and there.
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
DrDonnyBrago
PostPosted: 09:30 - 19 Jul 2011    Post subject: Reply with quote
No it doesn't. The cams have to come out but that is true for all shim under bucket bikes.
Barry_M2
PostPosted: 09:55 - 19 Jul 2011    Post subject: Reply with quote
The ZXR doesn't have buckets over the shims, only the ZX7 does. You dont actually need to remove the cams either on the ZXR, you can push the followers to the side as they are held in place with springs. It's a bit tight but can be done. Wink
DrDonnyBrago
PostPosted: 10:05 - 19 Jul 2011    Post subject: Reply with quote
Easy on smart arse Wink , I only have experience of the zx7r. removed the cams when we did it, are you sure you can get them out with cams in place? There was barely enough room to measure the clearances.
Barry_M2
PostPosted: 10:33 - 19 Jul 2011    Post subject: Reply with quote
Yep, once you push the follower to the side you have about 10-15mm ish!
Obviously its much easier if you remove the cams, but as the space from the cam covers to the frame are so tight it's difficult to line up the cams & chain when you come to re-fit unless you remove the engine. I have done it, but it's a pain to see down there.
Musketeer
PostPosted: 08:49 - 20 Jul 2011    Post subject: Reply with quote
As you mentioned that it's heavy I googled it and it says 205kg dry Confused I would need to spend a year at the gym to be able to handle a bike as heavy as that one Wink Especially getting out of my property would be challenging especially in the mornings (or wet days) when it's quite slippery in my garden where I would have to push it up the hill on the grass Thumbs Down
Nah.. 180kg dry max for me (160kg preferably). "Man up" comments expected haha, thanks. But I must admit it's a great looking bike.
0ddball
PostPosted: 09:25 - 20 Jul 2011    Post subject: Reply with quote
The weight isn't an issue on the road but yeah, it isn't the best bike for pushing around in small spaces.
ZXR750L
bacon
PostPosted: 09:42 - 21 Jul 2011    Post subject: Reply with quote
I chose my Zx7r for the awesome 90's styling, the j 6r might be a better bike but I'd still choose a 7r given the same choice again.
edit: and yeah id choose one over a zxr400, in comparison despite the zxr750 making less power than later 750's, it will still have more than the 400, and weigh only maybe 20kg more? (im guessing).
The 205kg dry weight really isnt that much of a big deal on the zx7r, you get used to it.
dansrockin
PostPosted: 11:05 - 21 Jul 2011    Post subject: Reply with quote
brilliant bikes, ive had two, a j1 and an l3, the l3 was definitly the better bike, better rear shock as standard, more power, better looking in my opinion without the hoover pipes! the sound they make when you wind it on in second or third gear is to die for!
they dont seem any heavier to push around than any other sports bike, and once on the move you dont notice the weight anyway.
they have one of the best front ends ever put on a road bike.
i found them both to be fairly comfy for commuting and long distance stuff, pretty good fuel economy too.
maybe not as fast as some of the other 750s, but they can more than hold there own, and they look and sound better than anything else for the same money!
and the secret is get a green one, they go faster! lol
chrisgixxer
PostPosted: 15:59 - 21 Jul 2011    Post subject: zx7r Reply with quote
these were one of the best handling bikes in there day but a little heavy and a tad slow to keep up with competion
speeding dosn't kill stopping does
current bike suzuki gsxr 1000 k8
previous bikes kawasaki zx9r e-1, aprilia rsv mille, suzuki gsxr 750 k5, yamaha r6, kawasaki zx9r c2, kawasaki zx6r f3, suzuki gs750d, yamaha xs250, honda h100
Fortuna
PostPosted: 17:09 - 21 Jul 2011    Post subject: Reply with quote
This 10 stone weakling owns a ZX7R.
Musketeer
PostPosted: 23:41 - 21 Jul 2011    Post subject: Reply with quote
11 stones here, fairly athletic build, but strength counts for nothing when legs go sideways Wink I'm not worried about riding a heavy bike. It's the pushing on slippery surface that worries me.. I had problems with much lighter bikes Embarassed
ZRX61
Victor Meldrew
PostPosted: 15:24 - 22 Jul 2011    Post subject: Reply with quote
BLUEX5 wrote:
As per usual Kwackers, head gaskets and water pumps fail and the odd issue with dropped valves due to chocolate collets.
Really? Never had any of that happen to any of the Kaw's I've owned during the past 36 years...
& several of them went over 100K miles without doing anything to the engine apart from oil/filter changes & valve adjustments. Current ZRX (93K miles) hasn't needed any valves adjusted in the past 40,000 miles...
They're not one night stands, they're auditions.
The last post was made 14 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 135.27 Kb
