Datatool system 3
killa
Won't Shut Up
PostPosted: 11:42 - 21 Jul 2011    Post subject: Datatool system 3 Reply with quote
Before i melt this thing down to use as a coffee coaster (and possibly a flick through the manual)
What’s going on with this thing?
Battery is fine in the fob, battery seems fine on the bike. The fob has two buttons, one to disarm and one changes the alarm mode i think.
Whenever it feels like it the alarm decides when i press the ‘disarm’ button, it’ll continue to make long beeeeep! beeeep! beeeep! beeeeep! Noises (not the noise of triggered alarm) and no amount of pressing the buttons switch it off. Sometimes it will work, sometimes it won’t.
Has anyone else had this, how do i stop it making me look like a tit everywhere i go?
jay12329
Dr. Evil
PostPosted: 11:45 - 21 Jul 2011    Post subject: Reply with quote
If I remember correctly the long beeping noises tell you that the alarm has gone off since it was armed and the number of beeps tells you what caused it to go off.
Not sure what would cause it to continuously give long tones.
HTH
J
multijoy
PostPosted: 11:48 - 21 Jul 2011    Post subject: Reply with quote
Kill it with fire!
PostPosted: 11:54 - 21 Jul 2011    Post subject: Reply with quote
Take note of how many beeps and what tone they are then look at the manual.
When the alarm has gone off it doesn't beep for long just slightly longer than normal.
mjn51
PostPosted: 12:11 - 21 Jul 2011    Post subject: Reply with quote
a quick look at the manual later, are you putting into service mode by accident, system beeps every 15 secs ?
in case you can't find it the manual can be found
here
https://www.datatool.co.uk/pdfs/system3_ug.pdf
mjn51
PostPosted: 12:12 - 21 Jul 2011    Post subject: Reply with quote
beeps :-
2 Power Failure (Alarm) Fuse failed Wires cut
3 Hot wire detection (possible theft) Ignition tampered with
4 Movement detection Motorcycle has been moved
5 Nudge detection Motorcycle has been nudged too many times
6 Tamper circuit Protective trigger switch has been initiated
Jayy
Mr. Ponzi
PostPosted: 13:38 - 21 Jul 2011    Post subject: Reply with quote
Not sure but they're fucking annoying! Filling up with petrol is an arse, it arms itself and you have to put it into valet/service mode or keep the ignition on.
Liono
PostPosted: 18:06 - 21 Jul 2011    Post subject: Reply with quote
I've got the System 3 on my bike too and I despise it. It seems to be expressly designed with the intention of being as annoying as possible (yes, I can see why it might need to though).
The fact that there isn't a way of putting it into a mode where it doesn't beep every few seconds is incredibly annoying; it's very off-putting trying to do any work on it with it chirping away idiotically at frequent intervals.
PostPosted: 18:27 - 21 Jul 2011    Post subject: Re: Datatool system 3 Reply with quote
This is similar to what mine was doing three days before it packed up completely and left me stranded. I got a tech from Datatool to call and all he could suggest was I remove it as they are discontinued and there are no spares.
Jayy
Mr. Ponzi
PostPosted: 19:06 - 21 Jul 2011    Post subject: Reply with quote
Reassuring to know that Pete! I carry the fob on around my neck on a black chord thing that came with it, if I lose my keys and someone thinks they can steal the bike, they can't. At the same time though, If I somehow lose the fob from around my neck or put it down somewhere, I'm fucked!
Oldie
PostPosted: 20:12 - 21 Jul 2011    Post subject: Reply with quote
Had this system on my last bike - absolutely hated it.
Now have the Triumph/Datatool 4? and it's much better, but still a pain. At least you can fill up with fuel and it doesn't go berserk if a fly lands on the seat Neutral
sickpup
Old Timer
PostPosted: 20:15 - 21 Jul 2011    Post subject: Reply with quote
Not if you set up the PIN. Wink
TUG
PostPosted: 17:44 - 12 Dec 2011    Post subject: Reply with quote
ARGH mine is driving me fucking mental, it keeps beeping 3 times when I arm and disarm the alarm, i've checked all my wires and they are not at fault, i fucking hate this alarm, i've always hated the system 3's so i think its time to see if i can get a meta cheap from somewhere!!!!
