Aprilia RS125 Wont start. help please!
leepick
PostPosted: 16:04 - 17 Jul 2011    Post subject: Aprilia RS125 Wont start. help please! Reply with quote
basically my rs wont start, i bought a new coil (still wont start)
the piston moves freely in gear so its not seized.
had a new coil few weeks ago so it isnt that
all i get when i press the electric start button is ''TICK''...
all help will be appreciated
Aprilia RS125
PostPosted: 16:10 - 17 Jul 2011    Post subject: Reply with quote
Battery if it just clicks...
leepick
PostPosted: 16:14 - 17 Jul 2011    Post subject: Reply with quote
allright mate. its a new battery aswell. i got 12.3 volts in it. my alarm works fine and the horn and lights all work...
Aprilia RS125
PostPosted: 16:17 - 17 Jul 2011    Post subject: Reply with quote
Hows your starter solenoid? tried bridging the gap on there?
leepick
PostPosted: 16:22 - 17 Jul 2011    Post subject: Reply with quote
how would i go about bridging the gap mate?.
i also bought a new starter relay. dont no if i allready stated this
Aprilia RS125
leepick
PostPosted: 16:31 - 17 Jul 2011    Post subject: Reply with quote
Rob Fzs wrote:
tried bumping it?
tried a couple of times but cant really get it up to speed...
Aprilia RS125
thomp1983
PostPosted: 16:34 - 17 Jul 2011    Post subject: Reply with quote
try bump starting it first to confirm it will start as that'll narrow the fault down to the starter components. turn ignition on, clutch in into 1st run along with bike when you gather some pace release the clutch quickly whilst twisting the throttle open see if it starts if it does pull the clutch in before the bike can run away from you, you'll probably need the choke on 2
chris
leepick
PostPosted: 17:08 - 17 Jul 2011    Post subject: Reply with quote
chris
will try this soon as poss mate, some dirty little rat stole the tank off my bike, good job i didnt catch them doing it otherwise id probly be in jail rite now..
Aprilia RS125
PostPosted: 17:10 - 17 Jul 2011    Post subject: Reply with quote
Laughing they stole the tank!? why on earth Laughing
leepick
PostPosted: 17:15 - 17 Jul 2011    Post subject: Reply with quote
i dont no i really couldnt tell ya... pissed me off big time tho. dirty little tramps
Aprilia RS125
leepick
PostPosted: 17:44 - 17 Jul 2011    Post subject: Reply with quote
bridging the gap?
Aprilia RS125
thomp1983
PostPosted: 17:48 - 17 Jul 2011    Post subject: Reply with quote
there's probably still enough fuel in the carb to start the bike even with no tank so you should still be able to bump start it and see if you can fix your starting issue before fitting another tank
chris
PostPosted: 17:53 - 17 Jul 2011    Post subject: Reply with quote
leepick wrote:
bridging the gap?
This isnt yours... but closest i cba to find Laughing
Something like this.. basically one side is connected to your batteries + terminal. Chunky wire.
Bridging the gap.. the gap between the 2 nut/bolt looking thing. I use a rubber handled screwdriver and get both of them touching with that. If it still clicks, try a different battery or check your starter/ground.
My battery is OLD and sitting there right now is 12.8V
https://www.2carpros.com/images/articles/electrical/starter/solinode/starter_solinode.jpg
PostPosted: 17:55 - 17 Jul 2011    Post subject: Reply with quote
Also, put the choke on... regardless. My RS hated being off choke when it was cold.
leepick
PostPosted: 18:32 - 17 Jul 2011    Post subject: Reply with quote
so does mine mate
Aprilia RS125
leepick
PostPosted: 19:01 - 17 Jul 2011    Post subject: Reply with quote
so u honestly think its battery even though its not even a month old?
Aprilia RS125
thomp1983
PostPosted: 19:19 - 17 Jul 2011    Post subject: Reply with quote
if your bike happens to have an electrical fault such as a failed regulator then yes in a month it could have drained a new battery, or the solenoid he pictured above could have failed, the solenoid effectively transfers power from one of those terminals to the other when you press the button so if it's failed then your not getting power to the starter motor they have moving components inside and can click when failed or not getting enough power
chris
leepick
PostPosted: 19:22 - 17 Jul 2011    Post subject: Reply with quote
chris
do you mean the starter relay?... because i put a new one in less than a week agp. or do u mean the powervalve solenoid?
Aprilia RS125
thomp1983
PostPosted: 19:39 - 17 Jul 2011    Post subject: Reply with quote
he means the starter solenoid as pictured above, find your battery follow the positive lead it will go to a unit similar to that pictured above get a rubber handled screwdriver and use the blade to short the two terminals together you'll probably get some sparks but just ignore them and get the screwdriver held on there flat with the choke on the bike should start or just bump start it, once you know the bike will start you can then diagnose why it's not starting off the button
chris
ace-card
PostPosted: 20:01 - 17 Jul 2011    Post subject: Reply with quote
Or.....a lose wiring connection, possibly on a molex plug somewhere??
2007 Skyjet SJ-125, 2001 Aprillia RS125, 1988 Honda CG125, 1997 Yamaha YZF600R
Mama said "life is like a box o' chocolates....have what's nice, then offload the crap to everyone else!" Wink
leepick
PostPosted: 20:02 - 17 Jul 2011    Post subject: Reply with quote
im thinking loose wiring...
Aprilia RS125
leepick
PostPosted: 20:04 - 17 Jul 2011    Post subject: Reply with quote
chris
uild
... ill do this aswell... it cut out as i was riding in high revs like 2nd 3rd gear to clear my exhaust out like the MOT mechanic told me to (even tho its just had a rebuild).. so maybe somethings got too hot or a wires come loose or something
Aprilia RS125
PostPosted: 22:23 - 18 Jul 2011    Post subject: Reply with quote
Well dont trust him then Laughing
Clean exhaust by removing it and bunging up one end, put caustic soda in, bung the other end up and leave it overnight.
The last post was made 15 years, 90 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 120.76 Kb
