Rear Preload.
WannaBeDude
PostPosted: 12:54 - 17 Jul 2011    Post subject: Rear Preload. Reply with quote
Have tightened up my rear preload, as sit seemed a bit to bouncy for me, think i may of tightened it too much, so before my C spanner turns up in the week, any thoughts on a good rear preload setting. I'm 17 stone btw .... Karma Thumbs Up
PostPosted: 13:05 - 17 Jul 2011    Post subject: Re: Rear Preload. Reply with quote
Google came up with this:
https://www.motorcycleinfo.co.uk/index.cfm?fa=contentGeneric.peqehomhihbyduvj&pageId=97391
Something like 25mm sag as it talks about there is pretty standard. You are setting a consistent sag for you on the bike, not a specific 'setting'.
However, ideally you would probably get a new spring matched to your weight, as yours is probably for a lighter rider.
WannaBeDude
PostPosted: 13:11 - 17 Jul 2011    Post subject: Reply with quote
When they sold me the bike, they said it was ok, the seller did a ride on it and was of similar weight at the time.
I lost about a stone and a half, and it became more bouncy, i wanted better handling through tighter corners.
I screw drivered the preload down about an inch and a half, and sitting on the bike it seems a little too stiff.
I'd also like to ask, the four frame bolts that connect the rear frame to the front. Should they be solidly connected tight or have some play.
Karma Thumbs Up
PostPosted: 13:17 - 17 Jul 2011    Post subject: Reply with quote
If you lose weight, the bike should get a stiffer feel.
However, it's possible what you may be then feeling is damping settings set too low ('bounce' is obviously quite vague) - as you now have less weight to damp out the spring, which may actually be too stiff now.
The subframe should definitely be solidly connected with no play.
WannaBeDude
PostPosted: 13:26 - 17 Jul 2011    Post subject: Reply with quote
Thanks, it feels stiff bouncing on top of it upright, not ridden with settings yet. C spanner will turn up in the week, i'll undo it an inch no more and test when bikes working again.
At present it feels likes the back end would take a pounding on potholes etc ... although i allways, if i see them, lift my fat ass up to compensate.
Part of the problem is, i don't really know whats best, i was under the impression a tighter rear preload would be better for cornering now i'm experienced at least with this bike and pushing the boundrys more.
Karma Smile
PostPosted: 13:46 - 17 Jul 2011    Post subject: Reply with quote
Read the link I posted - get the preload set to the correct amount of sag and use that as a base line.
Generally you want as soft suspension as possible, but without bottoming out or undulating. This way it will be the most compliant over bumps mid-corner.
WannaBeDude
PostPosted: 14:01 - 17 Jul 2011    Post subject: Reply with quote
Blimey, really, so i need to adjust it where bouncing stationary on the bike, it does not bottom out / reach the max spring load ? Karma
edit, that link is the very page i read before thread making ... lol Embarassed Crying or Very sad
weasley
PostPosted: 14:42 - 18 Jul 2011    Post subject: Reply with quote
Just to point out something commonly misunderstood - adjusting preload make NO DIFFERENCE to the 'stiffness' of the spring - all it does is adjust which part of the shock's travel you are using. As explained above, you set the preload to achieve a static 'sag', which is typically around a third of the available shock travel.
If it's too bouncy then you need to adjust damping (compression and/or rebound) but you need to get it all back to stock settings and start from there, otherwise you'll find yourself in a mess. Alternatively the shock is worn and not damping correctly anyway.
WannaBeDude
PostPosted: 16:32 - 18 Jul 2011    Post subject: Reply with quote
It's a non adjustable shock that only has preload, it's done about 5500 km ...
Will loosen it back a touch and see how it feels. Thumbs Up
PostPosted: 16:49 - 18 Jul 2011    Post subject: Reply with quote
Use a cable tie around.
Bit fiddly on a rear shock, but it'll show you if it's bottoming out.
I couldn't always tell when my ST2 was bottoming out as they have rubber stoppers and it used to just kiss them.
Ideally you want some freeplay for those 'Oh i've hit a pothole' moments.
https://i104.photobucket.com/albums/m174/howlingterror_2006/IMG_0085-2.jpg
WannaBeDude
PostPosted: 19:13 - 18 Jul 2011    Post subject: Reply with quote
This is how it is, adjuster has been screwed downwards over an inch.
https://i37.photobucket.com/albums/e53/covdude/2011/18072011.jpg
https://i37.photobucket.com/albums/e53/covdude/2011/18072011002.jpg
PostPosted: 19:35 - 18 Jul 2011    Post subject: Reply with quote
A picture normally helps...Not in this situation.
Cable tie it...Ride it. Look where the cable tie ends up.
Against the stopper? Then lose more weight or change the spring.
You want about 10mm freeplay.
WannaBeDude
PostPosted: 19:40 - 18 Jul 2011    Post subject: Reply with quote
So applying my full weight on the seat upright, about 10 mm play between the metal body of the shock and the lower black rubber stopper .. ? Karma Thumbs Up
PostPosted: 21:23 - 18 Jul 2011    Post subject: Reply with quote
You need to ride the bike as you would normally do. i.e wearing kit on a mixture of road types.
Thing is you're a big lad. The bike was probably built and road tested using an average weight Italian.
My Ducati is a Sports Tourer. It's meant to haul luggage, rider and luggage. I'm not that heavy (12 1/2 stone) my pillions are under 9st. My preload is on full and it will still bottom out.
As i don't do much full luggage with pillion touring i haven't bothered uprating the spring.
Your bike is still newish so the suspension will still be working well.
Suspension is always a compromise.
WannaBeDude
PostPosted: 22:08 - 18 Jul 2011    Post subject: Reply with quote
Thanks,
I'll get sopmeone to look at it to see exact travel when i'm on it, and go from there.
ta Smile Karma
PostPosted: 22:31 - 18 Jul 2011    Post subject: Reply with quote
which will only tell you part of the story.
Riding over bumpy B roads or gassing it hard out of a corner. Braking hard etc.
That's why i mentioned using a visual indicator like a cable tie, but i suspect (and please don't sue me) 17st = full preload on a 125.
The last post was made 15 years, 90 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 94.79 Kb