Haz ER-5, innit!
rac3r
PostPosted: 18:17 - 12 Dec 2011    Post subject: Reply with quote
Alarms suck! Laughing
Look in the manual, I managed to get mine to do nothing at all apart from beeping when it arms/disarms. I managed to move the bike around and even lift the tank without it going off Laughing
Chequered Flag
Kris
PostPosted: 18:22 - 12 Dec 2011    Post subject: Reply with quote
Pfft. System 3 is easy.
Petrol Station:
- Pull up.
- Ignition off.
- Arm alarm (Left Button)
- Disarm movement (Right Button)
- Fill up as normal.
WTF is hard about that?
www.prisonplanet.com
mealies
PostPosted: 18:28 - 12 Dec 2011    Post subject: Reply with quote
I think the manual states this happens when the batteries in the fob are low. you may want to change those pronto if you haven't set a pin on the alarm
salty21
PostPosted: 18:32 - 12 Dec 2011    Post subject: Reply with quote
3 long beeps means battery in the fob is dying, sometimes mine just does it randomly, i've ripped it out of the last 2 bikes as mine used to cut the ignition at 10,000 rpm due to vibration frequencies in the engine, which when your pinning it in first comes as a bit of a shock and almost throws you over the bars if your not ready for it Laughing
Fisty
PostPosted: 20:16 - 12 Dec 2011    Post subject: Reply with quote
Mike, take the alarm off and burn it.
I had the system 3 on my TL, it kept going off randomly (even when not set!!) and died on me on the M4 the same day it did exactly what yours did.
Shocking alarm, It keft giving me Fi Fault codes after its was "fixed" by a datatool dealer.
I ended up taking the whole thing off.
Fatter and faster than Fret
GrantT
PostPosted: 20:43 - 12 Dec 2011    Post subject: Reply with quote
Petrol Station:
- Pull up.
- Ignition off.
Exactly what I do on the Speed Four!
Also use this mode when working on the bike, anything that doesn't require the ignition on or playing with electrics can be done in this mode - adjusting chain, pumping tyres, bleeding brakes etc....
GrantT
PostPosted: 20:44 - 12 Dec 2011    Post subject: Reply with quote
here
Excellent, thanks for this, been looking for the manual (obviously not hard enough!).
All I got with the bike is a hand written instruction on how to put it in service mode in the back of the service book!
Snodvan
PostPosted: 22:06 - 12 Dec 2011    Post subject: Reply with quote
Out of interest
HOW DO YOU take the ****** thing off the bike - properly??
Mine came with the bike (BMW) and is a pain in the butt because of the battery drain during periods of bike inactivity. The repetitive beep when the battery is out for various reasons is also grrrrrr !!
Snod
04 (UK Reg) BMW F650cs, but really 02 first Reg in Holland
GrantT
PostPosted: 22:17 - 12 Dec 2011    Post subject: Reply with quote
Snodvan wrote:
Out of interest
Snod
I asked my local Triumph dealer and he showed me how they come from the factory with no alarm, don't really want to put it up here in the public domain though for obvious reasons....
Send me a PM if you want and I'll fill you in
The knowledge is pretty public domain anyhow can share if the mods want.
MinhDinh
PostPosted: 22:42 - 12 Dec 2011    Post subject: Reply with quote
Service mode makes it beep.
You can disarm it to make it make no noise too, just press the buttons in a differed way, Which I forgot how to do now!
Hit the G spot. Wink
totalllama82
PostPosted: 00:28 - 13 Dec 2011    Post subject: Reply with quote
Take it off!
The siren on mine actually broke it was so vocal... think it beeped itself to death.
Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
Current: Kawasaki ZZR 1400 A7F
neatbik
PostPosted: 10:51 - 13 Dec 2011    Post subject: Reply with quote
I had one on my Triumph, it was a complete ball ache tbh.
It had a mind of its own, if i didnt use the bike for a while it would drain the battery and i just bloody hated it.
By the time i figured out just how easy it was to remove it i had pretty much sold the bike. (Not because of the alarm, i just wanted a change).
Hateful things in my opinion.
The last post was made 14 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 127.8 Kb
